Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #151 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 574441 Status: Offline Thanks: 52
| ![]() COM13 [VCP0] selected module v1.58 Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20090516-164838.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20090516-164839.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20090516-164843.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20090516-164846.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01E0 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 29 sec Remove/Install battery now |
| The Following 2 Users Say Thank You to mak_14344 For This Useful Post: |
| | #152 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks: 382
| Spice S7 User Code COM6 [VCP1] selected module v2.73 Action: read codes unlock method: read codes Model: Spice-S7 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:5241:19E8 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: KAI265_INA_En_1.09.109 Version: KONKA26_06B_HW 44 byte(s) read imei: 3534010xxxxxxx connection Ok 156 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 14325F Finished, time used: 13 sec Remove/Install battery now ! |
| The Following User Says Thank You to zeel_zeel For This Useful Post: |
| | #153 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 26
Member: 171512 Status: Offline Thanks: 141
| NKTEL C6000 REPAIR OK COM3 [VCP1] selected module v2.78 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F403:0004 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N78_TV0057_LCD_V2.7 Version: LONGYU25_GEMINI_HW detecting structure #2... 4 5 11 done 67 byte(s) read imei: 35849102107038 connection Ok building list... done items to clear: 157 warning: wrong packet cs warning: wrong packet cs items cleared: 157 of 157 building list... done items remains: 0 Finished, time used: 26 sec Remove/Install battery now ! |
| The Following User Says Thank You to ehsas_ghum For This Useful Post: |
| | #154 (permalink) |
| LG KP220 REPAIR OK WITH INFINTY THANKS GR8 TEAM COM3 [VCP1] selected module v2.74 Action: reset settings Model: LG-KP220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:C541:F784 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7338SA00-002-R1B Version: EP_0920 60 byte(s) read imei: 35167202215772 connection Ok building list... done items to clear: 220 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 220 of 220 building list... done items remains: 0 Finished, time used: 41 sec Remove/Install battery now ! |
| | #155 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: .:Jeddah,KSA:. Age: 26
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks: 792
| kg270 dead repaired:p kg 270 succesfuly repaired with infinity thanks infinity team ![]() COM3 [VCP0] selected module v1.63 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20090517-164500.B1E.bin loading data... data loaded imei: 35744601832729000 reading eeprom-security_35744601832729000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744601832729000_20090517-164501.B1E.bin reading eeprom-complete_35744601832729000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744601832729000_20090517-164508.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Write Done Finished, time used: 438 sec Remove/Install battery now ! |
| The Following User Says Thank You to azeem781986 For This Useful Post: |
| | #156 (permalink) |
| nktel 5310 user lock ok with infinty COM3 [VCP0] selected module v2.78 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001 B03:000Dstatus: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M5310B_V2.0.2 Version: LONGYU25_06B_HW detecting structure #2... 0 6 done 44 byte(s) read imei: 35668800063202 connection Ok detecting structure #1... 0 3 4 5 7 8warning: wrong packet cs done 156 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 7092 Finished, time used: 12 sec Remove/Install battery now ! |
| | #157 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004 Location: EGYPT Age: 29
Member: 63774 Status: Offline Sonork: 100.88137 Thanks: 67
| Alcatel-S210 unlock COM3 [VCP1] selected module v1.32 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090517-213722.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 74 sec Remove/Install battery now ! |
| The Following User Says Thank You to Tamer_Elhosary For This Useful Post: |
| | #158 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 207280 Status: Offline Thanks: 247
| New firmware but fixed [QUOTE=zinoubinabil;4391714]Post here Successfully Unlocked/repaired Phones By infinity box make sure to post log or screenshotPost here Successfully Unlocked Phones By infinity box. ==== log: [07/05/2009 15:03:46] ==== COM5 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001 803:0003status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #01 in region #00... flash: 98004900000002 2F0A400000000flash: Toshiba TV00578002DABD T 8Mb detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #03 in region #00... flash: 98004900000002 2F0A400000000flash: Toshiba TV00578002DABD T 8Mb detecting chip #04 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #05 in region #00... flash: 98004900000002 2F0A400000000flash: Toshiba TV00578002DABD T 8Mb detecting chip #06 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #07 in region #00... flash: 98004900000002 2F0A400000000flash: Toshiba TV00578002DABD T 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #01 in region #00... flash: 98004900000002 2F0A400000000flash: Toshiba TV00578002DABD T 8Mb detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba TV00578002DABD T 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.81, database date: 01.05.2009): TL_T819ZMC_P00U00F07L31_01_11.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: mt62xx@gmail.com - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: TL_T819ZMC_P00U00F07L31_01_11.BIN ver. sw 2: TL_T819ZMC_P00U00F07L31_01.11, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-007FFFFF... flash: 98004900000002 2F0A400000000checking area [00800000]: 00000000-007FFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00600000-007FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TL_T819ZMC_P00U00F07L31_01_11__ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\TL_T819ZMC_P00U00 F07L31_01_11__ffs_20090507-151340.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002 2F0A400000000Finalization Done Finished, time used: 604 sec Remove/Install battery now ! |
| The Following User Says Thank You to josh_aina For This Useful Post: |
| | #159 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: Al-Madina Communication Age: 35
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks: 497
| COM4 [VCP1] selected module v1.38 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352008020588163 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008020588163_LG-KP110_20090518-112637.B1E.bin .... reading _eeprom-ffs_352008020588163... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_352008020588163_LG-KP110_20090518-112744.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 121 sec Remove/Install battery now ! |
| The Following User Says Thank You to alis For This Useful Post: |
| | #160 (permalink) |
| COM4 [VCP1] selected module v2.71 Action: read codes unlock method: read codes Model: LG-KP199 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:8F41:FF0C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7339SA00-002-R1B Version: EP2_HW 44 byte(s) read imei: 35313302098234 connection Ok 157 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 3115 Finished, time used: 15 sec Remove/Install battery now ! |
| | #161 (permalink) |
| j110 user code COM4 [VCP1] selected module v1.32 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: user code Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 032H-000 software version: KIM-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20090518-100650.6AE.bin Read data done Check data ... Check data done Write ... pass 1... new user code: 0000 flash: 89886200010001:89886200000000 Write: eeprom Write done Finished, time used: 19 sec Remove/Install battery now ! |
| | #162 (permalink) |
| COM5 selected module v2.73 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/2 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! |
| | #163 (permalink) |
| lg kp110 blinking COM4 [VCP1] selected module v1.38 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352008020588163 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008020588163_LG-KP110_20090518-112637.B1E.bin .... reading _eeprom-ffs_352008020588163... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_352008020588163_LG-KP110_20090518-112744.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 121 sec Remove/Install battery now ! |
| | #164 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: Ofcourse New Pakistan Age: 24
Member: 253510 Status: Offline Sonork: 100.1592434 Thanks: 437
| lobster 544 lobster 544 imei change and format done with infinity here is log: Action: imei Model: Intex-IN5544 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6219, E01 Hardware version: Ver H/W: 0.1 Software version: MP500.W05.20.MP.V53" Software date: 2004.06.18 Barcode: AT+EGMR=0,5 imei: 350448085785480 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 358754857854871 verification Ok Finished, time used: 10 sec Power off phone now ! here is format log: ==== log opened: [5/18/2009 7:31:17 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v2.72 S/N: 672D:0112 Wait... Device: Intex-IN5544 Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? operation aborted ==== log opened: [5/18/2009 7:56:01 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v2.72 S/N: 672D:0112 Wait... Device: Intex-IN5544 Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/18/2009 7:56:27 PM] ==== COM4 [VCP0] selected module v2.72 Action: reset settings Model: Intex-IN5544 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8A01]... CPU: MT6219 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.2.1.4 Version: MP500.W05.20.MP.V53 Version: VerH/W:0.1 60 byte(s) read imei: 70194479539689 connection Ok building list... done items to clear: 226 warning: wrong packet cs warning: wrong packet cs items cleared: 220 of 226 building list... done items remains: 5 Finished, time used: 93 sec Remove/Install battery now ! |
| The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
| | #165 (permalink) |
| kg300 kg300 show lg logo then off successfully done with infinity: how to do:go to chinese miracles select cpu base band exe then run then select in setting tab 6228 6230 nand then format whole flash chip here is log files: ==== log opened: [5/18/2009 10:07:59 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 672D:0112 Wait... Device: Autodetect 6205-6227 NOR Done Device: Autodetect 6228-6230 NAND WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/18/2009 10:08:18 PM] ==== COM4 [VCP0] selected module v2.82 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:E941 5D4status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: incorrect bootloader header: FCBE6685CCEBF8B70C1CA404DA95BCBB nfi area detection finished: failed warning: can not detect chip parameters, default values assigned Identification Done Write ... formatting... .................................................. .................................................. Write Done Finished, time used: 70 sec Remove/Install battery now ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
