11-04-2017, 16:33 | #31 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | .::Successful Story For MTK Secure Boot Starts::. 1)OPPO F1S (32GB) A1601 MT6755 : https://drive.google.com/open?id=0Bw...E1YeVpmVzFINEU 2)OPPO F1S (64GB) A1601 MT6755 : https://drive.google.com/open?id=0Bw...URYazJnRTUzODQ 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS GOOD LUCK |
The Following 12 Users Say Thank You to gracy_elec For This Useful Post: |
11-14-2017, 19:58 | #32 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
IF NO, PLEASE SHARE DA FILE FOR THIS Micromax Q338 | |
11-15-2017, 10:01 | #34 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A71 CPH1717EX AndroidVer: 7.1.1 MTK 6750/55 FRP REMOVE Done SUCCESSFULLY REMOVE FRP MT6750/55(OPPO A71 CPH1717)USB Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_170815 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : OPPO Device Model : CPH1717 Device CPU : MT6755 Device IntName : CPH1717 Device Version : 7.1.1 Device Compile : 8/14/2017 3:17:42 PM Device Project : CPH1717EX_11_A.02_170815 Device ExtInfo : CPH1717 Ready to Flash! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : CPH1717 ProdModel : CPH1717 Device : CPH1717 AndroidVer: 7.1.1 MTKxCPU : MT6755 MTKxPRJ : CPH1717EX_11_A.02_170815 Done! Elapsed: 00:00:17 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB6E [eMMC] : FLASH_CID : 150100474536424D42030857F2A57409 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2B142F03980DD716A92665EA3648BA58 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
11-15-2017, 13:11 | #35 (permalink) |
Freak Poster Join Date: Nov 2009 Location: gonbad-iran
Member: 1155715 Status: Offline Sonork: ahmad.derakhshan61 Thanks Meter: 23 | hi i have 2 tablet I TOUCH -elink c706d- mt 6572 not boot by cm2.i hold vol +& too. have a new trick for it???? Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E43617264203588D2355662A7 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
11-16-2017, 14:55 | #37 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | WIKO KENNY SIGNED SPRELOADER AndroidVer: 7.0 MT6737M FRP REMOVE Done SUCCESSFULLY REMOVE FRP SIGNED SPRELOADER MT6737M(WIKO KENNY V3913)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E0B040142018C33B2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4201040BB2332401 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA3F6A391845AB709CA063AB5AF3758F6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : v3913 ProdModel : KENNY Device : v3913 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P139 Done! Elapsed: 00:00:17 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E0B040142018C33B2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4201040BB2332401 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA3F6A391845AB709CA063AB5AF3758F6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear PVL ( PrivacyLock ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
11-16-2017, 15:58 | #38 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Wiko kenny secure boot da files WIKO KENNY SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK 1 : https://drive.google.com/open?id=1_w...E50B8920h7so7_ LINK 2 : https://drive.google.com/open?id=1zR...BiLhRJ8yUUvA_4 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following 5 Users Say Thank You to gracy_elec For This Useful Post: |
11-16-2017, 16:24 | #39 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Oppo a71 cph1717ex secure boot da files OPPO A71 CPH1717EX SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=1wM...0TEU9A33pBYZTJ 1)SELECT MT6755_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following 7 Users Say Thank You to gracy_elec For This Useful Post: |
11-16-2017, 16:28 | #40 (permalink) | |
More greece to your elbow....... | |
11-16-2017, 16:42 | #41 (permalink) | |
"Not Found" Error 404 | |
11-16-2017, 18:34 | #42 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | 1)Sorry 2)New Link For OPPO A71 CPH1717EX 3)New link : https://drive.google.com/open?id=1wM...0TEU9A33pBYZTJ GOOD LUCK |
The Following 8 Users Say Thank You to gracy_elec For This Useful Post: |
11-16-2017, 18:40 | #43 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | 1)Sorry 2)New Link For WIKO KENNY 3)New Link1: https://drive.google.com/open?id=1zR...BiLhRJ8yUUvA_4 4)New Link 2 : https://drive.google.com/open?id=1_w...E50B8920h7so7_ GOOD LUCK |
11-17-2017, 06:51 | #44 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Wiko upulse secure boot da files WIKO UPULSE SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=1Hx...GDYFqF8RenErka 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
11-17-2017, 16:03 | #45 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Asus x008da mt6737m secure boot da files ASUS X008DA MT6737M SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=1Xw...vqc-IM1qYixtpH 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following 15 Users Say Thank You to gracy_elec For This Useful Post: |
