Old 09-18-2018, 18:53   #406 (permalink)
Member: 331917
Thanks Meter: 210
Originally Posted by YellowBoss View Post
CM2MT2 software is for new CPU but for older models you should use CM2MTK
the AUTH option is not supported on old version, could you please add??
or, allow us to use same cpu please.
thanks
Old 10-16-2018, 12:41   #407 (permalink)
Member: 2079059
mt6572 working 100%,please add other cpu.
With da file not working any models,please add cpu supporter how mt6572
Old 10-17-2018, 10:49   #408 (permalink)
Member: 2079059
I am sorry working cm mtk v1.58
Big thanks for works.
Old 11-05-2018, 15:23   #409 (permalink)
Member: 1766893
Sonork: iball
oppo a71 DA-error
need oppo a71 cph1717 boot file cm2
geating this error any one have boot fle
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
Old 11-05-2018, 15:51   #410 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,691
post full log from infinity cm2
Old 12-04-2018, 06:16   #411 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 133
VERTEX IMPRESS SUN 4G SECURE BOOT DA FILES
https://yadi.sk/d/oAmrWTELbd1nOg
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM6)
MODE : BOOTROM
PORT : 6
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00007017 : DA SEND ERROR!
  ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
  INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO type!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PTFN : MediaTek PreLoader USB VCOM (Android) (COM5)
MODE : PRELOADER PORT
PORT : 5
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : PRELOADER PORT
MODE : Vertex : Sun | Manual : Disabled
AGENT : MTK_AllInOne_DA_SP.bin
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 150100463732324D4200AE51D00F0305
DAInf: 4 : 2 : 155
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 150100463732324D4200AE51D00F2305
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F722MB
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00080000 [ 512,00 KB ]
              USER   : 0x1D2000000 [ 7,28 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        DRAM: 0x40000000 [ 1,00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 95EC77E670CAC84BD8629DEA277ED385
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : NRD90M
Display ID     : HW1.R1.V07
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2017-09-05
Build Time     : 1509089732
Product Model  : Sun
Product Brand  : Vertex
Product Name   : Sun
Product Device : Sun
Product Board  : Sun
Product Manfct : Vertex
Board Platform : mt6737m
Product Info   : Sun
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:16
The Following User Says Thank You to Abzal For This Useful Post:
Old 12-05-2018, 16:08   #412 (permalink)
Member: 2471665
Thanks Meter: 2
Lava iris 88 factory reset
I have seem problem please help
agent : selected agent doesn't have required configuration! check and select correct settings for your device!
The Following User Says Thank You to tufanbd For This Useful Post:
Old 12-05-2018, 16:19   #413 (permalink)
Member: 2471665
Thanks Meter: 2
agent : selected agent doesn't have required configuration! check and select correct settings for your device! Please help..
Old 12-09-2018, 10:40   #414 (permalink)
zebafridi's Avatar
Member: 2304199
Sonork: 100.1656573
Thanks Meter: 74
CCIT Touch Happiness P10Pro SECURE BOOT DA FILE Need
Old 02-03-2019, 20:36   #415 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 129
HI
Need Meizu M6 File please
Wait for phone...
Phone found! [ 43 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x07000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with SLA
Processing DA stage
Try Re-Install CM2MTK module!
Boot Error!
Operation Failed
Elapsed: 00:00:04
Old 02-12-2019, 10:39   #416 (permalink)
Member: 951910
Thanks Meter: 3
HUAWEI LUA L21 MT6735
Read Info
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065314738F50F07052B430C25
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505070FF5250CA32B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x2F96E7535F35AD7B78D89201752FE93F
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : HUAWEI
ProdName : LUA-L21
ProdModel : HUAWEI LUA-L21
Device : HWLUA-L6735
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : ALPS.L1.MP3.V2.95_OT6735M.35GU.LU.L1_P1
SECURITY :
IMEI_SW [1] : 863607030835779
IMEI_SW [2] : 863607033335777
BTMAC Addr : F043475333F6
WiFi MAC : F04347564136
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V48_P10_1_lwg _1
EXTRA :
LCD : Not info available
LCD Res : 854x480
TOUCH [0] : GT1XX
CAM [0] : ov5648_mipi_raw
CAM [1] : gc2355_mipi_raw
CAM [2] : sp2508_mipi_raw
CAM [3] : hi545_mipi_raw
MODEM : mt6735_sp_lwg_dsds_c2kirat_prod
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:23
The Following User Says Thank You to vovatlms For This Useful Post:
Page generated in 0.33578 seconds with 8 queries
