12-05-2008, 15:20 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | subject: touchscreen calibration failed : New firmware detected (2.70) COM6 [VCP0] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.25A1DA4D.[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN_FA15095E].rpl New firmware detected (2.70) : QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 25A1DA4D identification#1 protocol ver: 04 ver. sw 1: QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN ver. sw 2: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022, A1F6EA05 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2CEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 04227E22212200:2CEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 04227E22212200:2CEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_25A1DA4D_QVGA_PCB01_GPRS_MT6226_S01.SC_7 787_JBO_CSTAR_EN_ABRI_V1_3_26B_20071022.BIN_FA1509 5E_20081205-180217.B0X.bin Finished, time used: 68 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [12/5/2008 6:03:03 PM] ==== COM6 [VCP0] selected module v2.70 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 1 2 3 4 5 6 7 8 9 11 12 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ==== log: [12/5/2008 6:03:27 PM] ==== COM6 [VCP0] selected module v2.70 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 2 sec Remove/Install battery now ! ==== log: [12/5/2008 6:03:46 PM] ==== COM6 [VCP0] selected module v2.70 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 14 sec Remove/Install battery now ! ==== log: [12/5/2008 6:04:13 PM] ==== COM6 [VCP0] selected module v2.70 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 5 6 7 8 9 10warning: wrong packet cs 11 done 146 byte(s) read reading data #2... reading data #3... error: operation failed ! Finished, time used: 44 sec Remove/Install battery now ! ==== log: [12/5/2008 6:05:06 PM] ==== COM6 [VCP0] selected module v2.70 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022 Version: KP26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 88 sec Remove/Install battery now ! ==== log: [12/5/2008 6:07:05 PM] ==== COM6 [VCP0] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6054:2793 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2CEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.25A1DA4D.[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN_FA15095E].rpl New firmware detected (2.70) : QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 25A1DA4D identification#1 protocol ver: 04 ver. sw 1: QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN ver. sw 2: SC_7787_JBO_CSTAR_EN_ABRI_V1.3_26B_20071022, A1F6EA05 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2CEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN]... file saved: C:\Documents and Settings\Mano Billy\My Documents\flash[QVGA_PCB01_GPRS_MT6226_S01.SC_7787_JBO_CSTAR_EN_AB RI_V1_3_26B_20071022.BIN]_20081205-181521.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_25A1DA4D_QVGA_PCB01_GPRS_MT6226_S01.SC_7 787_JBO_CSTAR_EN_ABRI_V1_3_26B_20071022.BIN_FA1509 5E_20081205-181548.B0X.bin Finished, time used: 521 sec Remove/Install battery now ! here is the link Br Faisal_Computer |
s3 touchscreen calibration failed... | gsmsikar | Infinity-Box | 6 | 08-07-2009 07:59 |
Ztc N328 touchscreen calibration failed | KK Mobile | Infinity-Box | 1 | 05-06-2009 20:20 |
Calibration Mode Falied New firmware detected. | Shakeel_pattoki | Infinity-Box | 5 | 04-18-2009 00:28 |
<<< China A666 Touchscreen Calibration Failed >>> | khadim100 | Infinity-Box | 2 | 04-05-2009 11:36 |
Touchscreen calibration failed in N99i | lie_james | Infinity-Box | 1 | 01-23-2009 19:40 |
