02-24-2019, 09:01 | #57121 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Hero H4 2SCR SPD Call Log Not Show Fix Only Formate With Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_145 FBDE74DA5_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
02-24-2019, 09:09 | #57122 (permalink) |
No Life Poster Join Date: Jun 2008 Location: india
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Motorola XT-1706 frp reset done,,,,,,, Card found : S/N : 12B60F38 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32FA021052A56CB04D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A3936521002FA4DB0A3A5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x6AE03B2A4A069613BD0443E5C93EE2B2 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to chandan_123 For This Useful Post: |
02-24-2019, 10:53 | #57123 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile m95 hang on logo done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Update NVM image : nvitem.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Update NVM image : nvitem_wcn.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:04:19 Reconnect Power/Cable! |
02-24-2019, 10:57 | #57124 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile d3 illegul use error done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
02-24-2019, 12:06 | #57125 (permalink) |
No Life Poster Join Date: May 2007 Location: Indore
Member: 506648 Status: Offline Sonork: 100.1614254 Thanks Meter: 702 | Seatel V8A Frp Reset | Phone Lock Reset by Infinity CM2 Dongle Seatel V8A Frp Reset | Phone Lock Reset by Infinity CM2 Dongle Thanks To Infinity Team |
The Following User Says Thank You to Ankit Verma For This Useful Post: |
02-24-2019, 12:54 | #57127 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Max T101 SPD 2SCR Logo Stuck Fix Only Formate With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chnese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REiV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_008 E81CB5A01_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
02-24-2019, 13:38 | #57128 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | TECNO WX4 Pro Format / Remove FRP Lock Done :) Code: Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 7001004548414345410118CB43BCEF67 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548414345410118CB43BCA467 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x390000000 [ 14.25 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6A7D9DDD208D21191826874EBC350ADC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : WX4Pro-H3712A-N-180302V99 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-02-05 Build Time : 1519965867 Product Model : TECNO WX4 Pro Product Brand : TECNO Product Name : H3712 Product Device : TECNO-WX4-Pro Product Manfct : TECNO Board Platform : mt6737m Product Info : TECNO-WX4-Pro USERDATA : ENCRYPTED IMEI[0] : 3572020821332xx IMEI[1] : 3572020821332xx NVRAM check : Passed! Backup sensetive data [ 10 ] Backup path : Backup\MT6735__6A7D9DDD208D21191826874EBC350ADC\ [3] Read : NVRAM [19] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! Done! Elapsed: 00:00:29 Code: Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 7001004548414345410118CB43BCEF67 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548414345410118CB43BCA467 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x390000000 [ 14.25 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6A7D9DDD208D21191826874EBC350ADC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
02-24-2019, 14:07 | #57129 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile xl8 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 7155D9A00D5172C9C9B654AA1B0DED46 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
02-24-2019, 14:15 | #57130 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Huawei hol-u19 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473464040502A2A11932E9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d4GA [eMMC] : FLASH_CID : 90014A4841473464040502A2A11932E9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0CF2E6DE42C45AE13944CE998B9C37CC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:48 Reconnect Power/Cable |
02-24-2019, 16:14 | #57131 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | HUAWEI CUN L21 Remove FRP Lock Done :) Code: Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : Y5II [ CUN-Lxx ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847316505074FC7DAFDBF35 DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074FC7DAFD5335 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D231BCBEEA54D61BF5E556FF90FC1D STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : HUAWEI Display ID : CUN-L21C578B126 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2017-12-01 Build Time : 1514319622 Product Model : CUN-L21 Product Brand : HUAWEI Product Name : CUN-L21 Product Device : CUN-L21 Product Board : CUN-L21 Product Manfct : HUAWEI Board Platform : mt6735 Product Info : hq6735_35u_b1n_l1 USERDATA : PLAIN ( NOT encrypted ) IMEI[0] : 86048403548x8xx IMEI[1] : 86048403550x8xx NVRAM check : Passed! Backup sensetive data [ 10 ] Backup path : Backup\MT6735__D231BCBEEA54D61B0F5E556F0F90FC1D\ [3] Read : NVRAM [21] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! Done! Elapsed: 00:00:29 Code: Operation : Memory Tool Init [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : Y5II [ CUN-Lxx ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847316505074FC7DAFDBF35 DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074FC7DAFD5335 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D231BCBEEA54D61BF5E556FF90FC1D STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP Erase partition Ok! Operation finished! Change global setting Init memory tool Erase frp partition |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
02-24-2019, 16:42 | #57132 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo CPH1729 A83 MT6763 FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : F957F9E79A938BE2C16FECCEA0C3DEB8AE4ACCCDB94F8015AC B84E2B9B4FC515 BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A54335EA81C43F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9E674A7A36EB3F72F17F015DD6DAAFCE DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
02-24-2019, 20:37 | #57133 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Canada Age: 44
Member: 169896 Status: Offline Thanks Meter: 323 | Quote: Sent from my SM-G965W using Tapatalk |
02-25-2019, 06:25 | #57134 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931121 Status: Offline Thanks Meter: 100 | sm g531f frp done by infinity box Phone In Download mode... Samsung module version 2.05 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing boot.img Flashing done Reboot phone... Phone found on COM32 Phone In Download mode... Phone Disconnected Phone found on COM33 Read Info... Read Info - ok Samsung module version 2.05 Connect ADB - Ok Reset FRP/ REACTIVATION LOCK - Done Reboot Phone... Phone Disconnected |
The Following User Says Thank You to moniuzzaman For This Useful Post: |
02-25-2019, 06:36 | #57135 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile t250 reset pattern done by cm2 Card found: S/N : 73CA70CC , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000017B0FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
