Old 09-22-2008, 06:10   #1 (permalink)
jatchaminda's Avatar
Member: 661090
Sonork: 100.1616818
Thanks Meter: 541
sagem my150x unlock sucess
COM13 selected
Device: Sagem-my150x
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
sw version: EAI_IC_251207_1558 251207_1558 EAI_IC Ag Bh `
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-sta_20080922-102216.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-sec_20080922-102219.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20080922-102229.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 75 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
The Following User Says Thank You to jatchaminda For This Useful Post:
Old 09-22-2008, 21:57   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
>>> sagem my150x unlocked successfull <<< keaelite Infinity-Box 1 05-06-2008 17:13
Sagem-my150x Unlock ok pardeeptelecom Infinity-Box 1 05-02-2008 14:07
My150X unlock sucess sharaz191 FuriousGold 0 03-26-2008 10:25
sagem my150x unlock code johnridge Phone Unlocking Codes & Maps 0 03-22-2008 13:29
pls help on sagem my150x unlock in mt manekmobile07 ARM9 BASED M62 / M62+ 4 03-21-2008 14:13
Page generated in 0.16120 seconds with 9 queries
