12-25-2008, 04:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | succes full unlock Bost-Mobile D615 module v2.71 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On chip: 0031:0ABF:3E05 detected CPU: MT6226MA Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: V1.00.04_M070925AU1-V24 Version: HWV1.0 detecting structure #2... done 60 byte(s) read imei: 35488501312462 connection Ok detecting structure #1... done 208 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 34814512/43185421 locked to: 000-00 SP code: 0000000000003344/0000000000003344 CP code: FFFFFFFFFFFF2143/FFFFFFFFFFFF1234 IMSI code: 2050500000930000/0205050000390000 Phone code: 0000000000000000 Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to ayhen42 For This Useful Post: |
12-25-2008, 16:37 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Bost-Mobile-D615 UNLOCK DONE | nilan | Infinity-Box | 2 | 05-18-2009 12:43 |
succes full unlock MY phone S21 | ayhen42 | Infinity-Box | 18 | 04-20-2009 18:26 |
Bost-Mobile-D615 (yes Optus) Unlock Done | srkhan | Infinity-Box | 2 | 02-08-2009 14:30 |
Bost-Mobile D615 cable pinout needed | tahod | Infinity-Box | 3 | 12-21-2008 10:22 |
