Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #181 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: GENCI-TITI POGRADEC ALBANIA
Member: 193804 Status: Offline Sonork: 100.1625629 Thanks: 175
| COM5 [VCP0] selected module v1.31 Device: BenQ-S660C Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... error: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Flash: 0089:88C500010001 file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20090522-155500.78F.bin Check Parameters Done Check Space... Flash: 0089:88C500010001 flash: Intel I28F320C3B-B B 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:88C500010001 Writing Done Finished, time used: 50 sec Remove/Install battery now ! THANK YOU INFINITY TEAM |
| The Following User Says Thank You to geti For This Useful Post: |
| | #183 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: india
Member: 573120 Status: Offline Thanks: 54
| before change sim jak do this first of all only repair with infinty if not succed then flash with 1270 file and repair eeprome file 10.6ae in support area and again repair and if need then unlock and user / phone/ unlock code . if not again succed then rebuild imei . post result , best of luck |
| The Following User Says Thank You to jagdish puri For This Useful Post: |
| | #184 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jul 2008
Member: 804466 Status: Offline Thanks: 44
| sfr 227 unlocked in 30 seconds COM3 [VCP0] selected module v1.60 Device: SFR-227 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: -FR-P108B1V1.0.0B03 Feb 27 2008 11 46 47 VDF-P108B1B02-FrEsPtIt- Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-static_20090523-154009.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-security_20090523-154009.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-complete_20090523-154011.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\SFR-227_lock-area_20090523-154015.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! thanks infinity |
| The Following User Says Thank You to moh032 For This Useful Post: |
| | #185 (permalink) |
| lg kg275 code read in infinity better than furious COM3 [VCP0] selected module v1.60 Device: LG-KG275 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL FR SFR KG275 P16 FL 33 V10a 208-10 JUN 22 2007 +1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20090523-194311.B1E.bin loading data... data loaded imei: 3585820107208**** reading eeprom-security_3585820107208****... file saved: D:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_35858201072087300_20090523-194311.B1E.bin reading eeprom-complete_3585820107208****... file saved: D:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_3585820107208****_20090523-194313.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 37988048 Finished, time used: 27 sec Remove/Install battery now ! |
| | #186 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: Ofcourse New Pakistan Age: 24
Member: 253510 Status: Online Sonork: 100.1592434 Thanks: 437
| zte A35 zte A35 dead successfully flash + unlock + imei change with infinity here is log files: here is flash + unlock logs ==== log: [5/24/2009 11:38:46 AM] ==== COM4 [VCP0] selected module v1.60 Device: ZTE-A35 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 7 P108A5V1.0.0B04 04.12.00 18.26.11 08.02.00 17 44 24 Jul 2 2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090524-113934.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090524-113935.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090524-113942.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 294 sec Remove/Install battery now ! here is imei change logs ==== log: [5/24/2009 11:45:35 AM] ==== COM4 [VCP0] selected module v1.60 Device: ZTE-A35 Checking data, wait... Action: "repair imei" new imei: 356985968958787 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: ARO-P108A7 Z B01-EnEs-PE02 g3dBV2.0 Sep 28 2007 04.12.00 18.26.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20090524-114553.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20090524-114554.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20090524-114600.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_imei-area_20090524-114620.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20090524-114640.B1E.bin backup critical area Done Check memory ... lock found imei found #1 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 114 sec Remove/Install battery now ! Finished |
| The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
| | #187 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM
Member: 488632 Status: Offline Thanks: 289
| w377 unock done COM1 [VCP0] selected module v1.32 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! rom version: 0411 Connecting... booting... finalizing... working, one more step... flash: 0089:8813 working... Finished, time used: 58 sec Remove/Install battery now ! |
| The Following User Says Thank You to yasermalik For This Useful Post: |
| | #188 (permalink) |
| Banned ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Age: 25
Member: 631286 Status: Offline Thanks: 350
| successfully unlock alcatel s210 COM6 [VCP0] selected module v1.32 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090524-041539.80E.bin Read data done Check data ... Check data done Write ... ......... ......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 78 sec Remove/Install battery now ! |
| The Following 2 Users Say Thank You to MOBIL CLINIC For This Useful Post: |
| | #190 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2004 Location: 29700A53 - BB PIN
Member: 91045 Status: Offline Sonork: 100.1577222 Thanks: 1,679
| ZTE-G X760 Unlock Done Thankx Infinity Team.... Code: COM7 [VCP0] selected module v2.74 Action: unlock unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:3B03:0000 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_B07A104 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302137111 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
| The Following 2 Users Say Thank You to Amir-SkillZ For This Useful Post: |
| | #191 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 26
Member: 171512 Status: Offline Thanks: 141
| NKTEL C2000 REPAIR OK WITH INFINTY COM3 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A303:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M380_CSTN_ABROAD_V1.0.2 Version: LONGYU25_06B_HW detecting structure #2... 0 6 done 44 byte(s) read imei: 35850114021584 connection Ok building list... done items to clear: 121 items cleared: 121 of 121 building list... done items remains: 0 Finished, time used: 22 sec Remove/Install battery now ! |
| The Following User Says Thank You to ehsas_ghum For This Useful Post: |
| | #192 (permalink) |
| NOKIA N99 ALIVE WITH INFINTY THANKS ALOT COM3 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:3241:C568 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: BB07_VIETNAM_V1.7_070125_TSB Version: BB07 detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 156 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 156 of 156 building list... done items remains: 0 Finished, time used: 75 sec Remove/Install battery now ! |
| | #193 (permalink) |
| NOKIA 6300 RESTART WITH SIM REPAIR OK WITH INFINTY COM3 [VCP0] selected module v2.82 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7923:926E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MV188_A_0712_FMBT_V20 Version: MV188_A_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 205 warning: wrong packet cs items cleared: 205 of 205 building list... done items remains: 0 Finished, time used: 31 sec Remove/Install battery now ! |
| | #194 (permalink) |
| MOTO C139 UNLOCK OK THANKS INFINTY TEAM KEEP IT UP COM3 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.24 HW version: _E88 LP ver: LPN_C139_NA2_00X Flex ver: FFN_C139_4R_10X imei otp: 010983002682875 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _010983002682875_20090525-150057.31E.bin imei eeprom: 010983002682875 Check Flash-2 Done Write... Write Done Finished, time used: 23 sec Remove/Install battery now ! |
| | #195 (permalink) |
| C2500 REPAIR OK WITH COMPLETE FFS FORMATE THANKS INFINTY TEAM COM3 [VCP0] selected module v2.74 Device: Kyocera-C2500 Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Kyocera-C2500__ffs... file saved: C:\Program Files\InfinityBox\MModule\Kyocera-C2500__ffs_20090526-122744.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 317 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
