Old 01-26-2008, 13:42   #1 (permalink)
Member: 547967
Thanks Meter: 653
successfully unlocked LG KG 290
Here is the Log...
COM5 [VCP2] selected
Device: LG KG290
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 357456******x
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601340508 2_LG KG290_20080127-043607.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 50 sec
Remove/Install battery now !
Old 01-26-2008, 13:57   #2 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
HWK does it in 00:00 SECOND.
TESTED ON 15 PIECES IN ONE DAY.
Old 01-26-2008, 22:21   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@blaiseid
sure, next time we will write -1 sec operation time (I think it's better than 0 sec because for sure 0 sec is false time), hope you will be more satisfied in this "time mashine".
btw, here is Infinity-Box support forum. Should I delete offtopic messages from Infinity-Box support forum or not ? Please, advice...
Old 01-27-2008, 09:32   #4 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
Originally Posted by InfinitySupport View Post
@blaiseid
Ofcourse, deleting of topic posts is adviced.
O second sound false in terms of timing matters.
sorry for my wrong sub-forum post.
Delete.
Old 01-27-2008, 09:38   #5 (permalink)
Member: 280594
Thanks Meter: 21
thanks for the info...
Old 02-05-2008, 08:22   #6 (permalink)
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
Thanks Meter: 265
COM6 [VCP0] selected
Device: LG KG290
Action: unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 357456013354249
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601335424 9_LG KG290_20080205-121818.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
error: wrong answer[C5]
Finished, time used: 131 sec
UNLOCK DONE..........................thanx infinity team
Old 02-06-2008, 07:04   #7 (permalink)
Member: 130995
Thank you very much for good test report !
Old 02-27-2008, 09:48   #8 (permalink)
Member: 213172
Sonork: 1582799
Thanks Meter: 265
today i try to unlock Kg290 with my ULT-Pro..but Set is still locked.after that i try with Infinity and my set become Unlocked.
thanx infinity Team........
problem whit lg kg 290 raltelefonica Infinity-Box 17 03-02-2009 14:42
halp me i need lg kg 290 usb Driver asgharali LG 0 10-19-2008 15:29
lg kg 290 lcd lights daanish LG 0 09-05-2008 13:33
LG kg 290 flash need HELPPPP maniek27 LG 0 09-01-2008 15:59
LG kg 290 keypad shoaib_sweet75 LG 1 06-22-2008 08:31
Page generated in 0.18478 seconds with 9 queries
