11-23-2014, 15:41 | #20251 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung b189 unlock module v2.04 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 16 sec |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
11-23-2014, 15:56 | #20252 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
11-24-2014, 11:22 | #20255 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Micromax A120 Read info / Read Flash done Code: Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A1D8C46191 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A1D8C46191 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A1D8C46191 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A1D8C46191 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : Micromax ProdName : A120 ProdModel : Micromax A120 Device : A120 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__MICROMAX__Micromax_A120__ALPS.KK1.MP1.V2.10__Android_4.4.2__20140612_094519.ispff Done! Elapsed: 00:30:23 Reconnect Power/Cable! Format done Code: Operation : Format FileSystem [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A1D8C46191 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A1D8C46191 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Other : Set SpecFTM Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
The Following User Says Thank You to ishant For This Useful Post: |
11-24-2014, 15:36 | #20256 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 206 Read Code Done :) Code: Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 112211 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\3x_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface.. |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
11-24-2014, 19:50 | #20257 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Some MTK Android backups and problems Here is my experience with ZTE Grand X Pro / ZTE U983 : Flash readout: All seem is fine ... But if i try to write readout to phone CM-2 stay at 0% and do nothing: Well - nothing to do more, phone disconnected, SW restarted and seconf try: This seem must tell me that erase process = OK, but write is unsucessfull ... So => phone is dead ... P.S. Some readouts if can be usefull i can upload: 1. OT-6040X 2. Lenvo (clone) S960t 3. Huawei (clone) Honor 3CW 99,99% same phone as Lenovo S960t from up, but different brand. 4. Prestigio PAP5450Duo WBR, DebeliaMark, BG |
The Following User Says Thank You to debeliamark For This Useful Post: |
11-24-2014, 21:38 | #20258 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @debeliamark, thanks for the logs. By the way - please, always use latest version. I improve such things in every version, when get some new / different phones, so, things step-by-step become more stable. |
11-24-2014, 23:14 | #20259 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Icemobile Apollo Touch Read Info Code: Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:05 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Read error :( Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Skip HSUSB init NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Skip HSUSB init Read error :( Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Format not working Code: Operation : Format FileSystem [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block ERASE error with code 0x00000000 Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! ReadDebug Log not Working Code: Operation : Read DebugLog [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 2 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read error :( Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! I will unlock and read flash in factory file, if you want, i can upload for you. |
The Following 2 Users Say Thank You to JorgeVla For This Useful Post: |
11-25-2014, 08:51 | #20264 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | X2-00 Flash Done :) Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading MMC password... password not set :( Core : v1.98 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meaa CNT : rm618__08.35.image_meaa_0595308 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 08.35 Phone version : 08.25 19-05-11 RM-618 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000007EB2CA942519D395422E5CCBB237AB ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 3593490410xxxxx Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\3593490410xxxxx.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meaa Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meaa Total writen 101 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meaa_0595308 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meaa_0595308 Total writen 341 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X2-00 Software Info: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 3593490410xxxxx PPM version : V 08.35 09-01-12 RM-618 (c) Nokia MEA Product code: 0595304 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:47 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
11-25-2014, 10:36 | #20265 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile i9 MT6582 4.2.2 Pattern Lock Read by Infinity Box |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
