08-20-2011, 08:38 | #13846 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | LG RD-6100 version 4 compile Jan 17 2008 selected.. offline.. downloading mode.. sending command.. sending command.. patching in progress 30%.. patching in progress 60%.. patching in progress 90%.. Done... Phones should be restarting now... Finished, time used: 31 sec |
The Following User Says Thank You to Sandeep Mobiles For This Useful Post: |
08-20-2011, 14:43 | #13847 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | E71 Flashed Succesfully On UFS Interface. Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.26 Rev : 2.0 Selected FlashSettings : Files Set for Flashing : MCU : rm346_510.21.009_prd.c00 PPM : rm346_510.21.009_prd.v27 CNT : rm346_510.21.009.53U APE : RM346_ENO_0741.10_08wk42.a36.fpsx CNT3 : leevi_erase_y_drive.fpsx Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1A30010D1D700052901831F7C9B3EE4E38E7E79E CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 004000EC , CMT , NAND CMT Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 52570A2086C79E6965175815B5388535CDD5C6F7A9 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 2048 byte(s) IMEI : 35------------ CMT : Read CCC certificate... Cert size : 1024 byte(s) CMT : Read HWC certificate... Cert size : 1024 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35------------_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1A30010D1D700052901831F7C9B3EE4E38E7E79E CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 004000EC , CMT , NAND CMT Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLCNT : 00030000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent CMT PAPUB : 52570A2086C79E6965175815B5388535CDD5C6F7A9 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing rm346_510.21.009_prd.c00 Found 3 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x00040000 - 0x007FFFFF CMT , NAND , Area : 0x00A00000 - 0x0759FFFF CMT , NAND , Area : 0x0F1C0000 - 0x0F8BFFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x0B , CMT , NAND CMT : Partition erase Ok Erase Partition 0x09 , CMT , NAND CMT : Partition erase Ok Erase Partition 0x0A , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:01 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Write : Processing rm346_510.21.009_prd.c00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS*CORE] CMT: Writing Hash CERT [SOS+ROFS] Total writen 554 blocks TIME : Write time : 00:06:14 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm346_510.21.009_prd.v27 Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x05420000 - 0x0759FFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x09 , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Write : Processing rm346_510.21.009_prd.v27 CMT: Writing Hash CERT [SOS+ROFX] Total writen 195 blocks TIME : Write time : 00:02:16 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm346_510.21.009.53U Erase Partition 0x08 , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:01 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Write : Processing rm346_510.21.009.53U Total writen 122 blocks TIME : Write time : 00:01:26 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Erase : Processing RM346_ENO_0741.10_08wk42.a36.fpsx Erase CRTFL : SOS*ENO CMT : CRTFL erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Write : Processing RM346_ENO_0741.10_08wk42.a36.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 15 blocks TIME : Write time : 00:00:08 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Erase : Processing leevi_erase_y_drive.fpsx Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x0F020000 - 0x0F1BFFFF Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Transmission mode : Dual (Ddr, TX2) Write : Processing leevi_erase_y_drive.fpsx Total writen 0 blocks TIME : Write time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 0003000000000C0000000C00000000 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia E71 Software Info: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia IMEI: 35------------ Ape Version: 510.21.009 Product code: 0566235 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to Shubhanshu~ For This Useful Post: |
08-20-2011, 19:15 | #13848 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 30600 byte(s) IMEI : 357651011427746 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 30600 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : D:\InfinityBox_install_BEST_v1.26\Backup\Cert\3576 51011427746_CRT.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok User ACCEPTED FULL ERASE Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Full Erase started... Asic : CMT , Sub : NOR Erase Area 0x00000000-0x00FFFFFF Using TimeOut : 10 min ( 600 sec ) Erasing, wait..... CMT : Erase Ok Done Phone disconected! Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Files Set for Flashing : MCU : N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_4.0839.42.2.1_PRD.V08 CNT : N73_userarea_4.0839.42.2.1.U02 Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent PAPUBkeys blank (erased or HW failure) Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00080000 - 0x00731951 CMT , NOR , Area : 0x00000000 - 0x0005FFFF CMT , NOR , Area : 0x001E0000 - 0x001FFFFF CMT , NOR , Area : 0x00880000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000FFFFF APE , NAND , Area : 0x00100000 - 0x0025FFFF APE , NAND , Area : 0x003C0000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:04 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+UZIP] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [SOS*CORE] APE: Writing Hash CERT [SOS+ROFS] APE: Writing Hash CERT [SOS+ROFX] Total writen 1770 blocks TIME : Write time : 00:05:30 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_rofx_4.0839.42.2.1_PRD.V08 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x03920000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_rofx_4.0839.42.2.1_PRD.V08 APE: Writing Hash CERT [SOS+ROFX] Total writen 1879 blocks TIME : Write time : 00:02:35 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_userarea_4.0839.42.2.1.U02 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x04E20000 - 0x07C9FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_userarea_4.0839.42.2.1.U02 Total writen 237 blocks TIME : Write time : 00:00:50 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N73 Software Info: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. IMEI: 12345610654321? Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) Variant Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... Switching to CMT... CMT : NPC erase Ok Writing NPC... Ok CMT : VARIANT erase Ok Writing VARIANT... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! Repair SD procedure started... Phone Imei: 357651011427746 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 7A5A00AAD802A8EADA116FC97DC1F5776DD7BFDC APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 1B70000B58C801547DEE62AB69CEE65EEB7C84C2 hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= 9E97FFCD5ADB5A5152EE54C2AFF8054738554C07 Init Service mode... Wait... Key file updated... Check phone mode... Phone already in Test mode, skip change... Writing Super Dongle Key... Ok Done! Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ----------------------- PA_SimLock Version : PA_SL phone detected Done! Local SX4 procedure started... Phone Imei: 357651011427746 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Uploading RF/Battery tune to phone... Using : RM-133.pm Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 33 write - Ok Record 34 write - Ok Record 44 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Record 22 write - Ok Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Checking StartUp data ... ----------------------- SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Done! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
08-20-2011, 19:15 | #13849 (permalink) |
08-21-2011, 03:15 | #13850 (permalink) |
Registered User Join Date: Jun 2009 Location: Philiphines
Member: 1048859 Status: Offline Thanks Meter: 72 | Nokia L-838+ china phone no power Done via InfinityBox I share to all frends and members: *Model: Nokia L838+ china phone *Proble is. No Power *procedure: *Infinity Box *Cable rj45 Rx Tx Grd *And Power supply Voltage.3.9 Frist: Run shell 2nd: Click Complete Mode and click format. Rx-Tx Grd. After Format Unit is Done; Have A nice Day to all Thanks *** |
The Following User Says Thank You to K.I.K For This Useful Post: |
08-21-2011, 05:36 | #13851 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM12 [VCP2] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... warning: wrong data size at 0x01009400, retry... warning: wrong cs at 0x01009400, retry... read error recovered current eeprom imei: 354701012137076 current otp imei: 354701012137076 file saved: C:\InfinityBox\LGA\eeprom_354701012137076_LG-KG110_20110821-100502.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space ... current eeprom imei: 354701012137076 ................. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 71 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
08-21-2011, 09:11 | #13852 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | Action: "repair imei" Model: Spice-S410 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 new imei-1: 353923035785787 verification Ok Finished, time used: 6 sec Remove/Install battery now ! |
08-21-2011, 09:19 | #13853 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | tesco mobile mojo chat successfull unlock 2pcs COM2 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: Tesco-Mobile-Mojo-Chat Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: MOJO_CHAT_C130UK_V3_2_110509 Version: 86 byte(s) read imei: 35762804xxxxx connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 23 sec Remove/Install battery now ! COM2 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: Tesco-Mobile-Mojo-Chat Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: MOJO_CHAT_C200UK_V3.2_110511 Version: 86 byte(s) read imei: 357628040xxxxx connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! [ |
The Following User Says Thank You to yasermalik For This Useful Post: |
08-21-2011, 09:44 | #13854 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP0] selected module v3.75 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1003:A00A status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.45 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203637506 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 1 min 25 sec Remove/Install battery now ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
08-22-2011, 04:47 | #13855 (permalink) |
08-22-2011, 08:28 | #13856 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | C3 Flashed Successfully Over USB Code: Core version : 1.26 Rev : 2.0 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm640__06.05.mcusw PPM : rm640__06.05.ppm_mr1 CNT : rm640__06.05.image_mr1_059B3Z9_006 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 06.05 Phone version : 05.65 26-11-10 RM-640 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 1B9000163DD503446A67591B694EC5F46AB66304 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 00300098 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 35------------ Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35------------_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm640__06.05.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm640__06.05.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm640__06.05.ppm_mr1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm640__06.05.ppm_mr1 Total writen 63 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm640__06.05.image_mr1_059B3Z9_006 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm640__06.05.image_mr1_059B3Z9_006 Total writen 288 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C3-01 Software Info: V 06.05 30-05-11 RM-640 (c) Nokia IMEI: 35------------ PPM version : V 06.05 30-05-11 RM-640 (c) Nokia MR1 Product code: 059B3Z9 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... Error When resetting FullFactory :( ... Error When resetting Product Tune :( ... Error When resetting SW upgrade Default :( ... Resetting LifeTimer Error check LifeTimer Data, break :( Reset It manually, please AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:00:56 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-22-2011, 09:47 | #13857 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | 5130 successfully flashed. card found: registered to: narendrasingh Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mh CNT : rm495__07.97_v2.image_mh_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 06800118A8DD7D56A4D2546EA80EA183AEBA3C89 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:30 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mh Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:03 Write : Processing rm495__07.97.ppm_mh Total 450 [450/0/0] blocks to write, writing... TIME : Write time : 00:00:22 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97_v2.image_mh_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:59 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97_v2.image_mh_red Total 528 [528/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:18 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MH Product code: 0585577 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
08-22-2011, 13:02 | #13858 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Boom success full flash nokia n900 by best card found: S/N 00000:00000 registered to: PAUL-TELECOM Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.003_PR_003 Device mode : Production mode Read info Ok Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.003_PR_003 Device mode : Production mode Read info Ok Check : Processing RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin BLK_INF : kernel BLK_VER : 2.6.28-20103103+0m5 ========== BLK_INF : rootfs BLK_VER : RX-51_2009SE_20.2010.36-2.204.1_PR_204 ========== BLK_INF : cmt-2nd BLK_VER : BB5_09.36 ========== BLK_INF : cmt-algo BLK_VER : BB5_09.36 ========== BLK_INF : cmt-mcusw BLK_VER : rx51_ICPR82_10w08 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2217 , 2218 , 2219 , 2220 , 2120 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2217 , 2218 , 2219 , 2220 , 2120 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2217 , 2218 , 2219 , 2220 , 2120 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2101 , 2102 , 2103 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2101 , 2102 , 2103 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2101 , 2102 , 2103 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2307 , 2308 , 2309 , 2310 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2307 , 2308 , 2309 , 2310 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2307 , 2308 , 2309 , 2310 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2407 , 2408 , 2409 , 2410 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2407 , 2408 , 2409 , 2410 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2407 , 2408 , 2409 , 2410 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2301 , 2302 , 2303 , 2304 , 2305 , 2306 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2301 , 2302 , 2303 , 2304 , 2305 , 2306 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2301 , 2302 , 2303 , 2304 , 2305 , 2306 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2401 , 2402 , 2403 , 2404 , 2405 , 2406 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2401 , 2402 , 2403 , 2404 , 2405 , 2406 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2401 , 2402 , 2403 , 2404 , 2405 , 2406 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2104 , 2105 , 2106 , 2107 , 2108 , 2109 , 2110 , 2111 , 2112 , 2113 , 2114 , 2115 , 2116 , 2117 , 2118 , 2119 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2104 , 2105 , 2106 , 2107 , 2108 , 2109 , 2110 , 2111 , 2112 , 2113 , 2114 , 2115 , 2116 , 2117 , 2118 , 2119 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2104 , 2105 , 2106 , 2107 , 2108 , 2109 , 2110 , 2111 , 2112 , 2113 , 2114 , 2115 , 2116 , 2117 , 2118 , 2119 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2501 , 2502 , 2503 , 2504 , 2505 , 2506 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2501 , 2502 , 2503 , 2504 , 2505 , 2506 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2501 , 2502 , 2503 , 2504 , 2505 , 2506 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2607 , 2608 , 2609 , 2610 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2607 , 2608 , 2609 , 2610 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2607 , 2608 , 2609 , 2610 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2507 , 2508 , 2509 , 2510 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2507 , 2508 , 2509 , 2510 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2507 , 2508 , 2509 , 2510 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2201 , 2202 , 2203 , 2204 , 2205 , 2206 , 2207 , 2208 , 2209 , 2210 , 2211 , 2212 , 2213 , 2214 , 2215 , 2216 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2201 , 2202 , 2203 , 2204 , 2205 , 2206 , 2207 , 2208 , 2209 , 2210 , 2211 , 2212 , 2213 , 2214 , 2215 , 2216 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2201 , 2202 , 2203 , 2204 , 2205 , 2206 , 2207 , 2208 , 2209 , 2210 , 2211 , 2212 , 2213 , 2214 , 2215 , 2216 ========== BLK_INF : 2nd BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2601 , 2602 , 2603 , 2604 , 2605 , 2606 ========== BLK_INF : xloader BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2601 , 2602 , 2603 , 2604 , 2605 , 2606 ========== BLK_INF : secondary BLK_VER : 1.4.14.9+0m5 BLK_THW : RX-51 BLK_REV : 2601 , 2602 , 2603 , 2604 , 2605 , 2606 ========== Check : File Is Ok ! Enable R&D mode... Device state : R&D mode Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2204 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.003_PR_003 Device mode : R&D mode [L:01] Read info Ok Processing NOL part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : rootfs , RX-51_2009SE_20.2010.36-2.204.1_PR_204 RootFs flash Ok Processing CMT part File : RX-51_2009SE_20.2010.36-2.204.1_PR_COMBINED_204_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_20.2010.36-2.204.1_PR_204 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:01:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to niloy2007 For This Useful Post: |
08-22-2011, 14:20 | #13859 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | Unlock done---alcatel 363 COM4 [VCP0] selected module v3.98 Device: Alcatel-363X, 363A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8A52:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.75CE7AF3 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_99950412].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 75CE7AF3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 12049599 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26F provider: 363X-2AVDES1 customization: CI26DH35 customization: XI26DH35 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26DH35 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_75CE7AF3_99950412_2011 0820-105137.B0X.bin Finished, time used: 2 min 31 sec Remove/Install battery now ! THANKS INFINTY |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
08-22-2011, 15:21 | #13860 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | OT-209X UNLOCKED module v4.00 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5866:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76S provider: 209X-2BRGUG9 customization: CM76CE80 customization: XM76CE80 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM76CE80 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-209X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20110822-170948.B0X.bin Finished, time used: 1 min 55 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
