06-07-2018, 09:22 | #50041 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Bardibas Age: 31
Member: 2670396 Status: Offline Thanks Meter: 125 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D4201D7AACE5954D5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4201D7AACE5954D5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x444A22FC6339A8EA3B268F63B82A0524 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Itel ProdName : I805 ProdModel : itel S12 Device : itel-S12 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : S12-I805-7.0-OP-V041-20180203 [Read Ok] : preloader_s12.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / s12 / EMMC Android Info saved HWConfig Info saved FW Size : 2873 MiB Scatter saved to : C:\Users\GSM-Abinash\Desktop\New folder\MT6580__Itel__itel_S12__itel-S12__7.0__S12-I805-7.0-OP-V041-20180203\ All done! Done! Elapsed: 00:16:31 Reconnect Power/Cable! |
06-07-2018, 10:47 | #50042 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 132 | Oppo F7 Done by Infinity Oppo F7 Stuck or restar after Force format just do this... Step by step 1. follow this step right here Code: http://forum.gsmhosting.com/vbb/f296/oppo-f7-after-format-user-then-reboot-only-pls-help-2416113/ IF STILL NO LUCK 2. Try do format it again with our lovely dongle Code: Operation : Reset Settings/Format FS [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100444836444D420591129026B40F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 767A7A45443238B2A94BABEA3E82B7BB DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:28 3. IF DEVICE HAS BOOT NORMALLY JUST DO FACTORY RESET ON PHONE |
The Following 3 Users Say Thank You to anoamocreative For This Useful Post: |
06-07-2018, 10:54 | #50043 (permalink) |
Member: 2670396 Status: Offline Thanks Meter: 125 | MT6737M__Itel__itel_S41__itel_S41__7.0__S41-I373-7.0-OP-V049-20180403_Firmware_Read_Done_With_CM2_BY_GSM_Abinas h Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447417132A53245155468 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A5327168549445 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x444A22FC0D299427B961C74E8CA50F98 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Itel ProdName : S41 ProdModel : itel S41 Device : itel_S41 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : S41-I373-7.0-OP-V049-20180403 [Read Ok] : preloader_rlk6737m_35_i_n.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / rlk6737m_35_i_n / EMMC Android Info saved HWConfig Info saved FW Size : 2868 MiB Scatter saved to : C:\Users\GSM-Abinash\Desktop\New folder\MT6737M__Itel__itel_S41__itel_S41__7.0__S41-I373-7.0-OP-V049-20180403\ All done! Done! Elapsed: 00:11:38 Reconnect Power/Cable! |
06-07-2018, 11:15 | #50044 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile LT700 PRO MT6735 FRP Reset Done With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 193 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423145631207428D1D76E0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D42071263E076638D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395F44E780983C5AB1BC47C2D3B INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
06-07-2018, 12:15 | #50045 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X700 Pro Lite MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some , Remove battery , Insert back 2. Insert USB cable. Ie cases require hold BootKey Wait for phone... Phone found! [ 193 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050732C1A08DC34F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050732C1A08DC34F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3954C2378CA28F585DF59056116 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
06-07-2018, 13:15 | #50046 (permalink) |
Insane Poster Join Date: Oct 2011 Location: Karnataka.bangalore
Member: 1681098 Status: Offline Sonork: mahindra Thanks Meter: 74 | panasonic p101 frp done with cm2 panasonic p101 frp done with cm2 Card found : BA145A3D , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Operation : Reset Settings/Format FS [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM33) MODE : PRELOADER PORT PORT : 33 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : BQ : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514536334D4203DF23E0D2C473 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 102C196C417E56B334F8E2ED24FF77 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
06-07-2018, 13:29 | #50047 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Micromax Q4310 FRP done ;) Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 52000115414231334A09064263175DA8 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0xC0000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BAB13 [eMMC] : FLASH_CID : 15010052333142414206094AA85D7363 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7E5F53DC90C98216EA7E659549C23F30 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Q4310 ProdModel : Micromax Q4310 Device : Q4310 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_miki6737m.35.n_P60 SECURITY : IMEI_SW [1] : 91xxxxxxxxxxxxx IMEI_SW [2] : 91xxxxxxxxxxxxx BTMAC Addr : 000CE8B89EF3 WiFi MAC : 000CE837306C Done! Elapsed: 00:00:19 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 52000115414231334A09064263175DA8 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0xC0000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BAB13 [eMMC] : FLASH_CID : 15010052333142414206094AA85D7363 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7E5F53DC90C98216EA7E659549C23F30 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
06-07-2018, 14:20 | #50048 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO A6010 SnapDragon 410 [MSM8916] FLASH & RECOVER HANG ON LOGO Done SUCCESSFULLY FLASH AND RECOVER HANG ON LOGO(LENOVO A6010 SnapDragon 410 [MSM8916] )USB THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
06-07-2018, 14:28 | #50049 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MI REDMI NOTE 4 SnapDragon 625 [MSM8953] PATTERN LOCK & MI ACCOUNT REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK & MI ACCOUNT(MI REDMI NOTE 4 SnapDragon 625 [MSM8953])USB THANKS INFINITY-BOX TEAM |
06-07-2018, 14:40 | #50050 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | INFOCUS M370 SnapDragon 210 [MSM8x09] FRP REMOVE Done SUCCESSFULLY REMOVE FRP(FOCUS M370 SnapDragon 210 [MSM8x09])USB THANKS INFINITY-BOX TEAM |
06-07-2018, 14:51 | #50051 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V7 PLUS 1716 PD1708F_EX SnapDragon 625 [MSM8953] PATTERN LOCK & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK & FRP(VIVO V7 PLUS 1716 PD1708F_EX SnapDragon 625 [MSM8953])USB THANKS INFINITY-BOX TEAM |
06-07-2018, 14:58 | #50052 (permalink) |
Junior Member Join Date: Nov 2017 Location: cagayan de oro city
Member: 2779784 Status: Offline Thanks Meter: 0 | thanks infinity team i have solve a lot of chinese phones here in our country philippines pattern passcode and frp solve in easy operation using cm2 infinity dongle...once again thanks and more power... |
06-07-2018, 15:05 | #50053 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A37F SnapDragon 410 [MSM8916] PATTERN LOCK & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK & FRP(OPPO A37F SnapDragon 410 [MSM8916])USB THANKS INFINITY-BOX TEAM |
06-07-2018, 15:36 | #50054 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO R831K FLASH AND RECOVER BLUE LIGHT AND VIBRATE ONLY Done SUCCESSFULLY FLASH AND RECOVER BLUE LIGHT AND VIBRATE(OPPO R831K)USB THANKS INFINITY-BOX TEAM |
06-07-2018, 15:47 | #50055 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | GIONEE P5L MT6735 PATTERN LOCK & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK & FRP(GIONEE P5L MT6735)USB THANKS INFINITY-BOX TEAM |
