Old 04-23-2008, 09:11   #1 (permalink)
Member: 599037
Thanks Meter: 103
a strange problem.. plz hlp for ztc zt6698
hi brother,, i got a ztc zt 6698 deasd.. i found the pinouts with the hlp of pin finder..i tried safe formatc but no use then i used complete format on that fone and after that fone is not getting on again.. means still dead.. i connected the fone on the digital power supply and found that till i pressed the power buton it consumes .02 amperes, but as i released the power button the fone consumes 0 amperes..
chk thw infinity log below:-
asd i pressed the pwr button everything is ok but as i release the pwr button as said by infinity the softwares gives error coz fone stops to consume power. here is the log):-
chk here
COM46 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:22E2:1A39
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
error: no any expected answer: wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 118 sec
Remove/Install battery now !..
wen software said to release the pwr button i did... as this error shown.. bt on the other hand if i do not release the pwr button everything is ok but fone still dead..
do i need to flash the fone... if yes then plz share the full flash for this fone here.. thanx plz hlp me that what shud i do??
oone more thing.. before complete format the fone was consuming.05 amp near bout current.. btu after complete format it doesnt..
Old 04-23-2008, 09:22   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
phone will not flash, problem with flash ic..... reball or change
Old 04-23-2008, 09:24   #3 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
u need not to flash the phone just heat the flash ic slightly and check it again....u will solve ur problem
if problem still same then Reball ur cpu and flash ic....from this u will receieve some result sure
Good luck
Kmax Mobile Repair
Gurmandi,Patiala
Old 04-23-2008, 09:24   #4 (permalink)
Ravvi's Avatar
Member: 611165
Thanks Meter: 36
Initialize...
Fault reasons:
Initialize Fail
See that errors bro...this is problem in flash chip....rehot or reball flash ic..we are also getting that type of problems....reball flash ic & post results
Old 04-23-2008, 09:29   #5 (permalink)
Member: 599037
Thanks Meter: 103
before the complete format the fone was dead but was consuming the pwr in sm milli amperes,... but after the complete foprmat the fone got totally dead.. i means it consumes the pwr till i kept the pwr switch pressed but as i relese the pwr button the power consumed is 0.... any idead what shud i do
Old 04-23-2008, 09:54   #6 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
Talking
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
see near cpu mt6226 then u found there flesh ic rehoot or rebool ic
now com to topic power consuming
i also se 9 phone with same models with 1 gb internel memory when i try to
format these phone same error comes damage flesh chip and after that
phone is going to same poosition as yours so rebool flesh solve you problam
rebool and post result there
best of luck
Old 04-23-2008, 11:34   #7 (permalink)
Member: 599037
Thanks Meter: 103
Originally Posted by joni_rajpura View Post
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
best of luck
gud shot bro.. i heated the chip and fone started to boot.. here is the log
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: B0001D00000000:B0001D00000000
flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.30CBF139.[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN_D67C4850].rpl
identification#1 detection finished
device-id: 30CBF139
identification#1 protocol ver: 04
ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN
ver. sw2: DM402.V007.WMB.2BT.GKW, AFB78329
ffs offset/size: 00F00000/00100000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00F00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00F00000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00F00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN]_20080423-155651.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _30CBF139_MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_ WMB_2BT_GKW.BIN_D67C4850_20080423-155741.B0X.bin
Finished, time used: 293 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
but aftere that the fone is still dead.. what shud i do now??
Old 04-23-2008, 12:28   #8 (permalink)
Member: 508072
Thanks Meter: 1,621
Talking
good jobbbbb bro....................
Old 04-23-2008, 15:27   #9 (permalink)
Member: 599037
Thanks Meter: 103
Ok Bro.. I Read The Full Flash From The Fone And Then I Erased The F;ash Chip And Wrote The Read Flash Agaiun... But Fone Is Still Dead....while Fone Is Using The Power Form The Digital Pwr Source But Not Getting On... Any Idea What Shud I Do???
HERE IS THE LOG FOR THE OPERATION..
COM46 [VCP4] selected
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00E00000
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80423-180737.B0E.bin
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 2755 sec
Old 04-23-2008, 19:31   #10 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
now after you repaired hardware, you must restore firmware in your phone.
you must find this software version file and flash your phone:
Old 04-24-2008, 05:17   #11 (permalink)
Ravvi's Avatar
Member: 611165
Thanks Meter: 36
Thanx for info Infinity help
Old 04-24-2008, 06:29   #12 (permalink)
Member: 599037
Thanks Meter: 103
hello!
thanx for ur reply tem.. i tried finding that file in the suport but didnt foiund... plz if sm one hav that flash fiel then plz share here.... thanx
Old 04-24-2008, 09:59   #13 (permalink)
Member: 148515
hello!
unfortunately we dont have this file on support
it must be found from collection of our users or you must read it out from working phone
Old 04-24-2008, 15:19   #14 (permalink)
Member: 599037
Thanks Meter: 103
please i urge to every one that if smonehav that model fone in the hands the plz read the firmware and eeeprom and share with me.. thanx model ztc zt6698
Old 04-24-2008, 20:14   #15 (permalink)
Member: 148515
hello!
it will be better if you start new tread with this question
like subject "ztc zt6698 firmware needed"
and full version name inside
this will be more visable for other users
i-Pmart BX Series RJ45 Cable Compatible For ZTC ZT6698 For Infinity Box IPMART ipmart WebShop 0 07-08-2009 10:50
u600 keys very strange problem.. plz hlp me here.. peter002 HWK 6 06-15-2009 15:39
flash for ztc ZT6698 malacatonche SpiderMan 1 01-17-2009 10:23
need firmware for ztc zt6698 peter002 Infinity-Box 2 04-25-2008 15:58
Page generated in 0.30058 seconds with 10 queries
