Old 11-04-2017, 16:33   #31 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
.::Successful Story For MTK Secure Boot Starts::.
OPPO F1S MT6755 FOR SIGNED with SPRELOADER SELECT SCATTER FILE IN FLASH OPTION AND USE OPTION LIKE READ INFO FRP USER LOCK ECT....
1)OPPO F1S (32GB) A1601 MT6755 : https://drive.google.com/open?id=0Bw...E1YeVpmVzFINEU
2)OPPO F1S (64GB) A1601 MT6755 : https://drive.google.com/open?id=0Bw...URYazJnRTUzODQ
3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS
GOOD LUCK
The Following 12 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-14-2017, 18:58   #32 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,691
Originally Posted by gracy_elec View Post
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9C
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48384731650507C5842C1892DB
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507C5842C1892DB
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xFD096D459E1E21870EF46D41CF387056
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Micromax
ProdName : Q338
ProdModel : Micromax Q338
Device : Q338
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_TINNO6580.WE.L_P4
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXX
BTMAC Addr : XXXXXXXXXXXX
WiFi MAC : XXXXXXXXXXX
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P12_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 1280x720
TOUCH [0] : GT9XX_hotknot
TOUCH [1] : synaptics_s5250
CAM [0] : s5k4h5yc_mipi_raw
CAM [1] : ov8858_mipi_raw
CAM [2] : ov5648_mipi_raw_darling
CAM [3] : ov5648_mipi_raw_sunwin
MODEM : STOM_MODEM =mt6580_s5250ap_hspa_modemB18_P12_mmx
LOCALE : en_US en_IN hi_IN mr_IN bn_IN kn_IN te_IN ta_IN ml_IN gu_IN pa_IN or_IN zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Done!
Elapsed: 00:01:31
THANKS INFINITY-BOX TEAM
BRO, DID U USED THAT LENOVO DA FILE FOR THIS PHONE ALSO?
IF NO, PLEASE SHARE DA FILE FOR THIS Micromax Q338
Old 11-15-2017, 08:00   #33 (permalink)
Member: 2592600
Thanks Meter: 16
How do we know extract Da from firmware
Sent from my C1001 using Tapatalk
Old 11-15-2017, 09:01   #34 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
Thumbs up OPPO A71 CPH1717EX AndroidVer: 7.1.1 MTK 6750/55 FRP REMOVE Done
SUCCESSFULLY REMOVE FRP MT6750/55(OPPO A71 CPH1717)USB
Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_170815 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : OPPO
Device Model : CPH1717
Device CPU : MT6755
Device IntName : CPH1717
Device Version : 7.1.1
Device Compile : 8/14/2017 3:17:42 PM
Device Project : CPH1717EX_11_A.02_170815
Device ExtInfo : CPH1717
Ready to Flash!
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BMB6E
[eMMC] : FLASH_CID : 150100474536424D42030857F2A57409
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x2B142F03980DD716A92665EA3648BA58
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Brand : OPPO
ProdName : CPH1717
ProdModel : CPH1717
Device : CPH1717
AndroidVer: 7.1.1
MTKxCPU : MT6755
MTKxPRJ : CPH1717EX_11_A.02_170815
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-15-2017, 12:11   #35 (permalink)
Member: 1155715
Sonork: ahmad.derakhshan61
Thanks Meter: 16
hi
i have 2 tablet I TOUCH -elink c706d- mt 6572 not boot by cm2.i hold vol +& too.
have a new trick for it????
Wait for phone...
Phone found! [ 94 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 8801034E43617264203588D2355662A7
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:08
Old 11-15-2017, 12:19   #36 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
hello
some phone & tab need to press volume key and some not to press volume key so try without hold volume key and post result
good luck
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-16-2017, 13:55   #37 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
WIKO KENNY SIGNED SPRELOADER AndroidVer: 7.0 MT6737M FRP REMOVE Done
SUCCESSFULLY REMOVE FRP SIGNED SPRELOADER MT6737M(WIKO KENNY V3913)USB
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 460001154D32584E0B040142018C33B2
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4201040BB2332401
DEV RID : 0xA3F6A391845AB709CA063AB5AF3758F6
SOC VERIFY : C1
Boot Ok!
Brand : WIKO
ProdName : v3913
ProdModel : KENNY
Device : v3913
AndroidVer: 7.0
MTKxCPU : MT6737M
MTKxPRJ : alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P139
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear PVL ( PrivacyLock )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
Old 11-16-2017, 14:58   #38 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
Wiko kenny secure boot da files
WIKO KENNY SECURE BOOT DA FILES
HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP
LINK 1 : https://drive.google.com/open?id=1_w...E50B8920h7so7_
LINK 2 : https://drive.google.com/open?id=1zR...BiLhRJ8yUUvA_4
1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6737M_Android_scatter.txt FILE IN FLASH TAB
2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO
4)POST LOG OPREATION
5)IF ANY PROBLEM I CAN HELP YOU OK
GOOD LUCK
The Following 5 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-16-2017, 15:24   #39 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
Oppo a71 cph1717ex secure boot da files
OPPO A71 CPH1717EX SECURE BOOT DA FILES
LINK : https://drive.google.com/open?id=1wM...0TEU9A33pBYZTJ
1)SELECT MT6755_Android_scatter.txt FILE IN FLASH TAB
GOOD LUCK
The Following 7 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-16-2017, 15:28   #40 (permalink)
Member: 1677653
Thanks Meter: 1,691
wiko kenny secure boot da files
here is your file but this file is modified so you cant flash if you try to flash your phone will brick this file can be use for read info,read user lock,read pattern lock,remove frp
link 1 : https://drive.google.com/open?id=1_w...e50b8920h7so7_
link 2 : https://drive.google.com/open?id=1zr...bilhrj8yuuva_4
1)need to change da files in boot folder and select mt6737m_android_scatter.txt file in flash tab
2)very importaint before do any opreation make read info
3)need to press vol "+" &"-" till the end opreation and you will success
4)post log opreation
5)if any problem i can help you ok
good luck
now you do well! Other user will also benefit....
More greece to your elbow.......
Old 11-16-2017, 15:42   #41 (permalink)
Member: 1677653
Thanks Meter: 1,691
GOOD LUCK
link not working
"Not Found"
Error 404
Old 11-16-2017, 17:34   #42 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
1)Sorry
2)New Link For OPPO A71 CPH1717EX
3)New link : https://drive.google.com/open?id=1wM...0TEU9A33pBYZTJ
GOOD LUCK
The Following 8 Users Say Thank You to gracy_elec For This Useful Post:
Old 11-16-2017, 17:40   #43 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
1)Sorry
2)New Link For WIKO KENNY
3)New Link1: https://drive.google.com/open?id=1zR...BiLhRJ8yUUvA_4
4)New Link 2 : https://drive.google.com/open?id=1_w...E50B8920h7so7_
GOOD LUCK
Old 11-17-2017, 05:51   #44 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
Wiko upulse secure boot da files
WIKO UPULSE SECURE BOOT DA FILES
LINK : https://drive.google.com/open?id=1Hx...GDYFqF8RenErka
GOOD LUCK
Old 11-17-2017, 15:03   #45 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,067
Asus x008da mt6737m secure boot da files
ASUS X008DA MT6737M SECURE BOOT DA FILES
LINK : https://drive.google.com/open?id=1Xw...vqc-IM1qYixtpH
3)NEED TO PRESS VOL "-" TILL THE END OPREATION AND YOU WILL SUCCESS
GOOD LUCK
The Following 15 Users Say Thank You to gracy_elec For This Useful Post:
Page generated in 0.54455 seconds with 8 queries
