02-10-2015, 14:51 | #21046 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Code: Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 247 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201730286F590B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201730286F590B5 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : alps ProdName : GT-I9600 ProdModel : GT-I9600 Device : GT-I9600 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 247 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201730286F590B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201730286F590B5 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : GT-I9600 ProdModel : GT-I9600 Device : GT-I9600 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.2 [Read Ok] : preloader_lightning89_wet_lca.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lightning89_wet_lca / EMMC FW Size : 550 MiB Scatter saved to : C:\Users\Fahad Irfan\Desktop\GT-I9600\MT6572__alps__GT-I9600__GT-I9600__4.2.2__ALPS.JB3.MP.V1.2\ All done! Done! Elapsed: 00:03:11 Reconnect Power/Cable! Operation : Read NVRAM [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 247 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201730286F590B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201730286F590B5 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, MT6572_eMMC.spnv saved Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
02-10-2015, 15:34 | #21047 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | i9500 mt6575 NAND format done Code: Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [HYNIX] H8BCS0PG0MBP [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [HYNIX] H8BCS0PG0MBP [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, i9500-MT6575_NAND.spnv saved Done! Elapsed: 00:00:26 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0068 , [HYNIX] H8BCS0PG0MBP [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to cheddihouse For This Useful Post: |
02-10-2015, 15:39 | #21048 (permalink) |
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | condor c7 mini PGN-404 full service Code: Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42017032DC5D9193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42017032DC5D9193 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : condor ProdName : condor ProdModel : PGN-404 Device : condor AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42017032DC5D9193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42017032DC5D9193 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : condor ProdName : condor ProdModel : PGN-404 Device : condor AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_gionee82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : spdata.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / gionee82_cwet_kk / EMMC FW Size : 1324 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__condor__PGN-404__condor__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:12 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42017032DC5D9193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42017032DC5D9193 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, c7-mini-MT6582_eMMC.spnv saved Done! Elapsed: 00:00:30 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42017032DC5D9193 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42017032DC5D9193 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : condor ProdName : condor ProdModel : PGN-404 Device : condor AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 Saved to : G:\china\Phone\Infinitybox\MT6582__CONDOR__PGN-404__ALPS.KK1.MP1.V2.10__Android_4.4.2__20141015_065918.ispff Done! Elapsed: 00:29:10 Reconnect Power/Cable! |
02-10-2015, 15:41 | #21049 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | lumia 620 flash done Core : v2.01 , WP8x FlashEngine : v7.9 FFU : RM846_3058.50000.1440.0001_RETAIL_lta_brazil_211_0 1_455602_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P5122 FFU RootKeyHash : 67131691EEDD1F38568C7FFAE284FB2621680FEA FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x62440000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.14 Protocol Implementation : 1.25 === Phone Initial info : Phone RMxxx ID : RM-846 Phone Model ID : Nokia.MSM8227.P5122.1.2 Phone Model PC : 059R8L1 Phone IMEI : 356347051500945 === eMMC info : eMMC Vendor : Unknown eMMC CID : 0090 eMMC Size : 7400 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 67131691EEDD1F38568C7FFAE284FB2621680FEA === Other info : SD present : False FFU : RM846_3058.50000.1440.0001_RETAIL_lta_brazil_211_0 1_455602_prd_signed.ffu Checking... Device RootKey Match with FFU RootKey! Device ProductID Match with FFU ProductID! ProductID : Nokia.MSM8227.P5122 DevRKH : 67131691EEDD1F38568C7FFAE284FB2621680FEA All Ok, Continue flashing... FFU : RM846_3058.50000.1440.0001_RETAIL_lta_brazil_211_0 1_455602_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Total flash time : 00:06:31 Rebooting Connect phone on selected interface... |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
02-10-2015, 15:41 | #21050 (permalink) |
02-10-2015, 16:27 | #21051 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | VGOTEL Venture_V2 Read Flash Code: Chinese Miracle II [MTK module] v 1.11 Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D0246E5808680AD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0246E5808680AD [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : VGOTel ProdName : Venture V2 ProdModel : Venture V2 Device : Venture_V2 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : 2013-9-09 17:54:01 [Read Ok] : preloader_konka72_i120_emmc_jb3.b [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / konka72_i120_emmc_j / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__VGOTel__Venture V2__Venture_V2__4.2.2__2013-9-09 175401\ All done! Done! Elapsed: 00:03:33 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
02-11-2015, 09:53 | #21052 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 206 Flash Done :) Code: Phone found! Series 40 Device detected! read info... - Ok Reading MMC password... password not set :( Core : v2.01 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059V0F5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 04.52 Phone version : 04.52 30-06-13 RM-872 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 3564560653xxxx IMEI 2 : 3564560653xxxx PCcode : 059Q4L5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+BEST\InfinityBox\BEST\Backup\Cert\3564560653xxxxx_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059V0F5 Image : package_m2_059V0F5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xA340 Flashing done! Total flash time : 00:03:11 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 3564560653xxxxx PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4L5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
02-11-2015, 09:54 | #21053 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Videocon A29 Stuck Done By Format FFS ( Back Again ) Read Info Code: Chinese Miracle II [MTK module] v 1.11 Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020CDD606CD001 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020CDD606CD001 [eMMC] : FLASH_LEN : 0x00000000E2C00000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : alps ProdName : Videocon ProdModel : A29 Device : uniscope72_wet_b1_jb3 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:50 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020CDD606CD001 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020CDD606CD001 [eMMC] : FLASH_LEN : 0x00000000E2C00000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
02-11-2015, 10:44 | #21054 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | HUAWEI Hol-U19 Code: Chinese Miracle II [MTK module] v 1.11 Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3858564D4206773FD46191A7 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D4206773FD46191A7 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : HUAWEI ProdName : Hol-U19 ProdModel : Hol-U19 Device : HWHol-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : Holly-U19V100R001C328B106_C [Read Ok] : preloader_huaqin82_wet_b2b_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / huaqin82_wet_b2b_kk / EMMC FW Size : 1188 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__HUAWEI__Hol-U19__HWHol-U__4.4.2__Holly-U19V100R001C328B106_C\ All done! Done! Elapsed: 00:05:35 Reconnect Power/Cable! |
02-11-2015, 10:46 | #21055 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | QMobile A750 NOIR4 Code: Chinese Miracle II [MTK module] v 1.11 Start at : [2/11/2015 / 1:12:50 PM] Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045B801C71 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A2711C805B [eMMC] : FLASH_LEN : 0x00000003AB800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : =QMobile ProdName : =NOIR4 ProdModel : =NOIR4 Device : =NOIR4 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_s9111b.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / s9111b / EMMC FW Size : 1447 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6589__=QMobile__=NOIR4__=NOIR4__4.2.1__ALPS.JB2.MP.V1.2\ All done! Done! Elapsed: 00:06:49 Reconnect Power/Cable! Finish at : [2/11/2015 / 1:19:41 PM] |
02-11-2015, 11:12 | #21056 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | NOKIA 225 RM-1012 FLASH DONE !!! Core : v1.98 , MTKx FlashEngine : v6.0 Verify files ... MAUI : RM-1012_ROM_eMP_21.00.11 VIVA : RM-1012_VIVA_eMP_21.00.11 LANG : RM-1012_LANG_PACK_ROM_EI_eMP_21.00.11_002 CUST : RM-1012_CUSTPACK_ROM_EI_EURO_RU_eMP_21.00.11_002 JMPT : RM-1012_JUMP_TABLE_EI_EURO_RU_eMP_21.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 77 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 408C6ADE7F45DABDEF18C9873178A909 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1012_ROM_eMP_21.00.11 SecureDecrypt : RM-1012_VIVA_eMP_21.00.11 SecureDecrypt : RM-1012_LANG_PACK_ROM_EI_eMP_21.00.11_002 SecureDecrypt : RM-1012_CUSTPACK_ROM_EI_EURO_RU_eMP_21.00.11_002 SecureDecrypt : RM-1012_JUMP_TABLE_EI_EURO_RU_eMP_21.00.11_002 OVRLP : 000069B900000001 PHPID : PEARL.21.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1012_ROM_eMP_21.00.11 Write : RM-1012_LANG_PACK_ROM_EI_eMP_21.00.11_002 Write : RM-1012_CUSTPACK_ROM_EI_EURO_RU_eMP_21.00.11_002 Write : RM-1012_JUMP_TABLE_EI_EURO_RU_eMP_21.00.11_002 Write : RM-1012_VIVA_eMP_21.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1012_ROM_eMP_21.00.11 [VERIFY] DONE : RM-1012_LANG_PACK_ROM_EI_eMP_21.00.11_002 [VERIFY] DONE : RM-1012_CUSTPACK_ROM_EI_EURO_RU_eMP_21.00.11_002 [VERIFY] DONE : RM-1012_JUMP_TABLE_EI_EURO_RU_eMP_21.00.11_002 [VERIFY] DONE : RM-1012_VIVA_eMP_21.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:49 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Unlocker_001 For This Useful Post: |
02-11-2015, 11:36 | #21057 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Intex Aqua 3g Stuck Done By Format@FFS Read Info Code: Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007E , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [32] Initial info read Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Format FFS Code: Operation : Format FileSystem [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007E , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
02-11-2015, 13:30 | #21060 (permalink) |
Junior Member Join Date: Nov 2014 Location: INDIA
Member: 2290533 Status: Offline Sonork: 100.1615863 Thanks Meter: 18 | MICROMAX A065 HANG ON LOGO DONE:CM2MTK FULL LOGS HERE--------- Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580641690571AF DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580641690571AF [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580641690571AF DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580641690571AF [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to INDIAN-KING For This Useful Post: |
