08-06-2012, 11:19 | #16546 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Connected phone - Nokia 6700s Software ver : V ICPR82_10w18.4 25-05-10 RM-576 (c) Nokia IMEI : 354321040284681 Ape Ver : 033.014 APE Var : 033.014033.014.01.01033.014.242.04 APE ADSP: 256 DSP Ver : ICPR82_10w18.4 APE Test: 0.A28 PPM : CNT : Product SN : KLQ359854 Product code : 0598566 Base Prd.code: 0580659 Module code : 0204314 Long Prod.SN : 0 Hardware info======= HWID : 2001 Retu : 35 Tahvo : 00 Batery: 3880 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 354321040284681 IMEI spNet : 3A 45 23 01 04 82 64 08 IMEI svNet : 33 45 23 01 04 82 64 38 F3 Conf key : 0000000000000000 Provider key : 2080100000000000 Country : France Operator : Orange F Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Using F-bus count... Sending code 283760069734509 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! |
The Following User Says Thank You to Nadoui For This Useful Post: |
08-07-2012, 09:56 | #16548 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm578__10.47.mcusw PPM : rm578__10.47.ppm_ru CNT : rm578__10.47.image_mr_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101023000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 21E0000B8B36015697D136FD47486FD76E0737A1 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm578__10.47.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0155FFFF, NOR, CMT Result: 0000 Erasing area 0x01560000 - 0x0175FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:56 Write : Processing rm578__10.47.mcusw Total 1395 [1395/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:08 MCU Write done ===Flashing [PPM]=== Erase : Processing rm578__10.47.ppm_ru Found 1 areas to erase Erasing area 0x01760000 - 0x01FFFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:06 Write : Processing rm578__10.47.ppm_ru Total 406 [406/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm578__10.47.image_mr_red Found 2 areas to erase Erasing area 0x02000000 - 0x0245FFFF, NOR, CMT Result: 0000 Erasing area 0x02460000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:45 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm578__10.47.image_mr_red Total 1040 [1040/0/0] blocks to write, writing... TIME : Write time : 00:00:52 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:09 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2730 classic Software Info: V 10.47 27-08-10 RM-578 (c) Nokia IMEI: 353396048503135 PPM version : V 10.47 27-08-10 RM-578 (c) Nokia Product code: 0585334 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:13:43 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Namangan For This Useful Post: |
08-07-2012, 11:26 | #16549 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_014.002_79.92_prd.core.fpsx PPM : RM-596_014.002_04.01_Russian_79.92_prd.rofs2.fpsx PPM2 : RM-596_014.002_00.01_79.92_prd.rofs3.fpsx CNT : RM-596_014.002_U01.01_79.92_prd.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 014.002 Phone version : 014.002 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 27400101D7D80344EB72EF05F313C44D4143FA42 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357398046940786 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357398046940786_2n d.rpl ===Flashing [MCU]=== Erase : Processing RM-596_014.002_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_014.002_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 549 blocks TIME : Write time : 00:00:20 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_014.002_04.01_Russian_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_014.002_04.01_Russian_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 178 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_014.002_00.01_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_014.002_00.01_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_014.002_U01.01_79.92_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_014.002_U01.01_79.92_prd.uda.fpsx Total writen 228 blocks TIME : Write time : 00:00:10 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 92PS1_10w46.9 01-03-11 RM-596 (c) Nokia IMEI: 357398046940786 Ape Version: 014.002 Product code: 059C5Q8 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:01 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to raychevski For This Useful Post: |
08-07-2012, 11:59 | #16550 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | registered to: saeedullah_khan Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_f CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 2060020924497F56B74B3AED6EAFDBB0FEFA1150 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:05 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:18 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_f Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:24 Write : Processing rm443__10.12.ppm_f Total 391 [391/0/0] blocks to write, writing... TIME : Write time : 00:00:18 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_f_chestnut Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:55 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_f_chestnut Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:30 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:12:32 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 356036035676919 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia F Product code: 0569441 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:13:23 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 6036035676919_SIM.rpl Elapsed: 00:00:02 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-07-2012, 12:35 | #16551 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | Phone found! Series 60 Device detected! read info... - Ok Set phone in Test mode... Restarting... Done! Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm645_071.005_prd.core.fpsx PPM : rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx PPM2 : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm645_071.005_U040.000_prd.uda.fpsx APE : RM645_ENO_10wk48v0.001.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1D30010C899C0344ECD8B60B26CD38CA0DDDE2DA ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354330044514605 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 4330044514605.rpl ===Flashing [MCU]=== Erase : Processing rm645_071.005_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_071.005_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 411 blocks TIME : Write time : 00:00:14 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 147 blocks TIME : Write time : 00:00:05 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm645_071.005_U040.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_071.005_U040.000_prd.uda.fpsx Total writen 1 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing RM645_ENO_10wk48v0.001.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM645_ENO_10wk48v0.001.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 10 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:22 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C5-00 Software Info: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia IMEI: 354330044514605 Ape Version: 071.005 Product code: 0593732 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:00:41 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
08-07-2012, 12:48 | #16552 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B1001015D9A0052118896A589C0A631FEF7B09C ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\354316049990387_SI M.rpl Phone disconected! Connect phone on selected interface... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-559_32.0.002_prd.core.C00 PPM : RM-559_32.0.002_prd.rofs2.V05 PPM2 : RM-559_32.0.002_C01_prd.rofs3.fpsx CNT : RM-559_32.0.002_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC -> Boot fail... Flashing failed... Core : v1.44 , FlashEngine : v1.35 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-559_32.0.002_prd.core.C00 PPM : RM-559_32.0.002_prd.rofs2.V05 PPM2 : RM-559_32.0.002_C01_prd.rofs3.fpsx CNT : RM-559_32.0.002_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B1001015D9A0052118896A589C0A631FEF7B09C ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-559_32.0.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0B71FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-559_32.0.002_prd.core.C00 Total 494 [494/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:31 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-559_32.0.002_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07920000 - 0x0A2FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_32.0.002_prd.rofs2.V05 Total 116 [116/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-559_32.0.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0A300000 - 0x0B71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_32.0.002_C01_prd.rofs3.fpsx Total 25 [25/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-559_32.0.002_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0B720000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_32.0.002_001_000_U001.uda.fpsx Total 32 [32/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X6-00 Software Info: V ICPR72_10w42.1.2 17-03-11 RM-559 (c) Nokia IMEI: 354316049990387 Ape Version: V 32.0.002 Product code: 05999F5 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:10 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-07-2012, 13:36 | #16553 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | COM6 [VCP0] selected module v4.11 Action: read unlock codes unlock method: read codes Model: ZTE-R221_16mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:6844:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: BG-MTEL-R9SM-P109A17V1.0.0B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 86120700637323 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 227318537470 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to dimityr.milev For This Useful Post: |
08-08-2012, 14:16 | #16554 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm561__09.98.image_t_ph_blac Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 4192038155344_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1910020957247E56E3C83E14EB2197889670CB71 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.98.image_t_ph_blac ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 037B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_t_ph_blac Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:29 Write : Processing rm561__09.98.image_t_ph_blac Total 696 [696/0/0] blocks to write, writing... TIME : Write time : 00:00:37 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.98 06-09-10 RM-561 (c) Nokia IMEI: 354192038155344 PPM version : V 09.98 06-09-10 RM-561 (c) Nokia S Product code: 0579321 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:07:02 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-08-2012, 14:31 | #16555 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | registered to: saeedullah_khan Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_f CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 2820010C24497F56981C502326BBFE79A001C416 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:28 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:12 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_f Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:10 Write : Processing rm443__10.12.ppm_f Total 391 [391/0/0] blocks to write, writing... TIME : Write time : 00:00:17 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_f_chestnut Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:08 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_f_chestnut Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:26 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 356036035702418 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia F Product code: 0569493 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:24 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
08-08-2012, 16:06 | #16556 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | registered to: nadoui Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C3-00 Software ver : V 03.36 05-07-10 RM-614 (c) Nokia IMEI : 354844041098610 PPM : V 03.36 05-07-10 RM-614 (c) Nokia OC2 CNT : Content: orange FR V 03.36 05-07-10 RM-614 (c) Nokia Product SN : DAY590819 Product code : 059B8V1 Base Prd.code: 0587486 Module code : 0204418 Long Prod.SN : 0 Hardware info======= HWID : 1003 Batery: 4091 mV CMT BT: 4217-v344 LCDVer: SEIKO Lock info =========== IMEI : 354844041098610 IMEI spNet : 3A 45 48 04 14 90 68 01 IMEI svNet : 33 45 48 04 14 90 68 01 F9 Conf key : 8000000000000000 Provider key : 2080100000000000 Country : France Operator : Orange F Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Using F-bus count... Sending code 160152240012931 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Phone disconected! Connect phone on selected interface... |
08-09-2012, 08:40 | #16557 (permalink) |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | Nokia C5-03 Flashing Done Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-03 Software ver : V ICPR82_11w25.7 05-12-11 RM-697 (c) Nokia IMEI : 359762048903134 Ape Ver : V 22.0.007 APE Var : V 22.0.00722.0.00722.0.007 APE ADSP: 256 DSP Ver : 11w48 APE Test: 10.0.031_v0.002 PPM : CNT : Product SN : 42813B4AA Product code : 059C505 Base Prd.code: 059B215 Module code : 0204650 Long Prod.SN : 0 Hardware info======= HWID : 4001 Retu : 40 Tahvo : 00 Batery: 3883 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 359762048903134 IMEI spNet : 3A 95 67 02 84 09 13 03 IMEI svNet : 33 95 67 02 84 09 13 03 F7 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL30 phone , SP_CODE_LEN : 20 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! BackUp UserData : [PhoneBook] Generation mode : [S60] Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 9.3/9.4] Phone! Warning! Many [9.3] and [9.4] phones not supported now Running : APE_TEST_SERVER,w03_09,(c)NMP Found! Will read 166 blocks... Sorry, FS error : Phone not answer... Error during read... Error during read... BackUp UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 9.3/9.4] Phone! Warning! Many [9.3] and [9.4] phones not supported now Running : APE_TEST_SERVER,w03_09,(c)NMP Found! Will read 166 blocks... Sorry, FS error : Phone not answer... Error during read... Error during read... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-697_22.0.007_prd.core.C00 PPM : RM-697_22.0.007_prd.rofs2.V20 PPM2 : RM-697_22.0.007_C01_prd.rofs3.fpsx CNT : RM697_719_014_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 0BC0000EB5DE034483F9A01B9CDA3A22A297FE39 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 78E50A8766EC9CD99D190EEA9676987905B09588 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 359762048903134 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\359762048903134.rp l ===Flashing [MCU]=== Erase : Processing RM-697_22.0.007_prd.core.C00 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-697_22.0.007_prd.core.C00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 443 blocks TIME : Write time : 00:01:00 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-697_22.0.007_prd.rofs2.V20 Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-697_22.0.007_prd.rofs2.V20 CMT: Writing Hash CERT [SOS+ROFS2] Total writen 77 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-697_22.0.007_C01_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-697_22.0.007_C01_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 6 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM697_719_014_U001.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM697_719_014_U001.uda.fpsx Total writen 24 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000010000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C5-03 Software Info: V ICPR82_11w25.7 05-12-11 RM-697 (c) Nokia IMEI: 359762048903134 Ape Version: V 22.0.007 Product code: 059C505 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:02 Connect phone on selected interface... GSM007 |
08-09-2012, 08:41 | #16558 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | 5310 Flashing done Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm303__10.10.mcusw PPM : rm303__10.10.ppm_m4 CNT : rm303__10.10.image_x_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101013000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 21A0000FA32F7D56F9CF2A7FC55B173146E897A3 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm303__10.10.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x010DFFFF, NOR, CMT Result: 0000 Erasing area 0x010E0000 - 0x0121FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:13 Write : Processing rm303__10.10.mcusw Total 1107 [1107/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:51 MCU Write done ===Flashing [PPM]=== Erase : Processing rm303__10.10.ppm_m4 Found 1 areas to erase Erasing area 0x01220000 - 0x0189FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:22 Write : Processing rm303__10.10.ppm_m4 Total 314 [314/0/0] blocks to write, writing... TIME : Write time : 00:00:29 PPM Write done ===Flashing [CNT]=== Erase : Processing rm303__10.10.image_x_blue Found 2 areas to erase Erasing area 0x018A0000 - 0x01B1FFFF, NOR, CMT Result: 0000 Erasing area 0x01B20000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:01 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm303__10.10.image_x_blue Total 680 [680/0/0] blocks to write, writing... TIME : Write time : 00:01:03 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:01 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5310 XpressMusic Software Info: V 10.10 23-03-09 RM-303 (c) Nokia IMEI: 351934034425871 PPM version : V 10.10 23-03-09 RM-303 (c) Nokia M4 Product code: 0556705 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:10:14 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... GSM007 |
08-09-2012, 10:57 | #16559 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,738 | registered to: saeedullah_khan Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_f CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Error on 1st boot Check cable, Battery. Try again -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_f CNT : rm443__10.12.image_f_chestnut Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0EF000066F9D7D562E6BE87A0F9257E7AADDA389 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:39 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:07 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_f Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:15 Write : Processing rm443__10.12.ppm_f Total 391 [391/0/0] blocks to write, writing... TIME : Write time : 00:00:16 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_f_chestnut Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:21 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_f_chestnut Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:27 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 353199036292368 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia F Product code: 0569439 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-09-2012, 17:23 | #16560 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | registered to: nadoui Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N97 mini Software ver : V ICPR72_09w44.11 20-01-10 RM-555 (c) Nokia IMEI : 351979049076326 Ape Ver : v 11.0.102 APE Var : v 11.0.10211.0.102.32.0111.0.102.322.02 APE ADSP: 256 DSP Ver : gadget_ICPR72_09w43_p1 APE Test: 0.031 PPM : CNT : 11.0.102.uda_1_001r RM555_101_000_M005 Product SN : CFN024620 Product code : 0598968 Base Prd.code: 0580176 Long Prod.SN : 0 Hardware info======= HWID : 6212 Retu : 16 Tahvo : 22 Batery: 3689 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 Lock info =========== IMEI : 351979049076326 IMEI spNet : 3A 15 79 09 94 70 36 02 IMEI svNet : 33 15 79 09 94 70 36 02 F3 Conf key : 8000000000000000 Provider key : 2080100425505114 Country : France Operator : Orange F Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close Lock2:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Using F-bus count... Sending code 061956872218607 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Phone disconected! Connect phone on selected interface... |
