08-23-2008, 10:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | successfully unlocked ALCATEL OT-V202 BY SOME TRIK Device: Alcatel E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E101_eeprom_calibration-1_20080823-143304.80E.bin Read data done Check data... Check data done Writing... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 367 sec Remove/Install battery now ! br.dynet |
The Following User Says Thank You to DYNET For This Useful Post: |
08-28-2008, 17:04 | #4 (permalink) |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | COM2 [VCP0] selected Device: Alcatel-V212 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-V212_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V212_eeprom_calibration-1_20080828-115925.80E.bin Read data done Check data... Check data done Writing... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 124 sec Remove/Install battery now ! tested today br karim _____ /12345\ _______ 1: Gnd 3: Box Tx/Phone Rx (RJ45 pin-2) 4: Box Rx/Phone Tx (RJ45 pin-3) |
The Following 2 Users Say Thank You to KARIM GSM-ZONE For This Useful Post: |
08-29-2008, 16:53 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
10-09-2008, 15:06 | #6 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 619955 Status: Offline Thanks Meter: 5 | infinity pin finder pls help pls am having infinity pin finder with infinity box and i want to unlock my alcatel ot-v212 but i dont know the cable to use please help & thanx for ur concern thanx again |
12-16-2008, 21:13 | #11 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
It's very easy: if you want to unlock Alcatel-V212 you must select Alcatel-V212 model and press "sp-unlock" button in software "Service" page. | |
[02-09-09] Unlock Alcatel OT-708 by IMEI | UnlockBase.com | UnlockBase | 3 | 01-24-2010 16:37 |
Successfully unlocked ALCATEL OT-S320 | limem2003 | Infinity-Box | 13 | 06-09-2009 13:32 |
>>> Successfully Unlocked Alcatel OT-E207 <<< | mujahid_ali | Infinity-Box | 2 | 12-15-2008 20:19 |
Successfully Unlock alcatel ot s210 with eu box | mehta | Easy-Unlocker | 1 | 10-26-2008 22:59 |
Motorola by IMEI - Alcatel OT Exxx by LOG - SOFT4GSM - WWW.UNLOCK.WS | gsmfactory | Main Sales Section | 0 | 01-21-2006 11:46 |
