12-21-2011, 22:12 | #15046 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | Zte x632 unlock done module v4.12 Action: read unlock codes unlock method: read codes Model: ZTE-X632 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:55E2:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW1.SW7.V3.04_MX_FMXIC Version: YUANDA23C_09A_HW ==================== New firmware found (v.4.12, database date: 28.11.2011): Z525.C136.HW1.SW7.V3.04_MX_FMXIC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35xxxxxxxxxxx connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 181 byte(s) read reading data... 228 byte(s) read lock[1] code: + 13268590 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
12-21-2011, 22:13 | #15047 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | Zte n285 unlock done hecking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: SE-ES-TME-P130D10V1.0.4B05 Version: 09BZTENJ_VEGA53_09B 115 byte(s) read imei: 35XXXXXXXXXXXXXXXXXX connection Ok 216 byte(s) read reading data... building new data... writing data... 204 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 24 sec Remove/Install battery |
12-22-2011, 06:39 | #15048 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Gfive d10 sucessfully complete formatted ==== [12/22/2011 10:58:00 AM] ==== COM16 [VCP1] selected module v4.10 Device: _Autodetect MT6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C8]: 00EC:225400000000 [SAMSUNG] K5N6433ATM chip size: 8Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: GILD.6700S.V11 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SZMI53_6432_09B_PCB01_GPRS_MT6253_S00.GILD_6700S_V 11.BIN_FLNK5N6433ATM_AD11 project-id: GILD.6700S.V11, 00000000 code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Format... autodetection mode... Format done Disconnect... done Finished, time used: 1 min 50 sec Remove/Install battery now ! |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
12-22-2011, 08:45 | #15049 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Just N9 flashing Code: Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1501 NOLO : 01/05/21 SWVer: DFL61_HARMATTAN_20.2011.40-4_PR_001 Device mode : Production mode Read info Ok Processing image : DFL_60.bin Processing APE Boot part... Processing : ape-algo , 2.1.5+0m6 APE Algorithm boot Ok Rebooting... RFS : Confirm Ok! Boot Done! RFS : Read info Device : RM-696 HW build : 1501 Bat.level : 94 SW release : (empty) Protocol : 108 UPDAPP ver : 1.6.3 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mmc,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On RFS Inf -> Init Done! RFS Inf -> eMMC format Skipped RFS Inf -> Secure format Skipped Start flashing all images... Image file : DFL_60.bin RFS : Sending hash [cert-sw] RFS : Flashing... RFS : Sending hash [xloader] RFS : Flashing... RFS : Sending hash [secondary] RFS : Flashing... RFS : Sending hash [kernel] RFS : Flashing... RFS : Sending hash [rootfs] RFS : Flashing... RFS : Sending hash [cmt-2nd] RFS : Flashing... RFS : Sending hash [cmt-algo] RFS : Flashing... RFS : Sending hash [cmt-mcusw] RFS : Flashing... RFS : Preparing CMT flashing... RFS : Processing CMT... CMT -> Erasing CMT.... CMT -> Erase done CMT -> Flashing CMT.... CMT -> Flash done CMT -> Finalize CMT.... CMT -> Finalize done RFS : CMT flash done RFS : Update SW Release Info Ok RFS : Reboot All done! |
The Following 5 Users Say Thank You to Dzirt For This Useful Post: |
12-23-2011, 06:57 | #15050 (permalink) |
No Life Poster Join Date: Sep 2008 Location: BD - UK Age: 44
Member: 861464 Status: Offline Sonork: 100.1597346 noor Thanks Meter: 172 | successfull unlock g6620 COM12 [VCP0] selected module v4.10 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C200.M40.04.10 Version: CKT53_12832_09B_HW ==================== New firmware found (v.4.10, database date: 21.11.2011): G6620SS.C200.M40.04.10 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804990702 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 61056724 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 46 sec Remove/Install battery now ! |
The Following User Says Thank You to noor012345 For This Useful Post: |
12-23-2011, 09:31 | #15051 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: India
Member: 1191805 Status: Offline Thanks Meter: 58 | Quote:
Loading data, wait... [Infinity Box] CDMA-Tool v1.70 smart-card: connected S/N: xxxxxxxxx Wait... Device: LG-3500 How to repair LG "blink": 1. press 5 + Power keys to enter phone in "Emergency mode" 2. connect phone to box via COM port RJ45 cable (emergency cable) 3. make "Repair blink" operation with CDMA-Tool software ==== [12/23/2011 1:55:51 PM] ==== COM7 [VCP0] selected module v1.70 Device: LG-3500 operation: Repair "Blink" Phone should be Switched ON ! connecting... file selected: F:\80 GB G\cdma\infinity\flash\LG\SCR\RD3500_SCR.bin QSC6010-RD3500 QSC6010-RD3500 LG RD3500 selected.. sending boot.. erasing... done.... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- done... Finished, time used: 2 min 20 sec | |
The Following 2 Users Say Thank You to mick12 For This Useful Post: |
12-23-2011, 11:03 | #15052 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | sfr 115 unlocked COM3 [VCP0] selected module v4.12 Action: "user code" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:42AD:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: EFS-SFR-R9SM-P109A17V1.0.4B03 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 3xxxxxxxxxxxxx connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... user code set to: 0000 Finished, time used: 11 sec Remove/Install battery now ! |
The Following User Says Thank You to .:B-A-G:. For This Useful Post: |
12-23-2011, 11:03 | #15053 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | success unlock sfr 251 ==== [19/12/2011 15:13:30] ==== COM3 [VCP0] selected module v4.12 Action: "sp-unlock" unlock method: smart fast Model: SFR-251 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X990_V2_Z5_FR_D18F107 Version: ZTEMT35_09A_GEMINI_HW 86 byte(s) read imei: xxxxxxxxxxxxxx connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... error: verification failed what to do: 1. be sure that you have full flash backup for emergency case 2. make "format ffs" in "complete" mode 3. power-on phone 4. power-off phone by "Power" button (DO NOT remove battery) 5. repeat current operation error: operation failed ! Finished, time used: 22 sec Remove/Install battery now ! and is unlocked !!! |
12-23-2011, 11:04 | #15054 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | success unlock zte s213 COM6 [VCP0] selected module v4.12 Action: read unlock codes unlock method: read codes Model: ZTE-S213 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4F03:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: FE-FR-OM9S-P109A14V1.0.0B05 Version: ZTENJ23D_09A_HW ==================== New firmware found (v.4.12, database date: 28.11.2011): FE-FR-OM9S-P109A14V1.0.0B05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 3xxxxxxxxxxxxxxx connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 864594220240 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 21 sec Remove/Install battery now ! |
12-23-2011, 11:04 | #15055 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | g6150 unlock success COM3 [VCP0] selected module v4.07 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B176SSC Version: VER.B 115 byte(s) read imei: xxxxxxxxxxxxxx Finished, time used: 20 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! |
12-23-2011, 11:31 | #15056 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_042.014_prd.core.fpsx PPM : rm632_042.014_04.01_German_QW1_prd.rofs2.fpsx PPM2 : rm632_042.014_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_042.014_U005.000_prd.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 042.014 Phone version : 042.014 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 030002131FDA5840774E625C1C2B9992A4C0A8D5 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.40.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.40.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357413040020061 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357413040020061_2n d.rpl ===Flashing [MCU]=== Erase : Processing rm632_042.014_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_042.014_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 424 blocks TIME : Write time : 00:00:16 MCU Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_042.014_04.01_German_QW1_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_042.014_04.01_German_QW1_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 252 blocks TIME : Write time : 00:00:10 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_042.014_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_042.014_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 32 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_042.014_U005.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:04 Write : Processing rm632_042.014_U005.000_prd.uda.fpsx Total writen 83 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Flashing done! Total flash time : 00:00:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_10w18.16.3 06-12-10 RM-632 (c) Nokia IMEI: 357413040020061 Ape Version: 042.014 Product code: 059B8P5 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:12 Connect phone on selected interface... |
The Following User Says Thank You to raychevski For This Useful Post: |
12-23-2011, 12:19 | #15057 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Antartica
Member: 1645273 Status: Offline Sonork: ... Thanks Meter: 31 | zte V9C reliance TAB done in juz 4 sec................. COM29 [QCUSB_COM29_1] selected Device: ZTE-V9C checking version... 9GB_RLNC_V9CV1.0.0B03 9GB_RLNC_V9CV1.0.0B03 ZTE V9C Ver 13 July 2011 selected... patching in progress.. done... Finished, time used: 4 sec |
The Following User Says Thank You to bumblebee46 For This Useful Post: |
12-23-2011, 13:22 | #15058 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ALCATEL-305X UNLOCKED module v4.12 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8274:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.34A6F8E3 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 34A6F8E3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: 305X-2FVDKE1 customization: CP16CH12 customization: XP16CH12 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CH12 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_34A6F8E3_1382AAEA_201 11223-142003.B0X.bin Finished, time used: 3 min 45 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
12-23-2011, 13:42 | #15059 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 285 | Core version : 1.30 Rev : 1.1 Selected FlashSettings : -> File : RM-707_025.007_U05.01_79.92.uda.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-707_025.007_79.92_prd.core.fpsx PPM : RM-707_025.007_24.01_India_79.92_prd.rofs2.fpsx PPM2 : RM-707_025.007_00.01_79.92_prd.rofs3.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 025.007 Phone version : 021.013 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1300020E40DA0344A9A2A190C624F3E403CC114F ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.34.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.34.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : A777258432D3E9101D6160DBAC2702FCC602E752 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356257049022706 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : e:\InfinityBox\BEST\Backup\Cert\356257049022706.rp l ===Flashing [MCU]=== Erase : Processing RM-707_025.007_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-707_025.007_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 504 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-707_025.007_24.01_India_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-707_025.007_24.01_India_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 111 blocks TIME : Write time : 00:00:04 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-707_025.007_00.01_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-707_025.007_00.01_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:25 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X7-00 Software Info: V 92_11w37 14-09-11 RM-707 (c) Nokia IMEI: 356257049022706 Ape Version: 025.007 Product code: 059G562 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to murthyy For This Useful Post: |
12-23-2011, 16:51 | #15060 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock done huawei g7010>>>> Code: COM3 [ProlificSerial2] selected module v4.13 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: GBRC154B267SSCPAB Version: VER.C 115 byte(s) read imei: 35391504704153 Finished, time used: 27 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! Br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
