Old 10-15-2008, 13:45   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Successfully Repaired ST60 Siemens
@infinity-Team
Thanks for the nice software which i didn't noticed before that Infinity Support Siemen ST60 for direct Unlock and flash.
here is the story.
yesterday i recieved one phone from customer which was saying "Sim MEP Failed" i read codes with JAF LOGER and i try all codes but no sucess phone still stays on the same error message then i try DreamBox and it reads 2 codes but problem still same error still same, then i downloaded one flasher and flash file posted by BB-gsm on this forum fones flash successfully but still the problem was same and error message was same so i was thinking to return this phone to customer but at the last try i checked in Infinity shell i thought may be it also have Calculator to calculate codes but i was surprised to see the options available in QMODULE , i unlock the phone with direct unlock and voila phone is working fine and no more error message, thank you infinity team for the nice software.
here is the log.
Application: C:\Program Files\InfinityBox\QModule\QModule.exe
Loading data, wait...
[Infinity Box] v2.21
S/N: xxxxxxxxxxxx
Wait...
Current device: Siemens-ST55,ST60
Done
COM1 ready
COM1 [VCP0] selected
Device: Siemens-ST55,ST60
Checking data, wait...
Action: Unlock
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 04227E22212200:00E3A000000000
flash: Fujitsu MB84VP24491HK T 8Mb
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20081015-122053.05E.bin
Check space Done
Check parameters...
Check parameters Done
Format file system...
Format file system Done
Write...
Preparing...
area requested/selected: 02/02
Write Done
Finished
Remove/Install battery now !
Time used: 37 sec
Take Care
ENJOY
The Following User Says Thank You to imran_qasim For This Useful Post:
Old 10-15-2008, 14:21   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
A75 siemens egold mobile blinking successfully repair by mxkey thanks azad4u MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-22-2010 12:38
BenQ-Siemens E52 Successfully repair with infinity box dog_baby Infinity-Box 5 05-19-2009 11:49
ST60 Siemens Unlock software Needed Irfangk786 Siemens-Benq RingTones and WallPapers 0 05-29-2005 16:29
st60 siemens code pleas dark Phone Unlocking Codes & Maps 14 05-24-2004 17:01
Page generated in 0.12000 seconds with 9 queries
