Old 05-20-2010, 15:32   #2491 (permalink)
Member: 249061
COM2 [VCP0] selected
module v3.30
Action: "sp-unlock"
unlock method: smart fast
Model: ZTE-X760
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:ED03:000F
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X760_Z15FR_FS_BFFA106
Version: ZTEMT25_07A_HW_D
44 byte(s) read
imei: 35235302722886
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 1 min 32 sec
Remove/Install battery now !
The Following User Says Thank You to gsm_jaja For This Useful Post:
Old 05-21-2010, 09:06   #2492 (permalink)
geti's Avatar
Member: 193804
Sonork: 100.1625629
zte g-x760 unlock ok
COM6 [VCP0] selected
module v3.38
Action: "sp-unlock"
Model: ZTE-X760
19200 autodetect
CPU: MT6225
chip: 0001:A603:000C
status: FF
Date: 2006.06.14
Version: 1.0
Version: X760_Z10UK_GD_BFFA112
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35897503158855
connection Ok
157 byte(s) read
reading data...
reading data #2...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
The Following User Says Thank You to geti For This Useful Post:
Old 05-21-2010, 20:20   #2493 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Phone must be in TEST-MODE: * + # + Power
Conectando. Aguarde...
Phone found, wait...
Conectado
Unlocking...
IMEI: 356125003564502
SEC ver: 01.21g(0002)
SW ver: 00.00:18:22:C04.01
MMI ver: Mmi:X400VA20.LP0521.ANM_v03,Oct15200411:26:42
Lendo eeprom-security_356125003564502...
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Panasonic-X400_eeprom-security_356125003564502_20100521-161646.08E.bin
Lendo eeprom-static_356125003564502...
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Panasonic-X400_eeprom-static_356125003564502_20100521-161649.08E.bin
Found: Network
Feito
Finished
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Old 05-21-2010, 21:44   #2494 (permalink)
jepetu's Avatar
Member: 181633
Coral 655 Unlock Ok!!! Pinout in Shell is wrong, correct pinout is like SFR 341 (ZTE X760, etc)
COM5 [VCP0] selected
module  v3.38
Action: "sp-unlock"
Model: Coral-655
19200 autodetect
CPU: MT6225
chip: 0001:D803:000B
status: FF
Date: 2006.06.14
Version: 1.0
Version: C2016HW_2.5_EU_DIGICEL
Version: C2016_EU
44 byte(s) read
imei: 35772902033015
connection Ok
157 byte(s) read
reading data...
reading data #2...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 47 sec
The Following User Says Thank You to jepetu For This Useful Post:
Old 05-22-2010, 07:06   #2495 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
COM33 [VCP0] selected
module v1.78
Device: Zong-A136
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20100516-173228.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20100516-173230.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20100516-173236.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20100516-173249.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 52 sec
The Following User Says Thank You to msashami For This Useful Post:
Old 05-22-2010, 07:15   #2496 (permalink)
yasermalik's Avatar
Member: 488632
ALCATEL CRYSTAL SUCCESSFULL UNLOCK
COM41 [VCP0] selected
module v3.38
Device: Alcatel-KR01x, Crystal
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:EB03:A001
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98006F00000003:08EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F9C6E E62.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_CA401D03].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: F9C6EE62
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 031D40CA
code offset: 00020000
ffs offset/size [01]: 01000000/00FE0000
TCL-ID identification
version: 352
provider: KR01X-2BTWGB1
customization: CJ35DL18
customization: XJ35DL18
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01000000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35644203032358
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-KR01x,Crystal_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI _06B_W07_28_SP1_V38__system_log_F9C6EE62_CA401D03_ 20100520-065744.B0X.bin
Finished, time used: 5 min 27 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to yasermalik For This Useful Post:
Old 05-22-2010, 08:23   #2497 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
module v1.39
Device: LG-KP110
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 3520080xxxx3512
file saved: C:\Program Files\InfinityBox\LGA\eeprom_3520080xxxx3512_LG-KP110_20100522-121549.B1E.bin
reading _eeprom-ffs_3520080xxxx53512...
file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_3520080xxxx3512_LG-KP110_20100522-122004.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 301 sec
Old 05-22-2010, 14:24   #2498 (permalink)
Member: 846805
COM3 [VCP0] selected
Mَdulo v3.38
Action: "sp-unlock"
Método de Destravamento: Inteligente
Modelo: ZTE-X761
Verificando Dados. Aguarde...
O Telefone Deverل Estar DESLIGADO!
Pressione e SEGURE o Botمo de Ligar!
19200 autodetect
Inicializando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:CA03:0008
status: FF
Solte o Botمo de Ligar!
Telefone Encontrado. Aguarde...
Data: 2006.06.14
Versمo: 1.0
Versمo: X761_Z5_Es_BFFA102
Versمo: ZTEMT25_07A_HW_C
44 byte(s) read
IMEI: 35787302452775
Conectado
157 byte(s) read
Lendo Dados...
reading data #4...
Construindo Novos Dados...
Escrevendo Dados...
145 byte(s) read
Lendo Dados...
972 byte(s) read
Escrevendo Dados...
verifying...
Verificado
Feito
Finalizado. Tempo Gasto: 16 sec
Remova/Recoloque a Bateria!
Old 05-22-2010, 15:00   #2499 (permalink)
ehsas_ghum's Avatar
Member: 171512
nokia 6300 repair done
COM21 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6219:8A01]...
CPU: MT6219
high speed boot On
Boot Done
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
interesting cpu type found
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info ver: 04
sw version: LONGYU19_07B_GEMINI_PCB01_GPRS_MT6219_EV.MAUI_07B_ W08_28_MP_V11.BIN
project-id: MAUI.07B.W08.28.MP.V11, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 44 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 05-23-2010, 08:55   #2500 (permalink)
nishue's Avatar
Member: 576633
LG KG110 user cord reset ok !
COM4 [VCP0] selected
module v1.39
Device: LG-KG110
Action: reset
Boot ...
Connecting, wait...
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 355995011739903
current otp imei: 355995011739903
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995011739903_LG-KG110_20100523-131620.B1E.bin
version: 602-03V10b20KG110P40
reading 602-03V10b20KG110P40_eeprom-ffs_355995011739903...
file saved: C:\Program Files\InfinityBox\LGA\602-03V10b20KG110P40_eeprom-ffs_355995011739903_LG-KG110_20100523-132014.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 278 sec
thankx teem !
The Following User Says Thank You to nishue For This Useful Post:
Old 05-23-2010, 09:35   #2501 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
COM20 [VCP1] selected
module v3.07
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001503:0004
status: FF
Boot Done
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
New firmware detected (v.3.07, database date: 16.01.2010):
M_LC0_PCB01_GPRS_MT6225_S00.B001_2_GEMINI_W08_12_M _LC0_M01.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: mt62xx@gmail.com or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: M_LC0_PCB01_GPRS_MT6225_S00.B001_2_GEMINI_W08_12_M _LC0_M01.BIN
project-id: B001_2.GEMINI.W08.12.M_LC0_M01, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: M_LC0_PCB01_GPRS_MT6225_S00.B001_2_GEMINI_W08_12_M _LC0_M01__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M_LC0_PCB01_GPRS_ MT6225_S00.B001_2_GEMINI_W08_12_M_LC0_M01__ffs_201 00522-133201.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 6 sec
The Following 2 Users Say Thank You to cel_phon For This Useful Post:
Old 05-23-2010, 11:05   #2502 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
COM20 [VCP0] selected
module v3.07
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:9603:0002
status: FF
Date: 2006.06.14
Version: 1.0
Version: BB33_CY_L11EN_AR_313_091109_HX8340_BYD_SP128NB0_CT F_BT_FM_G
Version: 25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35341900143093
connection Ok
building list...
done
items to clear: 160
warning: wrong packet cs
items cleared: 160 of 160
building list...
done
items remains: 0
Finished, time used: 25 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 05-23-2010, 11:05   #2503 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
module v3.07
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
building list...
done
items to clear: 160
building list...
done
items remains: 0
Old 05-23-2010, 11:32   #2504 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
=> module version: v.
=> operation (3) started: COM3
==> get_dll_version
dll version: 38.0i
==> set_com_port
==> set_baud_rate
==> set_v24_mode
==> set_baud_rate
==> check_comm_link
==> get_ms_id
imei: 353081034753692
==> get_sw_version
sw ver: P1.2PU02V01.01
==> get_sec_version
sec ver: 00.31Et(4242)
==> get_eep_version
eep version: 000C
==> get_eep_revision
eep revision: 0000
==> reading...
access result: 00
access level: 03
==> set required mode...
==> reboot...
==> reading...
lock result: 00
lock status: 020A
==> unlock...
verification result: F0600100561200FF00040105020503050405000000000000
==> restore original mode...
last error: No errors
=> operation finished
==> close_com_port
Finished, time used: 20 sec
Power Off/On phone now !
Old 05-23-2010, 12:35   #2505 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
module v1.39
Device: LG-KP170 (under test)
Action: reset
Boot ...
Connecting, wait...
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 350305260000001
file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100522-162957.B1E.bin
reading _eeprom-ffs_350305260000001...
file saved: C:\Documents and Settings\Administrator\Desktop\_eeprom-ffs_350305260000001_LG-KP170 (under test)_20100522-163428.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 346 sec
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 1.15980 seconds with 12 queries
