10-01-2019, 06:13 | #60616 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Jazz T1000 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7C0100454D533030383A0F0C0306C2AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x7C , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , 800SM [eMMC] : FLASH_CID : 7C0100454D533030383A0F0C0306C2AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001CCD80000 [eMMC] : FLASH_UCP : 7373 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3958D51C2140E979279DDAF5EE5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
10-01-2019, 06:58 | #60617 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera imeipk
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | i8i 2019 frp done Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:32 |
The Following User Says Thank You to ximasim For This Useful Post: |
10-01-2019, 06:59 | #60618 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Moto g 5 reset frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8937 CID : 0xDEAD IMEI : 000000000000000 UID : 0CC6731000000000000000000000 Model Info ============ DevModel : 000000000000000 IntName : cedric SW Info ============ DevSWVer : Blur_Version.25.281.12.cedric.retail.en.US DevQCVer : LA.UM.5.6.r1-01900-89xx.0 BaseBand : M8937_22.29.02.70t CEDRIC_LATAMDSDS_CUST BootLDRv : moto-msm8937-B8.24 HW Info ============ eMMCInfo : 32GB SKHYNIX HBG4a2 RV=08 PV=A4 FV=00000000000000A4 DRAMInfo : 2GB SKHYNIX LP3 DIE=8Gb M5=06 M6=03 M7=00 M8=1F Lock Info ============ WarrantyVoid : n/a FRP Lock : protection (77) Done! Elapsed: 00:00:06 Operation : Reset Settings [ v1.03 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:07 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! -- > Info : Wait till device boot, make "Enable ADB" operation after -- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"! Done! Elapsed: 00:00:07 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : 000000000000000 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : 000000000000000 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : 000000000000000 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:49 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : cedric Model : Moto G (5) FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:12 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:07 |
10-01-2019, 07:06 | #60619 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 3 reset pattern & frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Update Ok! Load IDBase v46104 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM55) MODE : PRELOADER PORT PORT : 55 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Nokia : Nokia 3 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_CRYPTO20.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132A54288B63E8FC9 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A54288B63E15C9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 235E82C0C96453431B51856B4CAFF7DC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : 00WW_5_120 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-05-05 Build Time : 1557915552 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Product Info : NE1 USERDATA : ENCRYPTED Done! Elapsed: 00:00:17 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM55) MODE : PRELOADER PORT PORT : 55 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Nokia : Nokia 3 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_CRYPTO20.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132A54288B63E8FC9 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A54288B63E15C9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 235E82C0C96453431B51856B4CAFF7DC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
10-01-2019, 07:16 | #60620 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | SHARP AQUOS M1 FRP Lock remove Done by cm2 Operation : Memory Tool Init [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM261) MODE : PRELOADER PORT PORT : 261 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1724 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484347386134A131251C49122F DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484347386134A131251C49932F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 96B5FFAEC6B0ECCAE6BC19BCD0273B9C STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM256) MODE : PRELOADER PORT PORT : 256 Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP Erase partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:02:39 |
The Following User Says Thank You to Manikanika81 For This Useful Post: |
10-01-2019, 11:21 | #60622 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile d7 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 2079D1AF525E10B15646D86840D96C41 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
10-01-2019, 11:25 | #60623 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Mione i7s plus hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Update Ok! Load IDBase v46104 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D53323838E10042FB524DCA DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100513832534D4200E138CA4D52FB NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832534D4200E138CA4D52FB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q82SMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7C8AA145362220874EC85BCC8F75A193 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM Port (COM50) MODE : PRELOADER PORT PORT : 50 Boot done! Patch Level : LMY47I Display ID : LMY47I test-keys Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-06-01 Build Time : 1503050510 Product Model : i7s Plus Product Brand : alps Product Name : i7s Plus Product Device : magc6580_we_l Product Manfct : alps Board Platform : mt6580 Product Info : magc6580_we_l USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:22 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D53323838E10042FB524DCA DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100513832534D4200E138CA4D52FB NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832534D4200E138CA4D52FB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q82SMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7C8AA145362220874EC85BCC8F75A193 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM Port (COM50) MODE : PRELOADER PORT PORT : 50 Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
10-01-2019, 11:29 | #60624 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo f1s reset frp done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Update Ok! Load IDBase v46104 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Preloader And Gadget Serial (COM26) MODE : PRELOADER PORT PORT : 26 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100525831344D42077C9090ACC3A5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX14MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1CBCE76F4A91FE27A198D0A1902F3171 DA : USB : HIGH-SPEED Boot done! Product Model : A1601 Product Brand : OPPO Product Name : A1601 Product Device : A1601 Product Board : full_oppo6750_15331 Product Info : oppo6750_15331 SW Version : A.28 SW OTA Version : A1601EX_11.A.28_INT_028_201702102025 SW OTA Name : A1601EX_11_A.28_170210 Display ID : A1601EX_11_A.28_170210 Kernel Info : 3.10.72-G201702102025 Product Model : A1601 Product Brand : OPPO Product Name : A1601 Product Device : A1601 Product Board : full_oppo6750_15331 Product Info : oppo6750_15331 SW Version : A.28 SW OTA Version : A1601EX_11.A.28_INT_028_201702102025 SW OTA Name : A1601EX_11_A.28_170210 Display ID : A1601EX_11_A.28_170210 Kernel Info : 3.10.72-G201702102025 Patch Level : LMY47I Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2017-02-05 Build Time : 1486731883 Product Manfct : OPPO Board Platform : mt6750 Product Model : A1601 Product Brand : OPPO Product Name : A1601 Product Device : A1601 Product Board : full_oppo6750_15331 Product Info : oppo6750_15331 SW Version : A.28 SW OTA Version : A1601EX_11.A.28_INT_028_201702102025 SW OTA Name : A1601EX_11_A.28_170210 Display ID : A1601EX_11_A.28_170210 Kernel Info : 3.10.72-G201702102025 USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:22 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Preloader And Gadget Serial (COM26) MODE : PRELOADER PORT PORT : 26 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100525831344D42077C9090ACC3A5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX14MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1CBCE76F4A91FE27A198D0A1902F3171 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
10-01-2019, 11:34 | #60625 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Telenor infinity a2 reset pattern done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Update Ok! Load IDBase v46104 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM26) MODE : PRELOADER PORT PORT : 26 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 450100444634303136018E4778421039 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444634303136018E4778425339 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 62F09DDFDB18A23035FBE1C4E2FFAED2 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : TELENOR-INFINITY-A2_L109 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-02-05 Build Time : 1491562966 Product Model : Infinity_a2 Product Brand : Telenor Product Name : b3680 Product Device : b3680 Product Board : full_b3680 Product Manfct : Dewav Board Platform : mt6737m Product Info : b3680 USERDATA : ENCRYPTED Done! Elapsed: 00:00:22 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM26) MODE : PRELOADER PORT PORT : 26 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 450100444634303136018E4778421039 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444634303136018E4778425339 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 62F09DDFDB18A23035FBE1C4E2FFAED2 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
10-01-2019, 13:57 | #60626 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | World first qmobile i6 metal 7731e reset frp dome by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2 Operation : Format FS / Reset Settings [ v2.00r2 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post: |
10-01-2019, 17:56 | #60627 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Tecno lc6 frp reset done Card found : A6936825 , v0138 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Socket Error # 11001 Host not found. Update failed! Check settings and/or internet connection! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 8801034439443136473821CA12576693 EMMC: VEN : FORESEE | OEM : 301 | DEV : D9D16G EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8966D01A355E2E3634A398B1A662661 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : LC6-H617CDE-PGo-190615V213 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-06-05 Build Time : 1560534920 Product Model : TECNO LC6 Product Brand : TECNO Product Name : H617 Product Device : TECNO-LC6 Product Manfct : TECNO MOBILE LIMITED Product Info : lc6_h617 Product Board : TECNO-LC6 Board Platform : mt6761 USERDATA : ENCRYPTED NVRAM check : Passed! Done! Elapsed: 00:00:36 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 8801034439443136473821CA12576693 EMMC: VEN : FORESEE | OEM : 301 | DEV : D9D16G EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8966D01A355E2E3634A398B1A662661 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Security [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 8801034439443136473821CA12576693 EMMC: VEN : FORESEE | OEM : 301 | DEV : D9D16G EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8966D01A355E2E3634A398B1A662661 DA : USB : HIGH-SPEED Boot done! NVRAM check : Passed! NVM saved as : MT6761__eMMC__.mt_sec NVM saved to : C:\Users\Yuslam Unique\Desktop\NV Backup\ Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
10-01-2019, 18:00 | #60628 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Tecno ka7o frp reset done Card found : A6936825 , v0138 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v46104 Ok! Update configuration ... Socket Error # 11001 Host not found. Update failed! Check settings and/or internet connection! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D3336457D6F03429F351506 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D42036F7D615359F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8ABBC6901B93801F162FF44C5C7E64FB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : KA7O-H8024DEFGH-O-190724V277 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-08-05 Build Time : 1563963529 Product Brand : TECNO Product Name : H8024 Product Device : TECNO-KA7-O Product Info : TECNO-KA7-O Product Model : TECNO KA7O Product Manfct : TECNO MOBILE LIMITED Board Platform : mt6580 USERDATA : ENCRYPTED IMEI[0] : XXXXXXXXXXXXXX IMEI[1] : XXXXXXXXXXXXXX NVRAM check : Passed! Done! Elapsed: 00:00:20 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D3336457D6F03429F351506 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D42036F7D615359F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8ABBC6901B93801F162FF44C5C7E64FB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-02-2019, 06:06 | #60629 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | LG Stylus 2 K520 FRP Reset Done By 1 Click With Infinity LGS LG Stylus 2 K520 FRP Reset Done By 1 Click With Infinity LGS Here are logs Youtube link https://www.youtube.com/watch?v=Y8ll...g14UHA&index=2 |
The Following User Says Thank You to umarnlw For This Useful Post: |
10-02-2019, 06:17 | #60630 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Oppo R17 Clone Welcome logo Only Done Via CM2 Oppo R17 Clone Welcome logo Only Done Via CM2 Logs Code: Card found : S/N : fertxter , v0138 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : aeon6580_weg_l_l200 , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A12FA0619D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A12FA0619D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x7A3C37BC861CE10C130B51311824C8D2 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : aeon6580_weg_l_l200 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3943 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x000000007EB80000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_aeon6580_weg_l_l200.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:05:40 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:05:59 Reconnect Power/Cable! |
The Following User Says Thank You to fertxter For This Useful Post: |
