09-01-2009, 01:55 | #1 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: No Location
Member: 87853 Status: Offline Thanks Meter: 1,231 | ***Success Unlocking Alcatel V670 With Infinity *** After U Can Enter The Unlock Code: NCK: 3258496332 SPCK:2118269893 Quote:
The Following 8 Users Say Thank You to MED9 For This Useful Post: |
09-01-2009, 10:48 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Working Solution Tested ON Alcatel S621x Imei:352395023109729 NCK: 2615640713 SPCK: 2594767218 Br UMER Last edited by maplegsm; 09-01-2009 at 10:54. |
The Following 2 Users Say Thank You to maplegsm For This Useful Post: |
09-08-2009, 14:24 | #4 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 297973 Status: Offline Sonork: 100.1604447 Thanks Meter: 35 | v670x unlock with infinity tested with v670x and 100/100 working thanks COM11 [VCP0] selected module v2.84 Périphérique: Alcatel-V670X, V670A Contrôle des données, attendre ... détection avancé de flash activé Action: "repair imei" nouvel imei: 357195020370455 Boot ... Appuyez et restez appuiez sur le bouton "Power" dès maintenant! 19200 fixed En route, attendre ... Initialisation [6226:8A03:8A02]... CPU: MT6226 chip: 0031:F870:A000 status: 01 taille de paquet de démarrage: 0400 lachez bouton d'alimentation maintenant! Boot Done Initialiser ... detecting chip #00 in region #00... Flash 01227E22302200:2BEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb le nombre de puce flash / régions détectés: 01/01 Initialiser Done Ensemble bauds ... 460800 Ensemble bauds Done Initialiser Démarrage ... Initialiser Démarrage Done Vérifier l'intégrité du firmware ... detect device rom info... phase de détection #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.E4E55 824.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_6A728EF9].rpl rom info detection finished device-id: E4E55824 rom info protocol ver: 05 ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN ver. sw 2: MAUI.06A.W06.52.SP1.V24, 06718D95 ffs offset / taille: 01000000/01000000 ffs address assigned: 01000000 startup code area #1 check... startup code area #1 fixed detect device sec info... phase de détection #1... detect device sec info finished sim-lock statut: enabled Vérifier l'intégrité du firmware Done Vérifier le contenu du firmware ... Vérifier le contenu du firmware Done sauvegarde les données requises ... imei original: 35305102110439 Flash 01227E22302200:2BEA0000000000 sauvegarde les données requises Done données requises Patch ... ..................................... original data found, method-A données requises Patch Done Opération spéciale ... Opération spéciale Done écrire ... Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 écrire imei detect device sec info... phase de détection #1... detect device sec info finished security area (sec info, part #2) calculation... Customization CC19FF23 bien Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 écrire security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... bien Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 écrire security area (sec info, part #1) security area (sec info, part #1) calculation done écrire Done Achèvement ... FFS formatting... Flash 01227E22302200:2BEA0000000000 Achèvement Done fichier sauvegardé: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V670X,V670A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_E4E55824_6A728EF9_20 090908-151747.B0X.bin Terminé, temps utilisé: 224 sec Retirez / remettre la batterie maintenant! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to kadergsm For This Useful Post: |
09-08-2009, 14:45 | #5 (permalink) |
Member: 297973 Status: Offline Sonork: 100.1604447 Thanks Meter: 35 | tested on alcatel v670x and 100/100 working No Need Any Flash File To Unlock Just Change Ur Original Imei To( 357195020370455) After U Can Enter The Unlock Code: NCK: 3258496332 SPCK:2118269893 |
The Following 4 Users Say Thank You to kadergsm For This Useful Post: |
11-16-2009, 22:12 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is direct unlock solution for Alcatel models, need to test it now. Please, try to unlock phone with this new software: http://www.infinity-box.com/download...dule_v2.94.rar It is no need to flash phone, just use "SP-Unlock" button from software "Service" page. Waiting for your results. |
help for unlock alcatel v670 help help | nejm | Infinity-Box | 5 | 06-27-2009 09:01 |
help unlock alcatel v670 | nejm | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 05-17-2009 00:21 |
Successfully unlock Alcatel-S319X with Infinity | Masud-GSM | Infinity-Box | 4 | 02-08-2009 05:34 |
Has anybody unlocked Alcatel c825x with infinity? | dennis1 | Infinity-Box | 1 | 10-21-2008 15:42 |
succesfully unlock alcatel s210 with infinity+pinfinder | Haouas | Infinity-Box | 1 | 07-26-2008 20:33 |
