12-31-2009, 09:37 | #1681 (permalink) |
No Life Poster Join Date: May 2008 Location: U.A.E Age: 34
Member: 767368 Status: Offline Sonork: 100.1590347 Thanks Meter: 570 | virgin vm621i unlock 100% virgin vm621i unlock 100% InfinityUpdate_MModule_v3.00 COM13 [VCP0] selected module v3.00 Device: Virgin-VM621i Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1603:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.597CA FF7.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 597CAFF7 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2AVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_28_SP1_V38__system_log_597CAFF7_C4B7397C_2009123 1-142650.B0X.bin Finished, time used: 3 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! thanks Infinity tem.................... |
The Following User Says Thank You to gsmshapon For This Useful Post: |
12-31-2009, 09:52 | #1682 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | 708X alcatel unlock done !! COM8 [VCP0] selected module v2.99 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2E03:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F6F9F 03C.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F6F9F03C rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, B9514FFC code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 169 provider: 708X-2CRGGB1 customization: CN16CC25 customization: XN16CC25 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CC25 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CC25 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_F6F9F03C_FC4F51B9_20 091231-004617.B0X.bin Finished, time used: 354 sec Remove/Install battery now ! thank infinity -team |
The Following User Says Thank You to msantar For This Useful Post: |
12-31-2009, 11:51 | #1683 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM8 [VCP0] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.75, database date: 21.12.2009): V800_GEMINI_PCB01_GPRS_MT6225_S00.V800_V01.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: V800_GEMINI_PCB01_GPRS_MT6225_S00.V800_V01.BIN ver. sw 2: V800.V01, 00000000 ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00F00000 flash: 89881200010001:89881200000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89881200010001:89881200000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 89881200010001:89881200000000 Finalization Done Finished, time used: 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-31-2009, 14:27 | #1684 (permalink) | |
Registered User Join Date: Mar 2006
Member: 247893 Status: Offline Thanks Meter: 82 | zte SFR231 UNLOCK DONE Quote:
The Following 2 Users Say Thank You to francogsm For This Useful Post: |
01-01-2010, 06:40 | #1685 (permalink) |
Freak Poster Join Date: Jan 2006 Location: India (Gujarat) Age: 36
Member: 223135 Status: Offline Sonork: 100.1592685 Thanks Meter: 177 | Succesfully Unlock Samsung S399 Cdma Successfully Unlock Samsung S399 Cdma In Infinity-Box COM5 [VCP0] selected module v1.09 Device: Samsung-SCH-S339 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to uttam For This Useful Post: |
01-01-2010, 14:16 | #1686 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | huawei T128 112calling restart phone problblem solve by infinity 1-try flash your phone 4 this file--Huawei-T128_2631-24P0-A050_2007-Aug-30_T128MZ_Airtel.B1M 2-right imei 100% tested solution by me see this log flashing log------------- ==== log: [1/1/2010 6:31:25 PM] ==== COM1 [VCP1] selected module v1.71 Device: Huawei-T128-HW-A Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 007 T128MZ 11 21 31 O Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-static_20100101-183145.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-security_20100101-183146.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-complete_20100101-183155.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Write Done Finished, time used: 252 sec Remove/Install battery now ! righting imei log------------------ COM1 [VCP1] selected module v1.71 Device: Huawei-T128-HW-A Checking data, wait... Action: "repair imei" new imei: 357563012820235 Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 007 T128MZ 11 21 31 O Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-static_20100101-183727.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-security_20100101-183728.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-complete_20100101-183736.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_imei-area_20100101-183801.B1E.bin warning: can't read lock-area backup critical area Done Check memory ... imei found #3 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 81 sec Remove/Install battery now ! Finished |
The Following User Says Thank You to Wasim007 For This Useful Post: |
01-02-2010, 08:49 | #1687 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP1] selected module v1.72 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20100102-121748.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20100102-121748.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20100102-121749.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20100102-121752.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to alis For This Useful Post: |
01-02-2010, 09:13 | #1688 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | VODAPHONE 541 UNLOCK OK COM4 [VCP0] selected module v2.97 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E703:A005 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FE0AE 01A.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: FE0AE01A rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 address offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDDE1 customization: CN17FB75 customization: XN17FB75 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_FE0AE01A_E8F450A0_20091228-123210.B0X.bin Finished, time used: 335 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
01-02-2010, 09:15 | #1689 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | LG GB102 4 UNIT UNLOCK COM4 selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091228-113957.B1E.bin loading data... data loaded imei: 35761602331773000 reading eeprom-security_35761602331773000... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602331773000_20091228-113958.B1E.bin reading eeprom-complete_35761602331773000... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602331773000_20091228-114004.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 20778350 Finished, time used: 26 sec Remove/Install battery now ! COM4 selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091228-113303.B1E.bin loading data... data loaded imei: 35761602399582400 reading eeprom-security_35761602399582400... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602399582400_20091228-113304.B1E.bin reading eeprom-complete_35761602399582400... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602399582400_20091228-113311.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 10750254 Finished, time used: 25 sec Remove/Install battery now ! COM4 selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091228-113520.B1E.bin loading data... data loaded imei: 35761602332155900 reading eeprom-security_35761602332155900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602332155900_20091228-113520.B1E.bin reading eeprom-complete_35761602332155900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602332155900_20091228-113527.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 40717559 Finished, time used: 26 sec Remove/Install battery now ! COM4 selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +3 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091228-113746.B1E.bin loading data... data loaded imei: 35399903721760700 reading eeprom-security_35399903721760700... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903721760700_20091228-113747.B1E.bin reading eeprom-complete_35399903721760700... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903721760700_20091228-113754.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 39078057 Finished, time used: 35 sec Remove/Install battery now ! |
01-02-2010, 12:53 | #1690 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | LG KG-300 Searching... Solved 100% COM4 [VCP0] selected module v3.00 Device: LG-KG300 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6227:8A02:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DONE flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD flash size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash chip: S_DONE flash id[0012]: 0098:007600A500C0 [TOSHIBA] TC58DVM92A1FT flash size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00047000 external RAM: S_DONE size: 00800000 boot style: S_NOR_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7312SA00-001 detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... rom info relocation detected warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN project-id: 7S7312SA00-001, 00000000 code offset: 00000000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... warning: incorrect header: 27DB3B553258CE28DBB5BCA5A1CC0893 nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... .................................................. .................................................. Disconnect... done Finished, time used: 1 min 2 sec Remove/Install battery now ! ~ZubairArain~ |
The Following User Says Thank You to ZubairArain For This Useful Post: |
01-03-2010, 06:42 | #1691 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Motorolla C117 ffs format OK COM4 [VCP0] selected Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 351972010769748 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _351972010769748_20100103-104053.18E.bin imei eeprom: 351972010769748 Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! ~ZubairArain~ |
01-03-2010, 06:43 | #1692 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | C117 Moto ffs format OK COM4 [VCP0] selected Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 351972010769748 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _351972010769748_20100103-104053.18E.bin imei eeprom: 351972010769748 Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! ~ZubairArain~ |
01-03-2010, 07:13 | #1693 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM8 [VCP0] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F503:0001 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.75, database date: 21.12.2009): HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37A_AL X_ML_A_3_V04.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S00.6302_C37A_AL X_ML_A_3_V04.BIN ver. sw 2: 6302_C37A_ALX_ML_A_3_v04, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-03-2010, 07:30 | #1694 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | mini n73 phone lock ok with formate ffs COM4 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:B424:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 28.04.2009): LCSH23_08A_PCB01_GPRS_MT6223P_S00.LKBCM01_8_28_1_2 T07M0730_M513.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: LCSH23_08A_PCB01_GPRS_MT6223P_S00.LKBCM01_8_28_1_2 T07M0730_M513.BIN ver. sw 2: LKBCM01.8.28.1.2T07M0730_M513, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00C00000 flash: 98000300000001:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00C80000 Detected ffs/eeprom address is non-standard: 00C80000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00C80000 detecting ffs/eeprom size... ffs/eeprom size: 00380000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00C80000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000001:2BEA0000000000 Finalization Done Finished, time used: 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-03-2010, 12:20 | #1695 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | LG-GB102 unlock done.... COM4 [VCP0] selected module v1.72 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 + Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20100103-031641.B1E.bin loading data... data loaded imei: 3539990343----- reading eeprom-security_3539990343-----... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903439-----0_20100103-031642.B1E.bin reading eeprom-complete_35399903439----00... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903439----0_20100103-031648.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 77090559 Finished, time used: 61 sec Remove/Install battery now ! |
The Following User Says Thank You to >>.123.<< For This Useful Post: |
