06-26-2010, 14:34 | #3031 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C703:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4DFFFDFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18D09FC518D09FC518D09FC518D09FC518D09FC518D09FC5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 13.06.201): HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN project-id: B1.COMP_TT.GFIVE.FAT.1, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4DFFFDFFF:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HEXING2_GEMINI_PCB1_GPRS_MT25_S0B1_COMP_TT_GFIVE_F AT_1BIN__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING2_GEMINI_PC B1_GPRS_MT25_S0B1_COMP_TT_GFIVE_FAT_1BIN__ffs_2010 0626-063217.B0E.bin flash: 2088C4DFFFDFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4DFFFDFFF:2088C400000000 Finalization Done Finished, time used: 2 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
06-26-2010, 14:57 | #3032 (permalink) | ||
No Life Poster Join Date: Oct 2006 Location: Chennai - India Age: 37
Member: 372320 Status: Offline Sonork: 100.113211 Thanks Meter: 2,661 | no need internet no user name no pass word no need waiting no validity only onlock fast fast COM62 [QCUSB_COM62_1] selected module v1.04 Device: ZTE-C370 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec COM2 [QCUSB_COM2_2] selected module v1.04 Device: Haier-C5100 Action: "sp-unlock" Phone should be Switched ON ! connecting... checking version... C5100-HSP-R00.00.37 HAIER C5100 version 37 selected.. Sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 20 sec Thanks For Test report Wait and See .. you will Be happy Beyond you Regards Ram Quote:
The Following 9 Users Say Thank You to Chennairam For This Useful Post: |
06-26-2010, 16:25 | #3033 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | lg kp320 stuck at lg logo done with infinity here is log COM4 [VCP0] selected module v3.41 Device: LG-KP320 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610SA00-002-R1C detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN project-id: 7S7610SA00-002-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
06-26-2010, 17:23 | #3034 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP1] selected Mَdulo v1.38 Dispositivo: Alcatel-E221 "Detecçمo Avançada do Chip" Ativada Açمo: Destravar Verificando Dados. Aguarde... Boot ... O Telefone Deverل Estar DESLIGADO! Pressione o Botمo LIGAR Agora! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Determinar Velocidade ... 115200 Determinar Velocidade done Check hardware ... Flash 012A7E2A242A00:54000000000000 Flash AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... Lendo Alcatel-E221_eeprom_calibration-1... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20100626-132146.80E.bin Read data done Check data ... Check data done Escrever ... .......... .......... .. Flash 012A7E2A242A00:54000000000000 Escrever simlock Escrever done Finalizado. Tempo Gasto: 2 min 8 sec Remova/Recoloque a Bateria! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
06-26-2010, 17:27 | #3035 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | Nokia 1661-2b whit jaf interface unlock perfect Port COM1 open OK Connect phone on selected interface... Wait... Phone found... Phone in Error mode Seting Local mode... Local mode set Phone connected - Ok IMEI 011885001233510 Read Lock Info Locked to T-Mobile;U.S.A. Unlocking... Unlock - Ok Port COM1 close |
The Following User Says Thank You to thewolverine For This Useful Post: |
06-26-2010, 17:56 | #3036 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | OT-203X UNLOCKED module v3.46 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5A58:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37M provider: 203X-2BRGTE5 customization: CM37CC31 customization: XM37CC31 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM37CC31 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908003186717 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100626-095220.B0X.bin Finished, time used: 1 min 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
06-27-2010, 08:03 | #3037 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Vodafon 225 Unlock done ! COM10 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -SA-P108A2 SST V1.0.0B11 Jul 18 2008 12 29 51 VDF-P108A2B07-RoFr Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20100627-123034.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20100627-123035.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20100627-123041.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20100627-123053.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! |
The Following User Says Thank You to nishue For This Useful Post: |
06-27-2010, 09:43 | #3038 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM10 [Serial2] selected module v3.15 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3F03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S4_TOSHIBA_EFIAPVRHMIT_V034 Version: A760_V3.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35464400213230 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 done 209 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
06-27-2010, 10:23 | #3039 (permalink) |
Freak Poster Join Date: Feb 2010 Location: india (telangana state) Age: 46
Member: 1230663 Status: Offline Sonork: 100.1593487 Thanks Meter: 174 | COM9 selected module v1.04 Device: LG-3500 Action: "sp-unlock" Phone should be Switched ON ! connecting... RD350F09 LG RD-3500 version 9 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following 9 Users Say Thank You to .::VENUGOPAL::. For This Useful Post: |
06-27-2010, 10:41 | #3040 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | lg3100 v4 COM2 [Serial0] selected module v1.04 Device: LG-3100 Action: "sp-unlock" Phone should be Switched ON ! connecting... change baudrate... RD310F04 LG RD-3100 version 4 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 39 sec lg3000 v9 COM2 [Serial0] selected module v1.04 Device: LG-3000 Action: "sp-unlock" Phone should be Switched ON ! connecting... change baudrate... checking version... RD300F09 LG RD-3000 version 9 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 39 sec lg 3500 v8 COM1 [LGSIDIAG1] selected module v1.04 Device: LG-3500 Action: "sp-unlock" Phone should be Switched ON ! connecting... RD350F08 LG RD-3500 version 8 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 22 sec abhishek |
The Following 9 Users Say Thank You to abhishek aga For This Useful Post: |
06-27-2010, 12:33 | #3041 (permalink) |
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | Huawei c5300 COM2 [Serial0] selected module v1.04 Device: Huawei-C5300 Action: "sp-unlock" Phone should be Switched ON ! connecting... sending comand... disabling minlock... Phones should be restarting now... Finished, time used: 19 sec abhishek |
The Following 10 Users Say Thank You to abhishek aga For This Useful Post: |
06-27-2010, 13:24 | #3042 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>ot s520x unlock ok infinity-box<<<< COM4 [VCP1] selected module v3.45 Device: Alcatel-S520X, S520A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:B903:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C3369 BA2.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_A0F6FAFB].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C3369BA2 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, FBFAF6A0 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 458 provider: S520X-2AVRGB1 customization: CD45DA50 customization: XD45DA50 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XD45DA50 customization name adjusted flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35198902137257 flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S520X,S520A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_C3369BA2_A0F6FAFB_20 100627-100712.B0X.bin Finished, time used: 1 min 48 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to shahid41 For This Useful Post: |
06-27-2010, 13:32 | #3043 (permalink) |
Freak Poster Join Date: Jun 2007 Location: pakistan
Member: 525998 Status: Offline Thanks Meter: 57 | LG KG290 COM6 [VCP0] selected module v1.38 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 357456016XXXXXX file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456016713XXXX_LG-KG290_20100627-051415.B1E.bin .............. Check flash Done Check space ... current eeprom imei: 35745601671XXXX .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 61 sec Remove/Install battery now ! |
The Following User Says Thank You to afridi4all For This Useful Post: |
06-27-2010, 13:34 | #3044 (permalink) |
Member: 525998 Status: Offline Thanks Meter: 57 | LG C3300 COM4 [VCP0] selected Device: LG C3300 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3582160007xxxxx file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_3582160007xxxx _LG C3300_20100516-121239.B1E.bin .. Check flash Done Check space... current eeprom imei: 3582160007XXXX .......................... finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 35 sec Remove/Install battery now ! |
06-27-2010, 13:37 | #3045 (permalink) |
Member: 525998 Status: Offline Thanks Meter: 57 | VODAFONE 340 COM4 [VCP0] selected module v3.33 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1803:A008 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 3559220309xxxx connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 49 sec Remove/Install battery now ! |
