Old 01-16-2015, 14:27   #1 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 599
successfull read 492 MB file size enough to recover dead phone me this file q a 35
reading in 4 mints just other tools so slow but there file size is big what is
diffrence this file reading by other tool file can me write this via other tool
fully clear about its formate
Operation : Read Flash [ v1.09 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00AD00BC00900055005600AD00BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Read Ok , collect info
MTKxCPU : MT6572
MTKxPRJ : huaqin72_we_iba_lca
Saved to : C:\Users\fastFun\Desktop\MT6572__huaqin72_we_iba_l ca.ispff
Done!
Elapsed: 00:03:59
Reconnect Power/Cable!
Old 01-16-2015, 14:49   #2 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Sure, I hope it will work, as expected.
http://forum.gsmhosting.com/vbb/f296...l#post10802259
BTW:- Try to make sentence correct. U can use Google for that as ur English is weak
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Page generated in 0.31303 seconds with 7 queries
