Old 11-13-2019, 19:50   #61231 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
OPPO A37f PinLock Remove
Brand     : OPPO
ProdName  : A37f
ProdModel : A37f
Device    : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.38_INT_038_201907110016
Manufact. : OPPO
SysPatch  : LMY47V
DevComTime: 2019-07-10 7:29:34 PM
QLMxCPU   : MSM8916
USERData : NORMAL
GCSec    : EMPTY
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 046E9DD0
ID_BLOCK_L : D52F45B11C8AB7B26DC23213DCA72F1F
ID_BLOCK_L : 2558E6494AD5058E03F2A71C169997B4
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:28
Old 11-14-2019, 07:45   #61232 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I6 Matel 1 MT6582 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0138
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505073133D8F22387
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505073133D8F22387
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395F8A505A3EFF86B0007EEB8CB
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Old 11-14-2019, 09:52   #61233 (permalink)
Member: 2935044
Thanks Meter: 75
Infinix Hot S Pin+FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=iGbihtXqzxE[/QUOTE]
Old 11-14-2019, 09:59   #61234 (permalink)
Member: 2935044
Thanks Meter: 75
LAVA iris 702 Pin+FRP Reset Done By 1 Click With CM2 Adnan Mobile
AAdnan Mobile;13894476]LAVA iris 702 Pin+FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=GtkrNCtHQu0[/QUOTE]
Old 11-14-2019, 10:29   #61235 (permalink)
Member: 2935044
Thanks Meter: 75
Nokia TA-1047 Pin+FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=_Rsk-qG9o7o[/QUOTE]
Old 11-14-2019, 10:34   #61236 (permalink)
Member: 2935044
Thanks Meter: 75
Lava iris 820 Format+FRP Reset Done By 1 Click With CM2
AAdnan Mobile;13894481]Lava iris 820 Format+FRP Reset Done By 1 Click With CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=J0Qh7XX86A4[/QUOTE]
Old 11-14-2019, 11:52   #61237 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Blue 5 MT6580 FRP Reset Done With Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464536324D4203124A96FE55B7
[eMMC] : FLASH_INF : [SAMSUNG] , BM26E
[eMMC] : FLASH_CID : 150100464536324D4203124A96FE55B7
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395F882D0525F5CCED8FE128E72
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:18
Old 11-14-2019, 12:06   #61238 (permalink)
Member: 1051138
Sonork: 123456
Thanks Meter: 382
oppo a59m read pattern
14-Nov-19 / 4:18:04 PM
Card found : S/N : 61C9CA94 , v0135
Start at : [14-Nov-19 / 4:18:38 PM]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D42074DE3D06AA33B
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0x199FFE86DB1E733EADCDCEFB215D49E5
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
[AP] : Initial info read Ok!
Brand : OPPO
ProdName : A1601
ProdModel : A1601
Device : A1601
AndroidVer: 5.1
MTKxCPU : MT6755
MTKxPRJ : A1601EX_11_A.40_190709
SECURITY :
IMEI_SW [1] : 863795*********
IMEI_SW [2] : 863795*********
EXTRA :
LCD : Not info available
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov8865_mipi_raw
CAM [3] : s5k3p3sp_mipi_raw
MODEM : oppo6750_15331_lwg
Done!
Elapsed: 00:00:19
Start at : [14-Nov-19 / 4:26:17 PM]
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
USBDL : Init HSUSB Ok
Reading data ...
Get Locks ...
PatternLock Sequnce : 58649327
Done!
Elapsed: 00:00:34
Finish at : [14-Nov-19 / 4:26:52 PM]
Old 11-14-2019, 13:34   #61239 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Infinix-X609 Frp Reset
Patch Level    : O11019
Display ID     : X609-H8025AB-OGo-190604V186
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2019-06-05
Build Time     : 1559618446
Product Brand  : Infinix
Product Name   : H8025
Product Device : Infinix-X609
Product Info   : Infinix-X609
Product Model  : Infinix X609
Product Manfct : INFINIX MOBILITY LIMITED
Product Board  : Infinix-X609
Board Platform : mt6580
USERDATA : ENCRYPTED
NVRAM check : Passed!
Done!
Elapsed: 00:00:26
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11)
MODE : PRELOADER PORT
PORT : 11
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D323645672203427356C19A
DAInf: 4 : 2 : 156
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 150100464536324D420322679AC15673
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3A3E00000 [ 14.56 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x40000000 [ 1.00 GB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : DB83802275727A8411438A48A0F889C1
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:22
Old 11-14-2019, 13:37   #61240 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
GFIVE Spark Dead Recaver
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1F84E20E7604_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:27
Old 11-14-2019, 16:26   #61241 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Infinity B SPD77xx FRP Reset Done With King Infinity CM2
Card found: S/N : A19EC787 , v0138
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 29 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:22
Old 11-14-2019, 16:50   #61242 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 225
LG K580DS Format+FRP+Repier Ok
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
Format UserData
Format Cache
Format done
Erase FRP#0 block Ok!
Erase FRP#1 block Ok!
Done!
Elapsed: 00:00:12
Operation : Repair Security [ v1.03 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
Update IMEI1 : 35------------------
Update IMEI2 : 35------------------
Items updated successfully!
Done!
Elapsed: 00:00:12
The Following User Says Thank You to afghanistanmob For This Useful Post:
Old 11-16-2019, 09:19   #61243 (permalink)
Member: 1941705
Thanks Meter: 1,248
Nomi i5013 EVO M2 Pro
[QUOTE]Operation : Identify [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM408)
PORT : 408
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 422201F46E6977690000102087941A82
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: F40122426977696E20100000821A9487
EMMC: VEN : BIWIN | OEM : 2201 | DEV : Biwin
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x39A000000 [ 14,41 GB ]
SRAM: 0x00020000 [ 128,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
RNID : 84FA9C70CC426848E3CAE842D88DFB9F
Boot done!
Patch Level : NRD90M
Display ID : Nomi_i5013_V07_20170926
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2017-08-05
Build Time : 1506428202
Product Model : i5013
Product Brand : Nomi
Product Name : i5013
Product Device : i5013
Product Board : i5013
Product Manfct : Nomi
Product Info : keytak6580_weg_n
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:45
Operation : Read Firmware [ v2.06 ]
PORT : 408
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Ver. CodeName : REL
Ver. Release : 7.0
MT6580__Nomi__i5013__7.0__Nomi_i5013_V07_20170926_ _NRD90M__keytak6580_weg_n
SecureDevice : Plain
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : tz.img
Read : secro.img
Read : teeinfo.img
Read : system.img
ExtSparse : Compression ratio : 20%
Read : cache.img
Read : userdata.img
FW Size : 2,21 GB
Android Info saved : _Android_info.txt
Scatter : MT6580_Android_scatter.txt
Saved to : C:\Users\Roman\Desktop\nomi i5013\MT6580__Nomi__i5013__7.0__Nomi_i5013_V07_201 70926__NRD90M__keytak6580_weg_n\
Done!
Elapsed: 00:10:29
/QUOTE]
Old 11-16-2019, 12:33   #61244 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QMobile X30 Flashing
Brand     : TINNO
ProdName  : QMobile X30
ProdModel : QMobile X30
Device    : QMobile X30
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:09
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447326111015584C0C062DB
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111015584C0C062DB
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C25E75C6CBFB9D6B063A9D6D950
EXT RAM    : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4086 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:14
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:57
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:28
Old 11-16-2019, 12:38   #61245 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Phantom P2 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4841473265050706821C12B303
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050706821C12B303
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395E698A71B5741E139D3477334
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:45
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.58761 seconds with 11 queries
