Old 03-11-2009, 09:52   #1 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
>>> Successfully Unlocked Alcatel S621X <<<
Hello
i have unlocked Alcatel S621x Successfully.
1.download these 2 files
S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Serbian_simfree.B0M
S621X_repair_eeprom_ffs_universal_16m.B0E
Flash ur fone then go to service tab and click on "Repair Security Area"
Format FFS with complete mode option that's it and ur Phone is Unlock
==== log: [3/11/2009 12:24:45 PM] ====
COM5 [VCP0] selected
module v2.58
Device: Alcatel-S621X
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:2103:A009
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22422200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.0A8B0 8F9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl
identification#1 detection finished
device-id: 0A8B08F9
identification#1 protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF
ffs offset/size: 01020000/00FE0000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 35199002100331
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-122534.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD54BM02
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-122731.B0X.bin
Finished, time used: 162 sec
Remove/Install battery now !
Loading file v.04...
S621X_repair_eeprom_ffs_universal_16m.B0E.bin loaded
==== log: [3/11/2009 12:28:15 PM] ====
module v2.58
skip: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 0A8B08F9
sim-lock status: disabled
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-122854.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
done
done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-124021.B0X.bin
Finished, time used: 722 sec
==== log: [3/11/2009 12:40:29 PM] ====
module v2.58
Action: repair security area
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 0A8B08F9
done
done
Write ...
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-124228.B0X.bin
Finished, time used: 115 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [3/11/2009 12:42:32 PM] ====
module v2.58
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 0A8B08F9
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_0A8B08F9_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-124444.B0X.bin
Finished, time used: 128 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thanxs.
The Following User Says Thank You to mujahid_ali For This Useful Post:
Old 03-11-2009, 10:26   #2 (permalink)
G i l l a n i's Avatar
Member: 248178
Sonork: 100.1579207
Thanks Meter: 322
==== log: [3/11/2009 12:40:12 PM] ====
COM4 [VCP0] selected
module v2.58
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:C203:A004
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.50AAB C1B.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl
device-id: 50AABC1B
original imei: 351xxxxxxxxxxxx
Write ...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_50AABC1B_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-124103.B0X.bin
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_50AABC1B_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090311-125258.B0X.bin
Finished, time used: 748 sec
The Following User Says Thank You to G i l l a n i For This Useful Post:
Old 03-11-2009, 10:38   #3 (permalink)
samirov-gsm's Avatar
Member: 759168
Thanks Meter: 12,860
Good job...................
Old 03-11-2009, 22:49   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@mujahid_ali
@G i l l a n i
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 03-12-2009, 00:06   #5 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: (Off Line)
Thanks Meter: 1,808
module v2.58
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 50AABC1B
Write ...
done
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
Finalization Done
gooood thanks for the info
>>> Successfully Unlocked S7330 3G <<< mujahid_ali NSPRO 3 03-18-2009 16:35
>>> Successfully Unlocked T919 3G <<< mujahid_ali NSPRO 3 03-15-2009 10:01
>>> Successfully unlocked Vodafone 527 <<< mujahid_ali SAGEM JTAG UNLOCKER 1 02-14-2009 12:46
Successfully unlocked Alcatel-S621X Masud-GSM Infinity-Box 1 01-30-2009 16:16
>>> Successfully Unlocked Alcatel OT-E207 <<< mujahid_ali Infinity-Box 2 12-15-2008 20:19
Page generated in 0.37614 seconds with 8 queries
