Old 12-13-2009, 07:36   #1501 (permalink)
layek_khan's Avatar
Member: 1168412
Sonork: 100.1679510
Thanks Meter: 85
Thumbs up Alcatel ot-600 10000% direct unlocked
COM12 [VCP0] selected
module v2.99
Device: Alcatel-600
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:5103:A007
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.92173 920.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 92173920
rom info protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4
code offset: 00020000
ffs offset/size: 00C00000/00400000
TCL-ID identification
version: 266
provider: 600X-2AVRGB1
customization: CJ26CW10
customization: XJ26CW10
TCL-ID identification done
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_92173920_C4B7397C_20091213-132706.B0X.bin
Finished, time used: 201 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to layek_khan For This Useful Post:
Old 12-13-2009, 09:02   #1502 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
COM3 [VCP0] selected
module v2.99
Device: Kyocera-C2500
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6217:8A00]...
CPU: MT6217
Boot Done
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000
reading: Kyocera-C2500__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Kyocera-C2500__ffs_20091015-020059.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 91 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 12-13-2009, 10:23   #1503 (permalink)
best_unlocking's Avatar
Member: 889422
Thanks Meter: 182
ALCATEL E230 unlock 100% ok
run the infinity Shell
Select the Alcatel
model E230
when Select the ports infinity box
after read unlock codes
mushtaq
Old 12-13-2009, 10:46   #1504 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,418
please post log
Faisal_Computer
Old 12-13-2009, 10:53   #1505 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
Select the Alcatel
model E230
mushtaq
plz post ur logs here
Old 12-13-2009, 12:51   #1506 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 478
.::kp170::. Unlocked
COM3 [VCP2] selected
module v1.39
Device: LG-KP170 (under test)
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 35030526*******
ved: C:\Program Files\InfinityBox\LGA\eeprom_350305260******170 (under test)_20091213-174657.B1E.bin
Check flash Done
Check space ...
current eeprom imei: 35030526000******g: Probably wrong model selected or unknown eeprom structure,
Are you sure you want to continue ?
finalization done
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 83 sec
.::SHERRY MOBILES::.
The Following User Says Thank You to oMeR_Rasheed For This Useful Post:
Old 12-13-2009, 16:48   #1507 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 860
COM5 [VCP0] selected
module v2.99
Action: read codes
unlock method: read codes
Model: LG-KP220
error: boot initialization step #3 failed: 00
19200 autodetect
Initializing [6219:8B02:8B01]...
CPU: MT6219
chip: 0031:BAC1:B502
status: FF
detected CPU: MT6226MA
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6219B,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7338SA00-002-R1B
Version: EP_0920
60 byte(s) read
imei: 35167202274829
connection Ok
208 byte(s) read
156 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 5635282
Finished, time used: 47 sec
The Following User Says Thank You to alis For This Useful Post:
Old 12-14-2009, 05:04   #1508 (permalink)
ZubairArain's Avatar
Member: 751908
Thanks Meter: 186
Ufone T156 Unlock Done.
=> module version: v.
=> operation (3) started: COM4
==> get_dll_version
dll version: 38.0i
==> set_com_port
==> set_baud_rate
==> set_v24_mode
==> set_baud_rate
==> check_comm_link
==> get_ms_id
imei: 353081034700560
==> get_sw_version
sw ver: P1.2PU02V01.01
==> get_sec_version
sec ver: 00.31Et(4242)
==> get_eep_version
eep version: 000C
==> get_eep_revision
eep revision: 0000
==> reading...
access result: 00
access level: 03
==> set required mode...
==> reboot...
==> reading...
lock result: 00
lock status: 020A
==> unlock...
verification result: F0600100561200FF00040105020503050405000000000000
==> restore original mode...
last error: No errors
=> operation finished
==> close_com_port
Finished, time used: 20 sec
Power Off/On phone now !
~ZubairArain~
The Following User Says Thank You to ZubairArain For This Useful Post:
Old 12-14-2009, 09:33   #1509 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
TREND T100 PHONE CODE OK
COM6 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
high speed boot On
Boot Done
Initialize ...
flash: 01227E22022201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud ...
115200
Set baud Done
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00700000
checking area [00000000]: 00000000-007FFFFF...
ffs/eeprom found near: 00700000
detecting ffs/eeprom size...
ffs/eeprom size: 00100000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00700000-007FFFFF
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 67 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 12-14-2009, 10:49   #1510 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
Etisalat 211fm unlock done
COM8 [VCP1] selected
module v2.97
Device: Etisalat-211FM
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A04:8A00]...
CPU: MT6223
chip: 0011:5EB4:000C
status: FF
Boot Done
flash: 98009600000000:2AEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb
Initialize Done
====> Set baud ...
460800
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.2.97, database date: 03.10.2009):
ZTENJ23_07A_PMJ_PCB01_GPRS_MT6223_S00.AE-UAE-ET-P109A2FMV1_0_0B04.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info protocol ver: 04
ver. sw 1: ZTENJ23_07A_PMJ_PCB01_GPRS_MT6223_S00.AE-UAE-ET-P109A2FMV1_0_0B04.BIN
ver. sw 2: AE-UAE-ET-P109A2FMV1.0.0B04, 00000000
address offset: 00000000
ffs offset/size: 00680000/00180000
ffs/eeprom address assigned: 00680000
reading: Etisalat-211FM_ZTENJ23_07A_PMJ_PCB01_GPRS_MT6223_S00.AE-UAE-ET-P109A2FMV1_0_0B04__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Etisalat-211FM_ZTENJ23_07A_PMJ_PCB01_GPRS_MT6223_S00.AE-UAE-ET-P109A2FMV1_0_0B04__ffs_20091214-154733.B0E.bin
detection procedure, wait...
detection procedure completed
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
====> Write ...
Write: eeprom
Write Done
Finalization Done
Finished, time used: 102 sec
GSMSWAT
The Following 2 Users Say Thank You to gsm-world For This Useful Post:
Old 12-14-2009, 10:50   #1511 (permalink)
Member: 529953
Sonork: 100.1605485
Thanks Meter: 46
COM10 [VCP0] selected
module v1.37
Device: Motorola-C168
"advanced chip detection" active
Action: reset settings
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
406250
Set baud done
Check hardware ...
flash: 89886400010001:89886400000000
flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb
software version: 1490-000
software version: TCT-9-
Check hardware done
Read data ...
reading Motorola-C168_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20091214-154628.69E.bin
Read data done
Check data ...
Check data done
Write ...
Erase: ffs
Write done
Finished, time used: 108 sec
The Following User Says Thank You to fraz12345 For This Useful Post:
Old 12-14-2009, 11:10   #1512 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
module v2.75
Action: touchscreen calibration
mode: 1
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:E803:000B
Connecting, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: A300.V03.EnFrArRuPeViSp.XIAHUA
Version: Eidolon_GEMINI_HW_V3.0
detecting structure #2...
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-2)...
0 1 done
211 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 15 sec
Old 12-14-2009, 11:26   #1513 (permalink)
akhtar416786's Avatar
Member: 342708
Thanks Meter: 29
Alcatel-E201-finalizing...done-Remove/Install battery now !
COM4 [VCP3] selected
module v1.34
Device: Alcatel-E201
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-E201_eeprom_calibration-1...
file saved: C:\Documents and Settings\akhtar\Desktop\Alcatel-E201_eeprom_calibration-1_20081214-161819.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 124 sec
The Following User Says Thank You to akhtar416786 For This Useful Post:
Old 12-14-2009, 12:13   #1514 (permalink)
Member: 245026
Thanks Meter: 379
zte x761
COM8 [VCP0] selected
module v2.96
Action: unlock
unlock method: smart fast
Model: ZTE-X761
19200 autodetect
CPU: MT6225
chip: 0001:0603:000A
status: FF
Date: 2006.06.14
Version: 1.0
Version: X761_Z2_SF_BFFA108
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35***********
connection Ok
157 byte(s) read
reading data...
reading data #4...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
The Following User Says Thank You to sassa_01 For This Useful Post:
Old 12-14-2009, 13:05   #1515 (permalink)
Member: 300690
Thanks Meter: 12
Originally Posted by Infinity-Box View Post
Dear Customers,
As we all have experienced the miracle our chinese miracle software can produce to service Chinese Made Phones we would like to you to post your success storys here
Some Guideline
1) Not more than 4 lines
2) How you were benfited by Infinity Box Chinese miracle software
3) How our support has been this is your comment for our future customers
i had been using infinity for the last three years..
i unlocked nearly "3000 moto 139,115 " ,,,"1000 spice s5.4o4.."200 nos j100",,,"200 nos sams c140",,,,,"2000 chinese dead phones" and now ""1000 nos imei changin"" and some other models..
i think no other box can give the updates and quick reply as INFINITY..
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.45379 seconds with 9 queries
