02-04-2015, 08:44 | #20986 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Read info Code: Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475806382ED9516D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475806382ED9516D [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : Micromax ProdName : A064 ProdModel : Micromax A064 Device : A064 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A064_SW_V8.0.2_HW_V1.0_20140731 Done! Elapsed: 00:00:14 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475806382ED9516D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475806382ED9516D [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A064 ProdModel : Micromax A064 Device : A064 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A064_SW_V8.0.2_HW_V1.0_20140731 [Read Ok] : preloader_huaqin71_cwet_i_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6571 / V1.1.1 / huaqin71_cwet_i_kk / EMMC FW Size : 805 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6571__Micromax__Micromax A064__A064__4.4.2__MMX_A064_SW_V8.0.2_HW_V1.0_20140731\ All done! Done! Elapsed: 00:03:52 Reconnect Power/Cable! |
The Following User Says Thank You to ishant For This Useful Post: |
02-04-2015, 09:39 | #20987 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Q mobile a500 factory file read Quote:
The Following 2 Users Say Thank You to FullFlashPak For This Useful Post: |
02-04-2015, 12:23 | #20988 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | spice qt 75 call log not showing, done with just format Start at : [2/4/2015 / 4:43:49 PM] Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 491 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! gurinder |
The Following User Says Thank You to gurinder For This Useful Post: |
02-04-2015, 14:00 | #20989 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nokia X Flashing Nokia X Flashing H/W V1 Flash Mode : Full Update Code: Core : v2.01 , NXP FlashEngine : v4.5 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Ok, Set : RM980_1.2.4.3_boot.img Ok, Set : RM980_1.2.4.3_cache.img Ok, Set : RM980_1.2.4.3_emmc_appsboot.mbn Ok, Set : RM980_1.2.4.3_emmc_appsboothd.mbn Ok, Set : RM980_1.2.4.3_fat.bin Ok, Set : RM980_1.2.4.3_oemsbl.mbn Ok, Set : RM980_1.2.4.3_oemsblhd.mbn Ok, Set : RM980_1.2.4.3_persist.img Ok, Set : RM980_1.2.4.3_preload.img Ok, Set : RM980_1.2.4.3_qcsbl.mbn Ok, Set : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Ok, Set : RM980_1.2.4.3_recovery.img Ok, Set : RM980_1.2.4.3_system.img Ok, Set : RM980_1.2.4.3_udisk.bin Ok, Set : RM980_1.2.4.3_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : F3B4D4FD Processing : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.2.4.3_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.2.4.3_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:06 Reboot phone Ok Connect phone on selected interface... Phone found! Nokia X Platform Phone detected (ADB) Read info... Ok |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
02-04-2015, 14:24 | #20990 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Nokia 130 Reset Security Code Done Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 277 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : BEE501DB4EDC18AFE03709E3007A02EF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 355759xxxxx4262 BBUID : BEE501DB4EDC18AFE03709E3007A02EF SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 355759xxxxx4262_MTK.mtsec Read Done! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 277 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : BEE501DB4EDC18AFE03709E3007A02EF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
02-04-2015, 15:50 | #20991 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Bro! Use Code: Code jpg images | |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
02-04-2015, 16:27 | #20992 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nokia 130 flashing NOKIA 130 FLASHING MODE : FullFlash Code: Core : v2.01 , MTKx FlashEngine : v6.8 Verify files ... MAUI : RM-1035_ROM_eMP_10.02.11 VIVA : RM-1035_VIVA_eMP_10.02.11 LANG : RM-1035_LANG_PACK_ROM_EH_eMP_10.02.11_001 CUST : RM-1035_CUSTPACK_ROM_EH_EURO_LV_eMP_10.02.11_001 JMPT : RM-1035_JUMP_TABLE_EH_EURO_LV_eMP_10.02.11_001 - > MODE : FullFlash Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 3564690635***** PPM version : MH Product code: 059W057 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 019B3C3335F9288DA73F9A074392AE80 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.02.11 SecureDecrypt : RM-1035_VIVA_eMP_10.02.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_EH_eMP_10.02.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_EH_EURO_LV_eMP_10.02.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_EH_EURO_LV_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 === Backup Enabled Reading RPL backup... Read Error : Not allowed === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001C000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.02.11 Write : RM-1035_LANG_PACK_ROM_EH_eMP_10.02.11_001 Write : RM-1035_CUSTPACK_ROM_EH_EURO_LV_eMP_10.02.11_001 Write : RM-1035_JUMP_TABLE_EH_EURO_LV_eMP_10.02.11_001 Write : RM-1035_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_EH_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_EH_EURO_LV_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_EH_EURO_LV_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:59 Reboot phone Ok ] |
02-05-2015, 09:34 | #20993 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | SAMSUNG S5 G900 READ FACTORY FILE Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D4330344745078D4A403101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7901004D4D4330344745078D4A403101 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : GT-I9008 ProdModel : GT-I9008 Device : GT-I9008 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_mbk72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_jb3 / EMMC FW Size : 678 MiB Scatter saved to : E:\QMOBILE ANDORID\SAMSUNG S5 G900 MT6572\MT6572__samsung__GT-I9008__GT-I9008__4.4.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:38 Reconnect Power/Cable! |
02-05-2015, 13:39 | #20994 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile X200 Read Full Info & Read Factory Flash File Done Code: Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 284 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930515A4CF78071D9 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930515A4CF78071D9 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : QMobile ProdName : QMobileX200 ProdModel : QMobileX200 Device : i3465 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : I3465_DI34651_QMOBILE-X200_L103 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 284 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930515A4CF78071D9 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930515A4CF78071D9 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobileX200 ProdModel : QMobileX200 Device : i3465 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : I3465_DI34651_QMOBILE-X200_L103 [Read Ok] : preloader_i3465.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : test.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / i3465 / EMMC FW Size : 1068 MiB Scatter saved to : C:\Users\Fahad Irfan\Desktop\Qmobile X200\MT6582__QMobile__QMobileX200__i3465__4.4.2__I3465_DI34651_QMOBILE-X200_L103\ All done! Done! Elapsed: 00:04:58 |
02-05-2015, 14:51 | #20995 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | DANY G5 GENIUS_TAB Read Full Info & Read Factory Flash File Done Code: Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 248 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433038475806B0970931E5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G80CM [eMMC] : FLASH_CID : 7001004D4D433038475806B0970931E5 [eMMC] : FLASH_LEN : 0x00000001CD000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : DANY ProdName : DANY ProdModel : G5 Device : GENIUS_TAB AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : XD918_v0.2_NSD_G5_2G_20140404 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 248 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433038475806B0970931E5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G80CM [eMMC] : FLASH_CID : 7001004D4D433038475806B0970931E5 [eMMC] : FLASH_LEN : 0x00000001CD000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : DANY ProdName : DANY ProdModel : G5 Device : GENIUS_TAB AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : XD918_v0.2_NSD_G5_2G_20140404 [Read Ok] : preloader_hexing82_tb_jb5.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / hexing82_tb_jb5 / EMMC FW Size : 934 MiB Scatter saved to : C:\Users\Fahad Irfan\Desktop\Dany Genius G5\MT6582__DANY__G5__GENIUS_TAB__4.2.2__XD918_v0.2_NSD_G5_2G_20140404\ All done! Done! Elapsed: 00:04:42 Reconnect Power/Cable! |
02-05-2015, 16:57 | #20996 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | Walton primo E1 Code: Operation : Check / Read Info [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 223 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done Initial info read Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Format FileSystem [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 223 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to mbiborna For This Useful Post: |
02-05-2015, 17:46 | #20997 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Nokia 220 Flashing Done Code: Core : v1.99 , MTKx FlashEngine : v6.5 Verify files ... MAUI : RM-969_ROM_eMP_10.03.11 VIVA : RM-969_VIVA_eMP_10.03.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 277 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 0ADDFA6BE1BB3219C7DB5745CAA8BA46 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_10.03.11 SecureDecrypt : RM-969_VIVA_eMP_10.03.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_10.03.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 Write : RM-969_VIVA_eMP_10.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_10.03.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_10.03.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.03.11 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_10.03.11 [VERIFY] DONE : RM-969_VIVA_eMP_10.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:54 Reboot phone Ok Connect phone on selected interface... |
02-05-2015, 20:38 | #20998 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A5s Format Done Operation : Check / Read Info [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758541032275157 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758541032275157 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : alps ProdName : a2_qy_a5s ProdModel : A5s Device : a2_qy_a5s AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : UTLA5sv1013_11042014 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Format FileSystem [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758541032275157 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758541032275157 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-05-2015, 20:51 | #20999 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | LAVA iris 405+ Read Factory Firmware & Format Done Operation : Check / Read Info [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201AFEEC84D41C3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201AFEEC84D41C3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : iris ProdName : 405+ ProdModel : iris405+ Device : iris405+ AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201AFEEC84D41C3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201AFEEC84D41C3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : iris ProdName : 405+ ProdModel : iris405+ Device : iris405+ AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_lava72_sp01w.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lava72_sp01w / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__iris__iris405+__iris405+__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:26 Reconnect Power/Cable! Operation : Format FileSystem [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201AFEEC84D41C3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201AFEEC84D41C3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
02-05-2015, 20:53 | #21000 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A20 Format Done Operation : Check / Read Info [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344728057FDEF4B05F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D30344728057FDEF4B05F [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : Karbonn ProdName : Karbonn A20 ProdModel : Karbonn A20 Device : Karbonn_A20 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D30344728057FDEF4B05F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D30344728057FDEF4B05F [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:03:10 Reconnect Power/Cable! |
