success unlock my220v hi evryone infinty the best always unlock succesful with only prolific Application: D:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.43 S/N: 2B7B:010E Wait... Current model: Sagem-my220v Ready COM19 ready COM19 [Serial2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IO_141107_1557 141107_1557 EBI_IO Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Documents and Settings\Administrator\Desktop\backup_eeprom-sta_20080412-142635.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: D:\Documents and Settings\Administrator\Desktop\backup_eeprom-sec_20080412-142638.B1E.bin reading [eeprom-complete]... file saved: D:\Documents and Settings\Administrator\Desktop\backup_eeprom-complete_20080412-142645.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 45 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
good infu.......................... |
Thanks for onfo Which cable..? |
its good job thnx for info: |
1..........16 9: Phone Tx (RJ45 pin 3) 10: Phone Rx (RJ45 pin 2) 16: Gnd |
thanks for share it infinty is great |
Thanks, infinity users, Do you have any solution for unlock code < my 220x, my 150> |
thanks for this info.............. |
