Old 01-21-2016, 14:31   #30631 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,988
Nokia C1-01 Read User Code Done :)
Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info...  - Ok
Reading Phone Info....
Connected phone -    C1-01
Software ver : V 04.40 23-02-11 RM-607 (c) Nokia
IMEI    :      355962040143093
XappVer :      0000087A
PPM     :      V 04.40 23-02-11 RM-607 (c) Nokia             M_C
CNT     :      Content: m_c_0596699 V 04.40 23-02-11 RM-607 (c) Nokia
Product SN   :     HUC308051
Product code :     0596379
Base Prd.code:     0585582
Module code  :     0204427
Long Prod.SN :     0
Hardware info=======
HWID  : 1001
Battery: 3735 mV
CMT BT: 19b5-22012
LCDVer: TPO
Lock info ===========
IMEI spNet : 3A 55 69 02 04 41 03 09
IMEI svNet : 33 55 69 02 04 41 03 19 F1
Sl Conf  : 001-01-00000000000
Sl Prof  : 800000000003000-B
Sl Aux   : 000B0000
Hw Sig   : 5818B95F1E6F4ED2
Country      : Test SIM (Open)
Operator     : NOKIA (Open)
Lock info:
Block 1
L1:Open;  L2:Open;  L3:Open;  L4:Open;  L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Error collect lock info, try again
CRT308 Backup Created
CMLA Key status : Not Present
SimLock status : Ok
Security status : Ok
PA_SimLock Version :
PA_SL3 phone ,  SP_CODE_LEN : 15
User Code : 25888
MMC pwd  : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 01-21-2016, 14:32   #30632 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 130
Verify files ...
MAUI : RM-1035_ROM_eMP_10.01.11
VIVA : RM-1035_VIVA_eMP_10.01.11
LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 46 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : D914916AF529BC0EA5110D16C00D9C10
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : CRYSTAL.10.01.11.p2
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000
SecureDecrypt : RM-1035_ROM_eMP_10.01.11
SecureDecrypt : RM-1035_VIVA_eMP_10.01.11
SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
OVRLP : 000069B900000001
PHPID : CRYSTAL.10.01.11.p2
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1035_ROM_eMP_10.01.11
Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
Write : RM-1035_VIVA_eMP_10.01.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1035_ROM_eMP_10.01.11
[VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11
CODE_VERIFY : Ok
FORMAT FFS : skipped
Rebooting phone now
Flashing done!
Total flash time : 00:00:53
Reboot phone Ok
Old 01-21-2016, 14:34   #30633 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia x2-05
Files Set for Flashing :
MCU : rm772__08.35.mcusw
PPM : rm772__08.35.ppm_m_a
CNT : rm772__08.35.image_m_a_059H0Q3
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm772__08.35.mcusw
Image : rm772__08.35.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x018C0000
Erasing, wait ...
Erase done, time : 00:00:47
Write , Start : 0x40280000 , Len : 0x01840000
Flashing , wait ...
Region flash done, time : 00:00:34
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x3754
   ===Flashing [PPM]===
File : rm772__08.35.ppm_m_a
Image : package_m_a.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41B40000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:09
Write , Start : 0x41B40000 , Len : 0x00461634
Flashing , wait ...
Region flash done, time : 00:00:05
CRC check passed , 0x472E
   ===Flashing [CNT]===
File : rm772__08.35.image_m_a_059H0Q3
Image : package_m_a_059H0Q3.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42240000 , Len : 0x01BE0000
Erasing, wait ...
Erase done, time : 00:01:05
Write , Start : 0x42240000 , Len : 0x00CC0000
Flashing , wait ...
Region flash done, time : 00:00:16
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0xE042
Flashing done!
Total flash time : 00:03:05
Reboot phone now...
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 42 certs
Certificates found, skip upload ...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:03:50
Phone found!
read info...  - Ok
Old 01-21-2016, 14:37   #30634 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia 2700
MCU : BD0153C4_rm561__09.98.mcusw
PPM : F952B617_rm561__09.98.ppm_u
CNT : 229E4545_rm561__09.98.image_ctv_thai_black
[Gen] Rules accepted for : RAP3x Generation
Check files done...
Getting product info...
--- Press phone's power button or insert cable & charger! ---
Waiting for communication response.
ASIC ID:       000000010000022600010006030C192101033000
CPU ID :       RAP3Gv3 , Features : No any extended features
RAP_PUB:   1270001947248A563F70E60B1A169FFCEE78FAE8
CMT_ROOT:  9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
Erase : Processing BD0153C4_rm561__09.98.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:36
Write : Processing BD0153C4_rm561__09.98.mcusw
Total 1256 [1256/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:00:59
MCU Write done
Erase : Processing F952B617_rm561__09.98.ppm_u
Found 1 areas to erase
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:04
Write : Processing F952B617_rm561__09.98.ppm_u
Total 424 [424/0/0] blocks to write, writing...
TIME : Write time : 00:00:20
PPM Write done
Erase : Processing 229E4545_rm561__09.98.image_ctv_thai_black
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:06:55
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing 229E4545_rm561__09.98.image_ctv_thai_black
Total 696 [696/0/0] blocks to write, writing...
TIME : Write time : 00:00:38
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:12:35
Reboot phone now...
SwUpgradeSet...OK!
Total - 0 certs
Uploading User Certificates...
Uploaded 26 certs!
Done!
Elapsed: 00:13:37
Phone found!
read info...  - Ok
Old 01-21-2016, 14:38   #30635 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia 112
MCU : rm837__03.51.mcusw
PPM : rm837__03.51.ppm_m2
CNT : rm837__03.51.image_m2_059P7C1
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.50_M1S1
FLASHID : 89008289
Boot done!
Check keys...
File : rm837__03.51.mcusw
Image : rm837__03.51.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:01
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:06
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:26
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x87F4
File : rm837__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:18
Write , Start : 0x41BC0000 , Len : 0x0030F7C0
Flashing , wait ...
Region flash done, time : 00:00:03
CRC check passed , 0x46E6
File : rm837__03.51.image_m2_059P7C1
Image : package_m2_059P7C1.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:03:47
Write , Start : 0x421C0000 , Len : 0x00EE0000
Flashing , wait ...
Region flash done, time : 00:00:20
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
CRC check passed , 0x2559
Flashing done!
Total flash time : 00:07:48
Reboot phone now...
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:08:25
Phone found!
read info...  - Ok
Old 01-21-2016, 14:39   #30636 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 206
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q8L5
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
FLASHID : 89008289
Boot done!
Check keys...
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:05
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:10
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:31
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
File : rm872__04.52.ppm_m2
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:20
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xC9E6
File : rm872__04.52.image_m2_059Q8L5
Image : package_m2_059Q8L5.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:04:01
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Region flash done, time : 00:00:22
Erasing, wait ...
Erase done, time : 00:00:08
No write data, skip
CRC check passed , 0xA5A8
Flashing done!
Total flash time : 00:07:47
Reboot phone now...
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:08:35
Phone found!
read info...  - Ok
Old 01-21-2016, 14:39   #30637 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia 205
MCU : rm862__03.18.mcusw
PPM : rm862__03.18.ppm_ma2
CNT : rm862__03.18.image_ma2_059Q0F3
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.55_M1S1
FLASHID : 89008289
Boot done!
Check keys...
File : rm862__03.18.mcusw
Image : rm862__03.18.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x017C0000
Erasing, wait ...
Erase done, time : 00:02:14
Write , Start : 0x40280000 , Len : 0x017C0000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x107F
File : rm862__03.18.ppm_ma2
Image : package_ma2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A40000 , Len : 0x00640000
Erasing, wait ...
Erase done, time : 00:00:22
Write , Start : 0x41A40000 , Len : 0x003EF444
Flashing , wait ...
CRC check passed , 0xF579
File : rm862__03.18.image_ma2_059Q0F3
Image : package_ma2_059Q0F3.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42080000 , Len : 0x01DA0000
Erasing, wait ...
Erase done, time : 00:04:16
Write , Start : 0x42080000 , Len : 0x00FC0000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0xF79F
Flashing done!
Total flash time : 00:08:10
Reboot phone now...
SwUpgradeSet...OK!
Total - 42 certs
Done!
Elapsed: 00:08:50
Phone found!
read info...  - Ok
Old 01-21-2016, 14:40   #30638 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia x2-00
MCU : rm618__08.35.mcusw
PPM : rm618__08.35.ppm_meac
CNT : rm618__08.35.image_meac_0595150
[Gen] Rules accepted for : RAPUxx Generation
Check files done...
--- Insert cable and charger or press phone's power button! ---
Waiting for communication response...
[BootRom] : 1st boot Ok!
ASIC ID:       000000000000000022000509200C0000
CPU ID :       BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID:        00005361
PUBLIC ID:     00000000009B120E0358674A861FF73AAE05A310
ASIC MODE ID:  00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID:        DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg  ,  Rev : 2.1  Ver : 12.8.0
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg  ,  Rev : 2.1  Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:02
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : E9700989029D9E899915F781B1582048E042A738
ADL: phone is in flash mode
 === SW Version Check ===
- > REFLASHING
Erase : Processing rm618__08.35.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm618__08.35.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [ISA+DYNSW]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [UPDAPP]
Total writen 511 blocks
TIME : Write time : 00:00:05
MCU Write done
ADL: Request programm status
NAND status : 00000002 / 00000001 / 00000000
Erase : Processing rm618__08.35.ppm_meac
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm618__08.35.ppm_meac
Total writen 100 blocks
TIME : Write time : 00:00:01
PPM Write done
Erase : Processing rm618__08.35.image_meac_0595150
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm618__08.35.image_meac_0595150
Total writen 342 blocks
TIME : Write time : 00:00:03
CNT Write done
ADL: Close_Session
Content: 000300000000020000000100000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:12
Reboot phone now...
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:01:02
Phone found!
read info...  - Ok
Old 01-21-2016, 14:41   #30639 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 130
Verify files ...
Wait for phone...
Phone found! [ 46 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 5D48F10E4A41B7AD5937255FAE9E130C
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
CODE_DNLOAD : Ok
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:01:02
Reboot phone Ok
Old 01-21-2016, 14:42   #30640 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia asha 202
MCU : rm834__20.52.mcusw
PPM : rm834__20.52.ppm_m_a
CNT : rm834__20.52.image_m_a_059M6C5
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.47_M1S1
FLASHID : EC001230
Boot done!
Check keys...
File : rm834__20.52.mcusw
Image : rm834__20.52.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:00:58
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:42
Erasing, wait ...
No write data, skip
CRC check passed , 0xD2A9
File : rm834__20.52.ppm_m_a
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Write , Start : 0x41DC0000 , Len : 0x0041B6E4
Flashing , wait ...
CRC check passed , 0xBBFE
File : rm834__20.52.image_m_a_059M6C5
Image : package_m_a_059M6C5.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:01:06
Write , Start : 0x424C0000 , Len : 0x00CC0000
Flashing , wait ...
Region flash done, time : 00:00:19
Erasing, wait ...
No write data, skip
CRC check passed , 0x78B9
Flashing done!
Total flash time : 00:03:29
Reboot phone now...
SwUpgradeSet...OK!
Total - 42 certs
Done!
Elapsed: 00:04:14
Phone found!
read info...  - Ok
Old 01-21-2016, 14:43   #30641 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 206
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : EC001230
Boot done!
Check keys...
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:48
Flashing , wait ...
Erasing, wait ...
No write data, skip
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Erase done, time : 00:00:10
Flashing , wait ...
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:01:10
Flashing , wait ...
Region flash done, time : 00:00:21
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:18
Reboot phone now...
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:04:03
Phone found!
read info...  - Ok
Old 01-21-2016, 14:44   #30642 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia 205
MCU : rm862__04.51.mcusw
PPM : rm862__04.51.ppm_ma3
CNT : rm862__04.51.image_ma3_059Q046
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : 89008289
Boot done!
Check keys...
File : rm862__04.51.mcusw
Image : rm862__04.51.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:13
Flashing , wait ...
Erasing, wait ...
No write data, skip
[Minor Error] : CRC returned by phone is wrong!
[CHK] : 01003014
File : rm862__04.51.ppm_ma3
Image : package_ma3.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Erase done, time : 00:00:28
Write , Start : 0x41A40000 , Len : 0x003F96F4
Flashing , wait ...
CRC check passed , 0xB428
File : rm862__04.51.image_ma3_059Q046
Image : package_ma3_059Q046.image.fls
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:03:51
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x4FA2
Flashing done!
Total flash time : 00:07:49
Reboot phone now...
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:08:44
Phone found!
read info...  - Ok
Old 01-21-2016, 14:52   #30643 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
nokia 5233 reset
Phone found!
Series 60 Device detected!
read info...  - Ok
Connected phone -    Nokia 5233
Software ver : V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
IMEI    :      352827057902405
XappVer :      00000866
Ape Ver :      V 51.1.002
APE Var :      V 51.1.002V 51.1.002 V 51.1.002
APE ADSP:      256
DSP Ver :      ICPR72_11WK13
APE Test:      eno_version
PPM     :
CNT     :
Product SN   :     471DDFBAA
Product code :     0597747
Base Prd.code:     0587948
Module code  :     0204695
Long Prod.SN :     0
HWID  : 0510
Retu  : 16
Tahvo : 22
Battery: 4581 mV
APE HW: 256
IMEI spNet : 3A 25 28 07 75 09 42 00
IMEI svNet : 33 25 28 07 75 09 42 10 F6
Conf key     : 0000000000000000
Provider key : 2440700000000000
Country      : Finland
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
SDD key status : Ok
CMLA Key status : Ok
SimLock status : Ok
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
Resetting selected items...
Operating mode is OK, no need change...
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:01
Phone disconected!
Old 01-21-2016, 14:53   #30644 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 110
MCU : rm827__03.51.mcusw
PPM : rm827__03.51.ppm_m2
CNT : rm827__03.51.image_m2_059Q541
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.49_M1S1
FLASHID : EC001230
Boot done!
Check keys...
File : rm827__03.51.mcusw
Image : rm827__03.51.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:51
Flashing , wait ...
Region flash done, time : 00:00:36
Erasing, wait ...
No write data, skip
CRC check passed , 0xA3D6
File : rm827__03.51.ppm_m2
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Write , Start : 0x41BC0000 , Len : 0x0030F748
Flashing , wait ...
CRC check passed , 0x4605
File : rm827__03.51.image_m2_059Q541
Image : package_m2_059Q541.image.fls
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:01:08
Write , Start : 0x421C0000 , Len : 0x00F00000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x7EE5
Flashing done!
Total flash time : 00:03:14
Reboot phone now...
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:03:50
Phone found!
read info...  - Ok
Old 01-21-2016, 14:54   #30645 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Nokia 108 format
Wait for phone...
Phone found! [ 46 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : 5B30A6293E731932AC08438A0AB16F51
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Rivendell.10.03.11.p1
BROM/BL stage done
DA_eMP_Rivendell.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.92897 seconds with 9 queries
