Old 06-09-2018, 15:10   #1 (permalink)
Member: 2511098
Thanks Meter: 41
Stream b3 maxi after rmoving pattern data were lost
after removing pattern wit Qualcomm module the data were erased -_-
log
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 0AA271C2
ID_BLOCK_L : C7215BA3129885807FD43C21EEB53D0D
ID_BLOCK_L : 7914BA15068931B257A6EB2022CDDBE0
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Direct access : Ok!
Processing step #1
Processing step #2
Processing step #3
Processing step #4
Processing step #5
Processing step #6
Processing step #7
UserLocks reset passed!
1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart!
2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints
3. In some cases require reboot phone twice or wait up to 5 minutes!
Done!
Elapsed: 00:00:38
Reconnect Power/Cable!
Old 06-10-2018, 11:09   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Lock reset not touch any data.
Required make exactly described way.
Since your report first - can't say anything useful, cos need full data dump to check it state, same device sample on hands and few days for testing.
Or atleast more info how device act after reset and power one.
step-by-step , better with timings between boot/home screen, what it wrote and e.t.c.
Normally - if FS has been damaged by some way - device will ask to make reset at boot. Then need dump data and make manual forensic. Nothing more happen.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.13176 seconds with 8 queries
