04-17-2008, 13:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Error Age: 40
Member: 553840 Status: Offline Thanks Meter: 122 | Successful Formet with Pin Finer here is the Logg....... Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:E341:5E1C high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3DFDEB15.[E506_B15_PCB01_GPRS_MT6226_S01.00_1.BIN_E39F7A6A].rpl identification#1 detection finished device-id: 3DFDEB15 identification#1 protocol ver: 04 ver. sw1: E506_B15_PCB01_GPRS_MT6226_S01.00_1.BIN ver. sw2: E506_B15.00.1, 9585601C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E506_B15_PCB01_GPRS_MT6226_S01.00_1.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E506_B15_PCB01_GPRS_MT6226_S01.00_1.BIN]_20080417-173230.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _3DFDEB15_E506_B15_PCB01_GPRS_MT6226_S01.00_1.BIN_ E39F7A6A_20080417-173250.B0X.bin Finished, time used: 226 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
need help sprint 7700 dead after formet with cpf dongel | R@jusat | CPF-Dongle | 3 | 03-20-2009 12:16 |
n95 With PIN code it HANG without PIN ok! | zakiyyboss | Infinity-Box | 15 | 10-15-2008 12:32 |
cect q380 can't find pin outs with pin finder | kiran | Infinity-Box | 4 | 04-09-2008 09:12 |
successfully format by Pin Finder Adapter | GEEBOO | Infinity-Box | 1 | 04-08-2008 17:49 |
n95 without pin ok, with pin hang | Proxy | Infinity-Box | 4 | 03-25-2008 02:22 |
