10-19-2011, 12:32 | #14611 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Huawei T156 unlocked => module version: v. => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033961684 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 18 sec Power Off/On phone now ! |
10-19-2011, 12:47 | #14612 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Succesfully flashed Korean 5800 to russian card found: S/N ------ registered to: Akramjon Connect phone on selected interface... Core version : 1.29 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_52.0.007_prd.core.C00 PPM : RM-356_52.0.007_prd.rofs2.V05 PPM2 : RM-356_52.0.007_C01_prd.rofs3.fpsx CNT : RM-356_52.0.007_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 193000030B8A0052C1A2014812BBE8E919CE7C52 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_52.0.007_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.core.C00 Total 501 [501/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:33 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_52.0.007_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.rofs2.V05 Total 118 [118/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI: 358279038366132 Ape Version: V 52.0.007 Product code: 0588615 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:07 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
10-19-2011, 12:48 | #14613 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Succesfully flashed another Korean 5800 to russian card found: S/N --------- registered to: Akramjon Connect phone on selected interface... Core version : 1.29 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_52.0.007_prd.core.C00 PPM : RM-356_52.0.007_prd.rofs2.V05 PPM2 : RM-356_52.0.007_C01_prd.rofs3.fpsx CNT : RM-356_52.0.007_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0B8001177A91005228C86EEC1297EAC7F28EACB8 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_52.0.007_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.core.C00 Total 501 [501/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:33 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_52.0.007_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.rofs2.V05 Total 118 [118/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI: 351531044543873 Ape Version: V 52.0.007 Product code: 0588615 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:14 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
10-19-2011, 12:54 | #14614 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | Motorolla C139 SP-Unlock DONE COM30 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.01.E. HW version: _E88 LP ver: LPH_C139_ASIA2_00A Flex ver: FFH_C139_67_30A imei otp: 35xxxxxxxxxxxxxxxx Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 xxxxxxxxxxxxx_20111019-171911.31E.bin imei eeprom: 35xxxxxxxxxxxxxx Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! |
10-19-2011, 13:48 | #14615 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | if not say thanks then no post again COM3 [VCP0] selected module v4.04 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:7D6A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 865 provider: V345X-2AVDGB1 customization: CM86FE30 customization: XM86FE30 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86FE30 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0000A571A36682 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20111019-031840.B0X.bin Finished, time used: 1 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Vodafone 345 unlock done |
The Following User Says Thank You to haroon454 For This Useful Post: |
10-19-2011, 14:05 | #14616 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Format File System... Check phone mode... Phone in RfInactive mode Seting Local mode... wait... Local mode set Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:07 Core version : 1.30 Rev : 1.1 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_52.0.007_prd.core.C00 PPM : RM-356_52.0.007_prd.rofs2.V05 PPM2 : RM-356_52.0.007_C01_prd.rofs3.fpsx CNT : RM-356_52.0.007_027_000_U001.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 52.0.007 Phone version : V 52.0.007 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354183022829515_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3771 mV -> Batery voltage less, than 3,8V (3771mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1A6001119C710052B4358C4D041896B6E068135A ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_52.0.007_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.core.C00 Total 501 [501/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_52.0.007_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_prd.rofs2.V05 Total 118 [118/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:09 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_52.0.007_027_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_52.0.007_027_000_U001.uda.fpsx Total 57 [57/0/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:52 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia IMEI: 354183022829515 Ape Version: V 52.0.007 Product code: 0575654 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:44 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
10-20-2011, 16:05 | #14617 (permalink) |
Freak Poster Join Date: Aug 2009 Location: kanpur
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 808714B4 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:05 | #14618 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 806ABED3 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:06 | #14619 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 80549BA7 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
The Following User Says Thank You to harvinder43 For This Useful Post: |
10-20-2011, 16:06 | #14620 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | M116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 806C0A63 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:07 | #14621 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 8027CACB Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:08 | #14622 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 808CEBA9 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:08 | #14623 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | OM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 808E1A81 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 16 sec |
10-20-2011, 16:09 | #14624 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 806EDE53 Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
10-20-2011, 16:09 | #14625 (permalink) |
Member: 1108057 Status: Offline Sonork: harvinder Thanks Meter: 131 | COM116 [QCUSB_COM116_1] selected module v1.64 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Jul 06 2011 Jul 06 2011 ZTE 1602 Jul 06 2011 selected.. ESN(hex) : 8079E3FB Password accepted.. downloading mode... waiting respon... waiting chip ready... disabling minlock... disabling minlock 50%... done... Finished, time used: 15 sec |
