Old 04-08-2008, 15:34   #1 (permalink)
GEEBOO's Avatar
Member: 553840
Thanks Meter: 122
successfully format by Pin Finder Adapter
here is the log
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:A3C1:6F16
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.39FFE351.[E550_Y3BT3ARTF_E550_GPRS_MT6226_S01.K858_01_1.BIN_ B6B15236].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 39FFE351
identification#1 protocol ver: 04
ver. sw1: E550_Y3BT3ARTF_E550_GPRS_MT6226_S01.K858_01_1.BIN
ver. sw2: K858.E550_Y3BT3ARTF.01.1, C9AD4E49
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[E550_Y3BT3ARTF_E550_GPRS_MT6226_S01.K858_01_1.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E550_Y3BT3ARTF_E550_GPRS_MT6226_S01.K858_01_1.BIN]_20080408-192821.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _39FFE351_E550_Y3BT3ARTF_E550_GPRS_MT6226_S01.K858 _01_1.BIN_B6B15236_20080408-192842.B0X.bin
Finished, time used: 255 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
thanx infinity teamfor ur gret effort
Old 04-08-2008, 17:49   #2 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
well don dear
thanks to infinity support team
Infinity Box Pin-finder adapter test report ezzis Infinity-Box 790 07-04-2015 22:03
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / IPMART ipmart WebShop 0 11-26-2009 10:30
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / IPMART ipmart WebShop 0 11-26-2009 10:30
Infinity Box Pin-finder adapter : update box error nekbil Infinity-Box 9 02-28-2008 18:02
Infinity Box - Auto Pin Finder Adapter!!! Hams Main Sales Section 0 02-09-2008 18:13
Page generated in 0.21165 seconds with 10 queries
