04-18-2009, 06:31 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Succes repair Much D800 ps. this phone problem is restart no sim insert log pinfinder ==== log opened: [4/17/2009 4:24:53 PM] ==== Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.17 Smart-Card S/N: xxxxx Smart-Card firmware version: 0112 Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished COM4 ready searching adapter at COM4... adapter found, version: 2000 S/N: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx done Initializing... done Cable: 2x6 (L12B) software version: 1.17 cable type: 2x6 (L12B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM4... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:4 Tx:2 time required: 18 sec Power On ! software version: 1.17 cable type: 2x6 (L12B) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM4... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:5 Tx:3 time required: 1 sec Power On ! log format operation ( complete mode ), i try format cpu 6205 can't format, only cpu 6226 can ==== log: [4/17/2009 6:17:49 PM] ==== COM4 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:4A41:7F48 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.75F87B9F.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_9EA247B7].rpl ==================== New firmware detected (v.2.81, database date: unknown): MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 75F87B9F identification#1 protocol ver: 04 ver. sw 1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN ver. sw 2: MAUI.05C.W06.16, 48B85D61 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\MTK26_05C_MASTER_ PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16__ffs_2009041 7-183912.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M TK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16__system_log_75F87B9F_9EA247B7_20090417-184001.B0X.bin Finished, time used: 1319 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! log repair imei ( only mode-3 can repair with another mode can't repair ) ==== log: [4/17/2009 6:45:40 PM] ==== COM4 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 354707000047961 ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:4A41:7F48 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.75F87B9F.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_9EA247B7].rpl ==================== New firmware detected (v.2.81, database date: unknown): MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 75F87B9F identification#1 protocol ver: 04 ver. sw 1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN ver. sw 2: MAUI.05C.W06.16, 48B85D61 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\MTK26_05C_MASTER_ PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16__ffs_2009041 7-190726.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... 4 step(s) required Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E22202200:29EA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M TK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16__system_log_75F87B9F_9EA247B7_20090417-192111.B0X.bin Finished, time used: 2128 sec Remove/Install battery now ! well that's all thx to infinity team for the great tool.... regards. notgood |
The Following User Says Thank You to notgood For This Useful Post: |
Need pinout MUCH D800 | sewet | Chinese Models & Cloned Phones | 1 | 04-15-2009 04:52 |
succes repair x820 camera | timberland2 | Trident/AGERE Platform | 1 | 01-04-2009 11:45 |
K550 and w580 succefully repaired | GsmFreeShop | Cruiser Suite | 11 | 11-05-2008 13:31 |
Error with reading .ASK. file, jaf are not succes repair dct4 ??????...imei number | anis_4u | Nokia Hardware & Hardware Repair | 0 | 05-31-2008 22:22 |
