Successfull unlock LG-KP100!! Today I successfull unlock 2 LG-KP100!! Thanks Infinity team!! COM3 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081020-111054.B1E.bin loading data... data loaded imei: 35996101776288100 reading [eeprom-sec_35996101776288100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101776288100_20081020-111057.B1E.bin reading [eeprom-complete_35996101776288100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101776288100_20081020-111103.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 57202185 Finished, Remove/Install battery now ! Time used: 23 sec COM3 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL TME KP100 01 FL 34 V10c 214-07 MAR-25-2008 +0 j Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081103-154657.B1E.bin loading data... data loaded imei: 35996101973869900 reading [eeprom-sec_35996101973869900]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101973869900_20081103-154659.B1E.bin reading [eeprom-complete_35996101973869900]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101973869900_20081103-154706.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 75801898 Finished, Remove/Install battery now ! Time used: 23 sec How to enter code: if you have original SIM or motorola test card,power ON phone with it and enter 2945#*20001# goto Menu-Settings-Security-Sim Unlock Code- Desactivate and enter the code you get or read out |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Hallo! But i think this is since longtime supported by other tool(s)!!?? |
thank you friend keep on |
