successfully unlock Vodafone-226FM COM4 selected Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sta_20081020-052141.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sec_20081020-052144.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081020-052147.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 34 sec Unlock instruction: 1. Power-On phone 2. Enter code: 1234567 |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
