04-25-2019, 09:00 | #58306 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Pakistan
Member: 1489718 Status: Offline Sonork: 100.1652829 QQ 3237590752 Thanks Meter: 1,495 | LAVA__iris80__7.0 flash done with cm2mt2 Code: Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :11 [FL] : Set : preloader_lava6737m_sp80_gmo.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x76F37B28 [ 1.86 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A483847346132A52135040401E3 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A0190613447383521A532E3010404 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_lava6737m_sp80_gmo.bin EMI : CNT : 0002 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : PRELOADER_INFO [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A5213540434E3 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 181A4BE557316250D8CF03DCBBC80A0B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM27) MODE : PRELOADER PORT PORT : 27 Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x41414642393735303841323644334432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x00000001CF300000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x41414642393735303841323644334432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:32 Reconnect Power/Cable! |
The Following User Says Thank You to YMS-RYK For This Useful Post: |
04-25-2019, 09:11 | #58307 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Qmobile LT550 SPD 9832 FRP Unlock Done By 1 Click With CM2 Qmobile LT550 SPD 9832 FRP Unlock Done By 1 Click With CM2 Here are Logs Youtube Link https://www.youtube.com/watch?v=ukxZicrYmoY |
The Following User Says Thank You to umarnlw For This Useful Post: |
04-25-2019, 10:44 | #58308 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Nigeria
Member: 974244 Status: Offline Thanks Meter: 50 | infinix x510 format done by cm2 Card found : E3B1B8F3 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Mobistel PreLoader USB VCOM Port (COM142) MODE : PRELOADER PORT PORT : 142 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 5100011541535838044206420592A6F2 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513858534142064204F2A69205 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q8XSAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 13073C203F6B92630B8DE562CE465EE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATAa Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
04-25-2019, 10:58 | #58309 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Infinix X559C Remove FRP Lock Done :) Code: Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM190) MODE : PRELOADER PORT PORT : 190 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D33364598310342A5A4E796 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D4203319896E7A4A5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 861BCDFFF6D7F72927CA3D743977F22C STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : X559-H8015C-N-170818V89 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-08-05 Build Time : 1503051304 Product Model : Infinix X559C Product Brand : Infinix Product Device : Infinix-X559C Product Name : H8015 Product Manfct : Infinix Board Platform : mt6580 Product Info : Infinix-X559 USERDATA : PLAIN ( NOT encrypted ) IMEI[0] : 353734092176723 IMEI[1] : 353734092176731 NVRAM check : Passed! Done! Elapsed: 00:00:25 Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM190) MODE : PRELOADER PORT PORT : 190 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D33364598310342A5A4E796 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D4203319896E7A4A5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 861BCDFFF6D7F72927CA3D743977F22C STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
04-25-2019, 11:48 | #58310 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X609 Flash Code: Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32364563DD0342F1B578CE DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203DD63CE78B5F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 67E29D00833D4B075235FE1410669CFA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : X609-H8025AB-GO-181227V149 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 1545860850 Product Brand : Infinix Product Name : H8025 Product Device : Infinix-X609 Product Info : Infinix-X609 Product Model : Infinix X609 Product Manfct : INFINIX MOBILITY LIMITED Product Board : Infinix-X609 Board Platform : mt6580 USERDATA : ENCRYPTED Done! Elapsed: 00:00:43 Preloader [HW DEV] Info : EMI : DEV : MT6580 EMI : SRC : preloader_bsp_h8025.bin EMI : CNT : 000A EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR2 , ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR2 , ID : ADDE14A7424AAD : VEN : UNKNOWN | DEV : §BJ* : RAM : [ 512.00 MB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 700100454841454538 : VEN : KINGSTON | DEV : EHAEE8 : RAM : [ 1.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 700100454838454434 : VEN : KINGSTON | DEV : EH8ED4 : RAM : [ 512.00 MB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 700100454838434434 : VEN : KINGSTON | DEV : EH8CD4 : RAM : [ 512.00 MB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :14 [FL] : Set : preloader_bsp_h8025.bin [FL] : Set : lk-sign.img [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : secro-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x5992F38C [ 1.40 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32364563DD0342F1B578CE DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D4203DD63CE78B5F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 67E29D00833D4B075235FE1410669CFA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000004C80000 : 0x00000000F0B80000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : LK2 SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : ODMDTBO SecInit : VENDOR SecInit : TEE1 SecInit : TEE2 SecInit : SECRO SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : LK2 Write : BOOT Write : RECOVERY Write : LOGO Write : ODMDTBO Write : VENDOR Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : WRITE INFO : OK SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:53 Reconnect Power/Cable! |
04-25-2019, 12:29 | #58311 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Peace Age: 27
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 245 | Lenovo P1ma40 FRP Remove Done by CM2MTK :) Read Info Code: Card found : S/N : 25C99553 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132382BED00425B134DE0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200ED2BE04D325B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x5D9FA1414402CB1C9EB330727261934F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : P1ma40 ProdModel : Lenovo P1ma40 Device : P1ma40 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : P1ma40_USR_S040_1701061530_MP3V2_16G_ROW_US SECURITY : IMEI_SW [1] : 355105149------ IMEI_SW [2] : 355105149------ BTMAC Addr : 000046033501 WiFi MAC : 000000000000 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P3_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : FT5446 CAM [0] : ov8865_mipi_raw CAM [1] : ov8865_mipi_raw_sunny CAM [2] : hi551_mipi_raw CAM [3] : hi551avc_mipi_raw MODEM : wingtech5335_lte_l_lwg_dsds_wt_pa_sky77643_98735a LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:21 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132382BED00425B134DE0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200ED2BE04D325B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x5D9FA1414402CB1C9EB330727261934F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
04-25-2019, 13:50 | #58312 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | L-MK Ester 2 MT6580 Privacey Code Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838454538011DF4AECEC3FF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EE8H [eMMC] : FLASH_CID : 700100454838454538011DF4AECEC3FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395D73A7905A693713BD4E60971 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
04-25-2019, 14:18 | #58313 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Huawei mya l22 reset frp done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33314553B30D421DB7DDF2 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:56 Reconnect Power/Cable! |
04-25-2019, 14:27 | #58314 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6i hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobile Device CPU : MT6580 Device IntName : QMobile i6i Device Version : 5.1 Device Compile : 6/20/2016 2:31:53 PM Device Project : ALPS.L1.MP6.V2_TINNO6580.WE.L Device ExtInfo : QMobile i6i Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D4202F527683683DD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D4202F527683683DD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB9E2EB775AA2E483E18AC5FAAACB5D1F INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3599 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000000E6300000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5030.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:04 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:27 Reconnect Power/Cable! |
04-25-2019, 14:28 | #58315 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | DOOGEE X11 read firmware done [CODEOperation : Read Firmware [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM41) MODE : PRELOADER PORT PORT : 41 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1836 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 45000170454538482A180138C765A3A1 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 70010045483845453801182AA1A365C7 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8EE8 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1C8000000 [ 7,13 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8A48FE55150E609E635236E9328C57A3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-08-05 Build Time : 1537253149 Product Model : X11 Product Brand : DOOGEE Product Name : X11 Product Device : X11 Product Manfct : DOOGEE Product Info : k80_bsp Product Board : k80_bsp Board Platform : mt6580 MT6580__DOOGEE__X11__8.1.0__O11019__O11019__k80_bs p SecureDevice : Plain Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : odmdtbo.img Read : vendor.img ExtSparse : Compression ratio : 71% Read : tz.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 14% Read : cache.img Read : userdata.img Read : sdrpmb.img FW Size : 1,39 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : G:\DOOGEE\MT6580__DOOGEE__X11__8.1.0__O11019__O110 19__k80_bsp\ Done! Elapsed: 00:06:02 ][/CODE] |
04-25-2019, 14:31 | #58316 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile 350 pro reset frp done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513832334D42002229D892B381 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42002229D892B381 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB9E2EB7705F589B5DD9917681B98A934 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
04-25-2019, 14:38 | #58317 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile energy x1 reset frp done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050755A1195D1401 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050755A1195D1401 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB9E2EB7713D089F696C246D12F7F8C6A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
04-25-2019, 14:41 | #58318 (permalink) |
Member: 974244 Status: Offline Thanks Meter: 50 | infinix x559c 16+2 frp done by cm2 Card found : E3B1B8F3 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 Load IDBase v123080 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Mobistel PreLoader USB VCOM Port (COM142) MODE : PRELOADER PORT PORT : 142 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D3336456AC403420145A8CC DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D4203C46ACCA84501 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1CBD79412DDFBE2B2F710BBBDF3DD637 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Read Firmware [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Mobistel PreLoader USB VCOM Port (COM142) MODE : PRELOADER PORT PORT : 142 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D3336456AC403420145A8CC DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D4203C46ACCA84501 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1CBD79412DDFBE2B2F710BBBDF3DD637 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : X559-H8015C-N-180605V132 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-05-05 Build Time : 1528171905 Product Model : Infinix X559C Product Brand : Infinix Product Device : Infinix-X559C Product Name : H8015 Product Manfct : Infinix Board Platform : mt6580 Product Info : Infinix-X559 MT6580__Infinix__Infinix_X559C__7.0__X559-H8015C-N-180605V132__NRD90M__Infinix-X559 SecureDevice : Plain Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : system.img Read : cache.img Read : userdata.img FW Size : 4.04 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : C:\Users\princejt\Desktop\vol music\CM2\MT6580__Infinix__Infinix_X559C__7.0__X55 9-H8015C-N-180605V132__NRD90M__Infinix-X559\ Done! Elapsed: 00:15:44 |
04-25-2019, 14:42 | #58319 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile g3 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : A0BD58E88BD7206E764AF7F016F6882A BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
04-25-2019, 14:45 | #58320 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile power 700 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 92D6238C6867FBE7A90B0F3CDF7C47A5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
