02-15-2016, 06:47 | #31381 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Code: Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040504A175D68137 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A175D68137 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : oppo72_14079 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4230 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_oppo72_14079.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0017 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : RESERVE2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:27 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : RESERVE2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:41 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:48 Reconnect Power/Cable! |
02-15-2016, 06:48 | #31382 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile X11 vires Remove Code: Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A269CDC1AB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A269CDC1AB [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 7 Removing infected files and scripts ... SmartAV Report : Removed 7 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:57 Reconnect Power/Cable! |
02-15-2016, 06:57 | #31383 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile I7 Reading Flash Code: Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201A2F4E0689143 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201A2F4E0689143 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile i7 ProdModel : QMobile i7 Device : QMobile i7 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 [Read Ok] : preloader_lcsh82_wet_hz_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / lcsh82_wet_hz_kk / EMMC FW Size : 935 MiB Scatter saved to : H:\Android tab and mobiles scatter files\Q mobiles\(...I...)\MT6582__QMobile__QMobile_i7__QMobile_i7__4.4.2__ALPS.KK1.MP1.V2.11\ All done! Done! Elapsed: 00:05:16 Reconnect Power/Cable! Remove Viruses Code: Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201A2F4E0689143 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201A2F4E0689143 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 37 Removing infected files and scripts ... SmartAV Report : Removed 37 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:28 Reconnect Power/Cable! |
02-15-2016, 07:03 | #31384 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile X6i Formating Code: Operation : Format File System / Reset Settings [ v1.14 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 147 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
02-15-2016, 07:23 | #31385 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile X500 Flashing done Code: Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42015AF4CE5B81A7 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42015AF4CE5B81A7 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : lcsh82_wet_hz_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3574 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEA80000 Flash Pre-Erase Done, time used : 00:00:11 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh82_wet_hz_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:12 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:41 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:22 Reconnect Power/Cable! |
02-15-2016, 07:25 | #31386 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Huawei Y511-u30 Read Pattern done Code: Operation : Read Pattern/DP Lock [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048600A354A02101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A354A02101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 14789 Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
02-15-2016, 07:41 | #31387 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile I5 flasing done Code: Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040504A23C303275 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A23C303275 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3777 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E3F00000 Flash Pre-Erase Done, time used : 00:00:13 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4700.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:40 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:53 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:02 Reconnect Power/Cable! |
02-15-2016, 08:02 | #31388 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile W20 read code Code: Operation : Read UserCode [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : E74B1FA5C5F0D47674F2CBE0AD29E54D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x00FF0000 , 0x00010000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 1031 PLock|MobTrack : Not active Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-15-2016, 08:28 | #31389 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | LAva X8Q Code: Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142018530D6D1C14D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 150100513758534142018530D6D1C14D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-15-2016, 08:29 | #31390 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Huawei Y511-u30 Fix DL Errors Code: Operation : Fix DL Errors [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048600A354A02101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A354A02101 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
02-15-2016, 09:29 | #31391 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Samsung SM-N900 Read Info Read Factory File Done Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473AFAAF1FD8525B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473AFAAF1FD8525B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : ja3gxx ProdModel : SM-N900 Device : ja3g AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1 EXTRA : LCD [0] : hx8389c_qc_dsi_vdo_qhd LCD [1] : ili9807_bft_cpt_qhd LCD [2] : rm68191_qhd_dsi_vdo LCD [3] : hx8389b_dsi_vdo_boe_qhd LCD [4] : otm9605_dsi_vdo_qhd LCD [5] : otm9608a_dsi_cmd_qhd nt35517_dsi_vdo_qhd LCD Res : 960x540 TOUCH [0] : mtk_gslX680 TOUCH [1] : GT9XX CAM [0] : ov5645_pip_yuv CAM [1] : ov7695_yuv MODEM : mbk72_wet_jb3_hspa_v2 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hi_IN hdpi pl_PL Done! Elapsed: 00:00:19 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473AFAAF1FD8525B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473AFAAF1FD8525B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : ja3gxx ProdModel : SM-N900 Device : ja3g AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_mbk72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_jb3 / EMMC FW Size : 774 MiB Scatter saved to : C:\Users\Luckey1\Desktop\MT6589__samsung__SM-N900__ja3g__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:30 Reconnect Power/Cable! |
02-15-2016, 10:14 | #31393 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Faislabad Age: 34
Member: 1657674 Status: Offline Thanks Meter: 855 | Glaxy S4 CLONE MTK6572 Nand Read Flash Done BY CM2 Operation : Read Flash [ v1.40 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 4 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... [Read Ok] : preloader_benrui72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : fat_empty.img [Read Ok] : system.img [Read Ok] : cache_empty.img [Read Ok] : usrdata_empty.img [ScatCFG] : MT6572 / V1.1.1 / benrui72_wet_lca / NAND FW Size : 288 MiB Scatter saved to : C:\Users\Ali jaan\Desktop\s4\MT6572__NAND__benrui72_wet_lca Done! Elapsed: 00:02:35 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to alijaanfsd For This Useful Post: |
02-15-2016, 10:57 | #31394 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile i5 format done Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930516059511851F5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930516059511851F5 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! BR GSM BOSS |
02-15-2016, 12:34 | #31395 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia C1-01 Flash Done :) Code: Core : v2.19 , BB5XG FlashEngine : v10.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.40.mcusw PPM : rm607__04.40.ppm_m_c CNT : rm607__04.40.image_m_c_0595609 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 04.40 Phone version : 06.07 13-10-11 RM-607 (c) Nokia -> Check SW version : Downgrade try -> Downgrade enabled by user request Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_2.3_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 359295046929017 PCcode : 0596700 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : F:\1+Flashing Software\1+BEST\InfinityBox\BEST\Backup\Cert\359295046929017_2nd_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm607__04.40.mcusw Image : rm607__04.40.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:02 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:48 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:40 CRC check passed , 0xD471 ===Flashing [PPM]=== File : rm607__04.40.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x41C00000 , Len : 0x0031A50C Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x4A12 ===Flashing [CNT]=== File : rm607__04.40.image_m_c_0595609 Image : package_m_c_0595609.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:04 Write , Start : 0x42200000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:15 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x17AA Flashing done! Total flash time : 00:03:09 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.40 23-02-11 RM-607 (c) Nokia IMEI: 359295046929017 PPM version : V 04.40 23-02-11 RM-607 (c) Nokia M_C Product code: 0596700 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:59 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
