Old 11-18-2017, 03:07   #46 (permalink)
deepuknp's Avatar
Member: 610829
Thanks Meter: 20
link not working please fix
Old 11-18-2017, 16:38   #47 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
Great job, guys. Looking forward for the next update.
Meanwhile, I'm looking for Hisense F23E (MT6737M) Secure DA.
If someone can post that one, that'd be much appreciated.
Thanks in advance
Old 11-18-2017, 17:23   #48 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 82
Please I need DA file for ASUS X008DC for FRP removal...Thanks
Sent from my TECNO CX Air using Tapatalk
Old 11-18-2017, 17:36   #49 (permalink)
Member: 1677653
Thanks Meter: 2,769
Have u try this phone with CM2 AST MODULE?
Old 11-18-2017, 18:53   #50 (permalink)
dineshras's Avatar
Member: 2185083
Sonork: 100.1670782:dineshras
Thanks Meter: 185
Rdp
Originally Posted by gracy_elec View Post
GET ERROR WHEN REMOVE PATTERN LOCK SECURE BOOT MT6735/MT6737M(LENOVO A7700)USB
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:02
Reconnect Power/Cable!
SUCCESSFULLY REMOVE SECURE BOOT MT3735/MT6737M PATTERN LOCK(LENOVO A7700)USB
FOR TIME BIN NEED TO REPLACE THE BOOT FILE MTK_AllInOne_DA_SP.bin IN BOOT FOLDER AND YOU WILL SUCCESS GOOD LUCK
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 520001154D31323829F700423B3BECD0
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D4200F729D0EC833B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xFD096D450C258A4EC5D285CA7BEEF6A8
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Lenovo
ProdName : A7700
ProdModel : Lenovo A7700
Device : A7700
AndroidVer: 6.0
MTKxCPU : MT6735
MTKxPRJ : A7700_USR_S218_1608151700_MP3V2_16G_ROW
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXXXX
BTMAC Addr : XXXXXXXXXXXX
WiFi MAC : XXXXXXXXXXXX
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P14_1_lwg _n
Done!
Elapsed: 00:00:18
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear RDP
Clear Ok!
Done!
Elapsed: 00:00:20
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:28
THANKS INFINITY-BOX TEAM
Clear RDP
Clear Ok!
What is RDP ???
The Following User Says Thank You to dineshras For This Useful Post:
Old 11-19-2017, 05:53   #51 (permalink)
Member: 1676006
Thanks Meter: 7
ASUS X008DA MT6737M SECURE BOOT DA FILES
HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP
LINK : https://drive.google.com/open?id=1Xw...vqc-IM1qYixtpH
1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB
2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO
3)NEED TO PRESS VOL "-" TILL THE END OPREATION AND YOU WILL SUCCESS
4)POST LOG OPREATION
5)IF ANY PROBLEM I CAN HELP YOU OK
GOOD LUCK
Hello ACCESS DENIED please other link..... thanks
Old 11-19-2017, 07:35   #52 (permalink)
rmstk's Avatar
Member: 2484144
Sonork: QQ_3272429273
Thanks Meter: 318
The Following 5 Users Say Thank You to rmstk For This Useful Post:
Old 11-19-2017, 08:12   #53 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Link Working Rechecked
Good Luck
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 11-19-2017, 09:27   #54 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 332
Question
Good Luck
hi dear
i have one question
are this secure boot fles working universal?
like lenovo mt6735 chipset da file for huawei models same chipset?!
Old 11-19-2017, 15:04   #55 (permalink)
Member: 1705399
Thanks Meter: 81
gracy_elec sir help me
i got vivo v5s, its secure boot
i am changing da file in boot folder but its required auth file
so where should place auth file?
please reply sir
Old 11-19-2017, 17:49   #56 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 128
Old 11-20-2017, 08:22   #57 (permalink)
murari-GSM's Avatar
Member: 1538128
Sonork: 100.1613105
Thanks Meter: 199
Good Luck
Thanks man
http://forum.gsmhosting.com/vbb/12793355-post46353.html
The Following User Says Thank You to murari-GSM For This Useful Post:
Old 11-20-2017, 13:24   #58 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Originally Posted by murari-gsm View Post
atlast your problem sloved so you happy
good luck
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-20-2017, 19:45   #59 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 128
Old 11-21-2017, 10:41   #60 (permalink)
Member: 2636476
Thanks Meter: 61
i got oppo f3 plz post file
Page generated in 0.24903 seconds with 9 queries
