Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 106 ![]() | Successfull Unlock backup Sagem my150x Device: Sagem-my150x Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_030807_1302 030807_1302 EAI_IC Ag Bh ` Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-sta_20080420-090248.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-sec_20080420-090303.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-complete_20080420-090314.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_flash_20080420-090625.B1X.bin completed Finished, Remove/Install battery now ! Time used: 248 sec |
The Following 2 Users Say Thank You to aukonline For This Useful Post: |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | Yes,thanks for the hard working of Infinity Team! :-) Today,one piece of this kind has been unlocked ;-) But,another one can't be unlocked with this software version. I will send e2prom file to support team right now. Code: COM15 [Serial2] selected Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_ID EAI_ID_160807_1140 Ag Bh ` f Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sta_20080422-180951.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sec_20080422-180953.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-complete_20080422-180955.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 30 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 Code: COM15 [Serial2] selected Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sta_20080422-183143.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sec_20080422-183144.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-complete_20080422-183146.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 23 sec Last edited by hakima; 04-21-2008 at 13:38. |
The Following User Says Thank You to hakima For This Useful Post: |
![]() | #3 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | Flash backup file has been sent to [email protected] B/r P/s:Sorry for new post with the same problem but previous post can't be edited after a few minutes. |
![]() | #6 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: NABINAGAR
Member: 747297 Status: Offline Sonork: [email protected] Thanks Meter: 47 | ![]() COM1 [Serial0] selected Device: Sagem-my150x Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_030807_1302 030807_1302 EAI_IC Ag Bh ` Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-sta_20080420-090248.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-sec_20080420-090303.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_eeprom-complete_20080420-090314.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\my150x\full flash\backup_Sagem-my150x_flash_20080420-090625.B1X.bin completed Finished, Remove/Install battery now ! Time used: 248 sec |
The Following User Says Thank You to riaz-net For This Useful Post: |
![]() | #7 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 34,071 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: South africa Age: 29
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 591 | i am trying error occured any 1 help me pls pls COM29 selected module v1.78 Device: Sagem-my150x Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... error: can't run preloader: middle part... error: can't run middle loader: Finished, time used: 12 sec Remove/Install battery now ! |
![]() | #9 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 49,005 | Quote:
My150x not unlock backup sent but error.. | ZIYAAD STRYKER | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 01-19-2010 06:37 |
Sagem My150x/vodafone 226/my401z Unlock | damabib | SMTi | 17 | 09-19-2009 08:19 |
>>> sagem my150x unlocked successfull <<< | keaelite | Infinity-Box | 1 | 05-06-2008 18:13 |
Successfull Unlock backup Sagem my150x | aukonline | Infinity-Box | 0 | 04-20-2008 18:10 |
