Old 05-26-2008, 10:00   #1 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
Successfully Flashed & Unlocked Kp130
Successfully Flashed & Unlocked Kp130 using VEPRO as a Interface
Credits goes to Infinity Team Good Team.
COM9 [Serial2] selected
Device: LG KP130
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:F0EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 35212---------------
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126--------4_LG KP130_20080526-004959.B1E.bin
version: -
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
flash: 01227E22212200:00000000000000
write: 2nd chip area
Write Done
Finished, time used: 101 sec
Remove/Install battery now !
Device: LG KP130
Action: unlock
unlock method: standard
Boot...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 352126----------
file saved: C:\Program Files\InfinityBox\LGA\eeprom_35212----------_LG KP130_20080526-005306.B1E.bin
version: -
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 35 sec
The Following User Says Thank You to mujahid_ali For This Useful Post:
Old 05-26-2008, 10:04   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
thx for good test report
Old 05-26-2008, 10:51   #3 (permalink)
Member: 483440
Thanks Meter: 163
What cable you used?
Old 05-26-2008, 10:57   #4 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 817
Its with ke500 cable for the sure. if you dont have use these pinout.
keybord up
18.............1
17 - RX (data to phone)
16 - TX (data from phone)
1,4,14,18 - GND
Old 05-26-2008, 10:57   #5 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,185
good share keep it up
Cable Rj45>>>>Ke500 uni box cable
Old 05-26-2008, 14:22   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Here is KP130 cable information:
keyboard top
1.........18
1: Gnd
2: phone Rx (RJ45 pin-2)
3: phone Tx (RJ45 pin-3)
5: Gnd
15: Gnd
18: Gnd
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-26-2008, 17:02   #7 (permalink)
Member: 483440
Thanks Meter: 163
keyboard top
1.........18
1: Gnd
5: Gnd
15: Gnd
18: Gnd
this pinout work perfect with infinity unicables , but after unlock phone hang in start up! any solution?
Old 05-26-2008, 17:06   #8 (permalink)
..::: Naveed :::..'s Avatar
Member: 352237
Sonork: 100.1577161
Thanks Meter: 599
can we use tx finder cable ?
Old 05-26-2008, 17:08   #9 (permalink)
Member: 483440
Thanks Meter: 163
Problem solved by reset setting :d
Infinity bes team
Old 05-26-2008, 17:09   #10 (permalink)
Member: 483440
Thanks Meter: 163
You can use unicables from infinity , so easy , work perfect
Old 05-26-2008, 17:12   #11 (permalink)
Member: 204319
Sonork: 100.1581770
Thanks Meter: 18
thx infinity for support for KP130 thank you very much
Old 05-26-2008, 17:27   #12 (permalink)
Member: 130995
Yes, you can.
Here is an instruction: http:///vbb/showthread.php?t=526956
successfully flash & unlock 2600c with 5.61v shimul_777 J.A.F. By Jafsupport.com 1 03-07-2009 08:31
w850 successfully flash & unlock by D-Client rea1One D-Unlock Suite 11 10-01-2007 00:37
is GR1000 supported by infinity? for flashing & unlocking & which cable??? ReyTech Infinity-Box 8 05-07-2007 01:13
***Successful Flashing & Unlocking Z150 whit UST-Pro2 v2.50 :)*** bhgsmservis UST Pro II 1 07-26-2006 17:30
Page generated in 0.33065 seconds with 8 queries
