04-27-2010, 05:09 | #2551 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v1.72 Device: LG-KG275 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL PT TMN KG275 P16 FL 351 V10b 268-06 MAY 29 2007 +3 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20100426-210851.B1E.bin loading data... data loaded imei: 35744501217708100 reading eeprom-security_35744501217708100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_35744501217708100_20100426-210851.B1E.bin reading eeprom-complete_35744501217708100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35744501217708100_20100426-210852.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 19 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
04-27-2010, 05:26 | #2552 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | 541 vodafone unlock successfull!! COM3 [VCP0] selected module v3.33 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2A03:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D8C7A C60.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D8C7AC60 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2FVDAU1 customization: CN17FL75 customization: XN17FL75 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FL75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FL75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703403241 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_D8C7AC60_E8F450A0_20100426-142233.B0X.bin Finished, time used: 4 min 11 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Br Kmax |
The Following 3 Users Say Thank You to kmaxmax For This Useful Post: |
04-27-2010, 05:29 | #2553 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: nakodar
Member: 903492 Status: Offline Sonork: 1590666 Thanks Meter: 571 | Quote:
nc sharing bro....................... | |
The Following User Says Thank You to ^^^RAVI SOOD^^^ For This Useful Post: |
04-27-2010, 08:25 | #2554 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | => module version: v. => operation (3) started: COM3 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081034812274 ==> get_sw_version sw ver: P1.2PU02V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! |
04-27-2010, 08:31 | #2555 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | 6300 dead ok COM3 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:6203:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: K300_PCB01_GPRS_MT6225_S00.MT6225_GEMINI_V1_00.BIN project-id: MT6225_GEMINI_V1.00, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: K300_PCB01_GPRS_MT6225_S00.MT6225_GEMINI_V1_00__ff s... file saved: C:\Program Files\InfinityBox\ChineseMiracle\K300_PCB01_GPRS_M T6225_S00.MT6225_GEMINI_V1_00__ffs_20100427-000612.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 4 min 52 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to saqi160 For This Useful Post: |
04-27-2010, 11:57 | #2556 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | !! LG KG300 Success reapaired Blinking !! COM3 [VCP0] selected module v3.07 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6227:8A02:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DONE flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD flash size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash chip: S_DONE flash id[0012]: 0098:007600A500C0 [TOSHIBA] TC58DVM92A1FT flash size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00047000 external RAM: S_DONE size: 00800000 boot style: S_NOR_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7312SA00-001 detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001.BIN project-id: 7S7312SA00-001, 00000000 code offset: 00000000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... warning: incorrect header: 1D98306A04922786687D8835D161E2A2 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... 00000000-03FFFFFF... Disconnect... done Finished, time used: 37 sec Remove/Install battery now ! |
The Following User Says Thank You to azeem781986 For This Useful Post: |
04-27-2010, 12:42 | #2557 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>>zte x761 unlock ok infinity-box<<<<< COM4 [VCP1] selected module v3.37 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X761 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5A03:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_BFFA108 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35235302229127 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to shahid41 For This Useful Post: |
04-27-2010, 13:16 | #2558 (permalink) |
No Life Poster Join Date: Jan 2009 Location: aurangabad
Member: 937338 Status: Offline Sonork: 100.1651155 Thanks Meter: 114 | sucsessful unlock vodafone 226 module v1.76 Device: Vodafone-226FM Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20030101-003357.B1E.bin loading data... data loaded reading eeprom-security... file saved: E:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20030101-003358.B1E.bin reading eeprom-complete... file saved: E:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20030101-003403.B1E.bin reading additional data... file saved: E:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20030101-003409.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 15 sec Remove/Install battery now ! |
The Following User Says Thank You to VINOD399 For This Useful Post: |
04-27-2010, 13:18 | #2559 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 357456017076160 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017076160_LG-KG290_20100427-051750.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... current eeprom imei: 357456017076160 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! |
04-27-2010, 13:27 | #2560 (permalink) |
Member: 937338 Status: Offline Sonork: 100.1651155 Thanks Meter: 114 | sucessfuly unlock samsumg s299 module v1.14 Device: Samsung-SCH-S299 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 13 sec Remove/Install battery now ! operation terminated by user error: operation failed Finished, time used: 13 sec Remove/Install battery now ! |
04-27-2010, 13:33 | #2561 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.39 Device: LG-KG291i Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 357456017076160 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017076160_LG-KG291i_20100427-052658.B1E.bin .................................................. .............. reading _eeprom-ffs_357456017076160... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_357456017076160_LG-KG291i_20100427-053132.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 368 sec Remove/Install battery now ! |
04-27-2010, 14:11 | #2562 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP1] selected Mَdulo v3.04 Dispositivo: Vodafone-541 Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F903:A00A status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 98006F00000004:09EA0000000000 Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.9 A4C2936.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 9A4C2936 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification Versمo: 17B provider: 708X-2EVDPT1 Customizaçمo CN17FG72 Customizaçمo XN17FG72 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... Erro: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Customizaçمo XN17FG72 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Customizaçمo XN17FG72 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: 00000000000000 Flash 98006F00000004:09EA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 98006F00000004:09EA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_9A4C2936_E8F450A0_20100427-100852.B0X.bin Finalizado. Tempo Gasto: 8 min 1 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
04-27-2010, 14:15 | #2563 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | China iphone repair ok Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
04-27-2010, 14:16 | #2564 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | Huwaei t161l unlock ok Quote:
04-27-2010, 18:58 | #2565 (permalink) |
Freak Poster Join Date: Oct 2006 Location: TUNISIA Age: 43
Member: 367280 Status: Offline Thanks Meter: 57 | Ot505 unlocked I USED PINFINDER AND I SELECT ALCATEL C700 FROM LIST OF PINOUT AND CABLE IS L10C COM4 [VCP0] selected module v3.34 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B1C8:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A967C 360.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_5434F94E].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A967C360 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 4EF93454 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 265 provider: 505X-2ASFFR1 customization: CP26CQ22 customization: XP26CQ22 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP26CQ22 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35777003023150 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_A967C360_5434F94E_20100427-190350.B0X.bin Finished, time used: 3 min 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to souheilh For This Useful Post: |
