Old 09-30-2017, 08:38   #45241 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Jazzx js1 clear frp lock done by cm2
JAZZX JS1 CLEAR FRP LOCK DONE BY CM2
Read Phone Info
Format/Reset Settings
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 700100454838434434012618398D53F7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 4DC8H
[eMMC] : FLASH_CID : 700100454838434434012618398D53F7
[eMMC] : FLASH_LEN : 0x00000001C8000000
[eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB]
DEV RID : 0xB9E2EB779A43DC324FC37D25B4C94077
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : JazzX
ProdName : JS1
ProdModel : JS1
Device : JS1
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_VANZO6580.WEG.L_P50
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P6_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 960x540
TOUCH [0] : GT1XX
CAM [0] : gc0310_yuv
CAM [1] : imx179_mipi_raw
CAM [2] : ov5670_mipi_raw
MODEM : mt6580_demo_hspa_default
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:07
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:18
ShahiD
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 09-30-2017, 14:57   #45242 (permalink)
Member: 1677653
Thanks Meter: 2,769
TECNO T350 FORMAT DONE BY CM2
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 91 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : FD8CD063882B9A4736849C6CC782A177
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info   : DL180_T350_PCB01_gprs_MT6261_S00.T350-DL180-20160824.bin
FileVersion : T350-DL180-20160824
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 91 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003A5000-0x003FFFFF , LEN : 0x0005B000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:09
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 09-30-2017, 15:01   #45243 (permalink)
Member: 1677653
Thanks Meter: 2,769
TECNO T660 RESET USERCODE & READ FLASH DONE BY CM2
Wait for phone...
Phone found! [ 91 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 37916AFBB706CB88FB637E94AB26B186
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
EXT_RAM : 0x00800000
File_Info   : UL252_T660_TECNO_PCB01_gprs_MT6260_S00.T660UL252G1-AF-170214V6.bin
FileVersion : T660UL252G1-AF-170214V6
Done!
Elapsed: 00:00:09
Operation : Reset UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 91 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:34
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 91 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 16777216 bytes read
Check and collect compile info
Saved to : C:\InfinityBox\CM2MTK\Read_out\UL252_T660_TECNO_PCB01_gprs_MT6260_S00.T660UL252G1-AF-170214V6.bin
Done!
Elapsed: 00:00:53
Old 09-30-2017, 16:48   #45244 (permalink)
Member: 1677653
Thanks Meter: 2,769
TECNO DroiPad7C PRO [READ INFO & READ FLASH] DONE BY CM2 (OTHER TOOL FAILED, PHONE ONLY CHARGING)
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 8801034E43617264204385D33C56932D
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E43617264204385D33C56932D
[eMMC] : FLASH_LEN : 0x000000039D000000
[eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB]
DEV RID    : 0xDEC55C37C86A54437923823B1EE8B405
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Brand     : TECNO
ProdName  : DroiPad7
ProdModel : DP7CPRO
Device    : DP7CPRO
AndroidVer: 5.1
MTKxCPU   : MT6580
MTKxPRJ   : DP7CPRO-KC07T-B2-L-20161020
SECURITY :
IMEI_SW [1] : 355489075882486
IMEI_SW [2] : 355489075882494
BTMAC Addr  : D47DFC067793
WiFi MAC    : D47DFC069E3F
MODEM :
BaseBand  : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P3_1_wg_n
EXTRA :
LCD : Not info available :(
LCD Res : 1024x600
TOUCH [0] : GT9XXTB_hotknot
CAM [0] : gc2755_mipi_raw
CAM [1] : gc2756_mipi_raw
MODEM : rlk8321_tb_sr_l_hspa_b1b8_open_edge
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
xGPT : Normalize settings Ok!
Brand     : TECNO
ProdName  : DroiPad7
ProdModel : DP7CPRO
Device    : DP7CPRO
AndroidVer: 5.1
MTKxCPU   : MT6580
[Read Ok] : preloader_rlk8321_tb_sr_l.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / rlk8321_tb_sr_l / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2374 MiB
Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6580__TECNO__DP7CPRO__DP7CPRO__5.1__DP7CPRO-KC07T-B2-L-20161020\
All done!
Done!
Elapsed: 00:14:10
Old 10-01-2017, 08:41   #45245 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Lava r1 hang on logo done by cm2
LAVA R1 HANG ON LOGO DONE BY CM2
Read Phone Info
Read Firmware
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 484A019061344741C52FA4326133CD3C
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132A42FC53CCDC361
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77072EAE5CF2B9F2EF93A131A5
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : Lava
ProdName : LAVA_R1
ProdModel : LAVA_R1
Device : LAVA_R1
AndroidVer: 6.0
MTKxCPU : MT6737M
MTKxPRJ : alps-mp-m0.mp1-V2.84_lava6737m.65.m0_P5
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V88_P38_1_lwg _n
EXTRA :
LCD Res : 1280x720
CAM [0] : STOM_HAL_IMGSENSOR
CAM [1] : =s5k3h7y_darling_mipi_raw
CAM [2] : s5k3h7y_mxns_mipi_raw
CAM [3] : s5k3h7y_sunwin_mipi_raw
CAM [4] : ov5648_darling_mipi_raw
CAM [5] : ov5648_mcnex_mipi_raw
CAM [6] : ov5648_sunwin_mipi_raw
MODEM : STOM_MODEM=lava37_sp504_lwg_dsds_cotsx_indonesia_t hai
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:46
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Lava
ProdName : LAVA_R1
ProdModel : LAVA_R1
Device : LAVA_R1
AndroidVer: 6.0
MTKxCPU : MT6737M
[Read Ok] : preloader_lava6737m_sp504_int.bin
[Read Ok] : lk.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[ScatCFG] : MT6737M / V1.1.2 / lava6737m_sp504_int / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 3960 MiB
Scatter saved to : D:\ANDROID\Qmobile Android Files\Lenovo\lawa\MT6737M__Lava__LAVA_R1__LAVA_R1_ _6.0__alps-mp-m0.mp1-V2.84_lava6737m.65.m0_P5\
All done!
Done!
Elapsed: 00:08:25
If You Like My Post Press Thanks
ShahiD
Old 10-01-2017, 08:45   #45246 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Qmobile x900 hang on logo done by cm2
QMOBILE X900 HANG ON LOGO DONE BY CM2
Read Phone Info
ShahiD
Old 10-01-2017, 08:53   #45247 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Smile Huawei y360-u60 hang on logo done by cm2
HUAWEI Y360-U60 HANG ON LOGO DONE BY CM2
Read Phone Info
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A483447326111024239BA6D235B
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111024239BA6D235B
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xB9E2EB77DE7D85D971F1F07B936CA349
SOC VERIFY : C1
Boot Ok!
Brand : HUAWEI
ProdName : Y360-U61
ProdModel : HUAWEI Y360-U61
Device : HWY360-U
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P43_1_wg_n
EXTRA :
LCD [0] : nt35512_wvga_dsi_vdo
LCD [1] : hx8379c_wvga_dsi_vdo ili9806e_dsi_vdo
LCD Res : 800x480
TOUCH [0] : GT1143
TOUCH [1] : MSG2138
TOUCH [2] : ft6336
CAM [0] : gc2355_mipi_raw
CAM [1] : ov2680_mipi_raw
CAM [2] : ov2680_mipi_raw_yiweili
CAM [3] : ov5670_mipi_raw
CAM [4] : hi551_mipi_raw
CAM [5] : ov5670_mipi_raw_yiweili
MODEM : wingtech82_wet_82kk_hspa_wt_pa_sky77590_band18_std _98360c1
LOCALE : es_US en_US zh_CN pt_BR es_ES pt_PT fr_FR de_DE ru_RU it_IT zh_HK zh_TW sv_SE nb_NO da_DK cs_CZ hu_HU sk_SK pl_PL ro_RO el_GR sr_RS mk_MK bg_BG fi_FI et_EE lv_LV lt_LT sl_SI hr_HR uk_UA tr_TR vi_VN in_ID ar_EG nl_NL th_TH ms_MY ca_ES hi_IN en_GB my_MM ko_KR bs_BA mk_MK fa_IR
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:18
ShahiD
Old 10-01-2017, 10:33   #45248 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
5Star Z-22 MT6572 Pattern Read,Formate,Factory Rom Read Done
Read pattern Lock :
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 7001004D4D43303447581F685D4652CB
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447581F685D4652CB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E6800000
[eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB]
DEV RID : 0xCF93229E53A16E06B6657706C8BF59AF
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 457683219
Done!
Elapsed: 00:00:18
Read Factory ROM :
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : alps
ProdName : Z-22
ProdModel : Z-22
Device : d37f2
AndroidVer: 6.0
MTKxCPU : MT6572
MTKxPRJ : D37F2_YBZ_Z_22_5STAR_EMMC4_32_M20_20170412_2006
[Read Ok] : preloader_d37f2.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[ScatCFG] : MT6572 / V1.1.1 / d37f2 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 777 MiB
Scatter saved to : C:\Users\MHT\Desktop\MT6572__alps__Z-22__d37f2__6.0__D37F2_YBZ_Z_22_5STAR_EMMC4_32_M20_ 20170412_2006\
All done!
Done!
Elapsed: 00:05:43
Format Done :
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:27
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Old 10-01-2017, 11:58   #45249 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Note_5_copy_MT6572_Flash Done Infinity CM2
MT6572__alps__Sony_Xperia_Z3__rtech72_we_72_kk__4. 4.2__ALPS.KK1.MP6.V1
Scatter Load Ok , BaseBand : MT6572 , Project : rtech72_we_72_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : alps
Device Model : rtech72_we_72_kk
Device CPU : MT6572
Device IntName : rtech72_we_72_kk
Device Version : 4.4.2
Device Compile : 19/4/2016 5:28:06
Device Project : ALPS.KK1.MP6.V1
Device ExtInfo : Sony Xperia Z3
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 110100303034473930518B8B17B8B05F
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 110100303034473930518B8B17B8B05F
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xCF93229EF790949EE00A15B7A0F63A35
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : rtech72_we_72_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3682 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E8680000
Flash Pre-Erase Done, time used : 00:00:05
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0013
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:27
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:01:30
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:16
Old 10-01-2017, 14:05   #45250 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
WALTON Primo V2 MSM8912 5.0.2 Hang On Logo Done By CM2
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : WALTON
Device Manufact.: WALTON
Device Model : q39
Device CPU : MSM8916
Device IntName : Primo_V2
Device Version : 5.0.2
CU_SWVer : WALTON
Device Compile : 12/22/2015 6:03:03 AM
Device ExtInfo : Primo V2
Load Ok!
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 610 [MSM8936]
ID_BLOCK_S : 02696B74
ID_BLOCK_I : 0090B0E1
ID_BLOCK_L : 71F3E915C02E5B563166EEF7300B8BC3
ID_BLOCK_L : 2053FD4C41D07A8B0EE9A21B698492B9
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Flash Chain : 31
Flashing now
Flashing : gpt_main0.bin
Flashing : NON-HLOS.bin
Flashing : sec.dat
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : system.img
Flashing : persist.img
Flashing : cache.img
Flashing : misc.img
Flashing : splash.img
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:07:38
Old 10-02-2017, 06:19   #45251 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I5i MT6582 FRP Read Done With King Infinity CM2
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040506A2198EC121
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040506A2198EC121
DEV RID : 0xD9C8F395EEF2BB58BCE1184076939276
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 45689
Done!
Elapsed: 00:00:11
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 10-02-2017, 07:50   #45252 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
OPPO F1s PATTERN READ DONE WITH INFINITY CM2MTK:-
READ INFO
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
SecCfgVal : 0x01000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D420792AAACDAA343
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID    : 0x5800154457356A34F0FC96326C195316
INT RAM    : 0x00000000
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
Brand     : OPPO
ProdName  : A1601
ProdModel : A1601
Device    : A1601
AndroidVer: 5.1
MTKxCPU   : MT6755
MTKxPRJ   : A1601EX_11_A.33_170814
SECURITY :
IMEI_SW [1] : 8637950xxxxxxxx
IMEI_SW [2] : 8637950xxxxxxxx
BTMAC Addr  : C09F00000000
WiFi MAC    : C09F00000000
EXTRA :
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov8865_mipi_raw
CAM [3] :  s5k3p3sp_mipi_raw
MODEM : oppo6750_15331_lwg
Done!
Elapsed: 00:00:20
READ PATTERN
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
USBDL : Init HSUSB Ok
Reading data ...
Get Locks ...
PatternLock Sequnce : 245683
Done!
Elapsed: 00:00:26
WBR
sahil2000ind
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post:
Old 10-02-2017, 08:13   #45253 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Panasonic T50 MT6582 FRP Reset Done With Hero Infinity CM2
Card found : S/N : A19EC787 , v0136
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100463732324D4200B55DC2764323
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200B55DC2764323
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F39504F4F8ED40EF9C71D053D0B2
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:10
Old 10-02-2017, 08:15   #45254 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Samsung ORG E1207Y(ABCD)(EFGH)Fail ,Done Only Infinity CM2
ard found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6530_SPD6500
Operation : Read User Code [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 132 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Check data... Can take some time
User Code : 1516
Done!
Elapsed: 00:00:22
Old 10-02-2017, 08:16   #45255 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Oppo A37f QLM Pattren Read Dne With King Infinity CM2
Card found : A19EC787 , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Read PatternLock [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 25A0E7E5
ID_BLOCK_I : 007050E1
ID_BLOCK_L : E202788631BDAAA582F71906C1981830
ID_BLOCK_L : 7B0AB417188B33B055A0F52220CFD9E2
Use CM2 Internal Loader
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 158963
Done!
Elapsed: 00:00:21
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 1.00031 seconds with 10 queries
