11-27-2017, 17:23 | #76 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2606915 Status: Offline Thanks Meter: 0 | Doogee mix 1. Power Off , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for ... found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Security [ v1.58 ] 1. Power Off , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for ... found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE1000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Security [ v1.58 ] 1. Power Off , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for ... found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 0551 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! pls, i cant nor remove locks options ,its mtk 6757 chip Last edited by ckross00000; 11-27-2017 at 17:31. |
11-28-2017, 08:54 | #78 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: lithuania ,kedainiai Age: 60
Member: 36262 Status: Offline Thanks Meter: 26 | Quote:
thank you and sorry, phone was take it back for client now they are impatient regards | |
11-29-2017, 13:30 | #79 (permalink) | |
Insane Poster Join Date: Oct 2015
Member: 2473356 Status: Offline Thanks Meter: 8 | Plzzzzzzzzzz i need firmwear cz i did break my phone befor this with wrong flash Plzzzzzzzzzz i need firmwear cz i did break my phone befor this with wrong flash Quote:
11-30-2017, 13:23 | #81 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Romania, Fagaras Age: 46
Member: 34379 Status: Offline Thanks Meter: 101 | Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333158FB5C074265A081AA Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Asus_X008D with imei broken |
11-30-2017, 16:03 | #82 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333158FB5C074265A081AA Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31X [eMMC] : FLASH_CID : 150100515831334D42075CFBAA815365 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x7F64D45239E4DC8288EF11856D6E29DF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok IMEI [00] : 352929088430347 IMEI [01] : 351929088430355 Set IMEI [00] : 352929088430347 Set IMEI [01] : 351929088430355 Prepare finished. Security check required! Wait for phone... Phone found! [ 33 ] Sync... Repair done! Imei null null, anybody can share good nvram |
11-30-2017, 16:26 | #83 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Qmobile i6 metal hd mt6580 secure boot da files QMOBILE I6 METAL HD MT6580 SECURE BOOT DA FILES HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=19C...z7UUdnIxqq-epD 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6580_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL '+' & "-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following User Says Thank You to gracy_elec For This Useful Post: |
11-30-2017, 16:37 | #84 (permalink) | |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
good luck | |
11-30-2017, 16:41 | #85 (permalink) | |
good luck | |
11-30-2017, 16:50 | #86 (permalink) | |
HERE IS YOUR FILE BUT THIS FILE IS MODIFIED SO YOU CANT FLASH IF YOU TRY TO FLASH YOUR PHONE WILL BRICK THIS FILE CAN BE USE FOR READ INFO,READ USER LOCK,READ PATTERN LOCK,REMOVE FRP LINK : https://drive.google.com/open?id=154...GCyl0CDmD8R7c2 1)SELECT MT6580_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL '+' & "-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK | |
The Following 4 Users Say Thank You to gracy_elec For This Useful Post: |
12-01-2017, 12:48 | #87 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | @gracy_elec Phone came to service with this problem and i think you right. right now on phone i have version ww_Phone-13.1.0.91-20170306 and can`t find newer version |
12-01-2017, 13:24 | #89 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Xiaomi redmi note 4x mt6797 helio x20 4gb 64 gb dead boot repair firmware XIAOMI REDMI NOTE 4X MT6797 HELIO X20 4GB 64 GB DEAD BOOT REPAIR FIRMWARE BECO OF CUST.IMG FILE YOUR PHONE BRICK BY THIS FILE YOUR PHONE WILL LIFE BACK DON'T WORRY BECO MODIFIED CUST.IMG AND SCATTER FILE IF ANY PROBLEM I CAN HELP YOU OK HERE IS YOUR FILE LINK : https://drive.google.com/open?id=1kx...-sqLFvgjQ3WOK9 GOOD LUCK |
12-01-2017, 13:25 | #90 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | @gracy_elec, please check CM2 secure boot |
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post: |
