01-03-2009, 14:38 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: ♥ ♥ ♥ ♥ Age: 35
Member: 748880 Status: Offline Thanks Meter: 1,705 | ;;;successfully unlock;;;; COM7 [VCP0] selected module v1.57 Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20090102-164535.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20090102-164536.B1E.bin loading data... data loaded imei: 35452565558545 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20090102-164537.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20090102-164540.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 019B Done probably you need to restore original imei after unlock process Write Done Finished, time used: 82 sec Remove/Install battery now ! THANKS FOR INFINTY TEAM ALWAYES BEST |
The Following 6 Users Say Thank You to SOHAIL BASHARAT For This Useful Post: |
01-03-2009, 15:09 | #5 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437422 Status: Offline Thanks Meter: 37 | COM7 [VCP3] selected module v1.59 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090103-190847.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090103-190848.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090103-190855.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090103-190901.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 49 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to musmanm For This Useful Post: |
01-03-2009, 15:37 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
;;;successfully unlock;;;; | SOHAIL BASHARAT | NSPRO | 2 | 12-31-2008 23:20 |
