07-04-2010, 16:51 | #3166 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Huwaei 2821 Unlock Done Code: COM1 [VCP3] selected module v1.06 Device: Huawei-C2821 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
07-04-2010, 20:31 | #3167 (permalink) |
Banned Join Date: May 2010
Member: 1308936 Status: Offline Thanks Meter: 88 | Vodafone -547 unlock sucess !!!! VODAFONE -547 UNLOCK SUCESS !!!! COM7 [VCP0] selected module v3.47 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-547 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: VF_UK_EN_P107A4V1.2.0B03 Version: 09AZTENJ35_09A 83 byte(s) read imei: 35962103006893 connection Ok 189 byte(s) read reading data... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 1 min 29 sec Remove/Install battery now ! THANKS INFINITY TEAM |
The Following User Says Thank You to manoj_kc For This Useful Post: |
07-05-2010, 05:53 | #3168 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v3.43 Device: LG-KG300 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6227:8A02:8A01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0012]: 0098:007600A500C0 [TOSHIBA] TC58DVM92A1FT chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7312SA00-001-R1C detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN project-id: 7S7312SA00-001-R1C, 00000000 code offset: 00000000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 1126644323112232242190BABECCCCCB warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 39 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
07-05-2010, 06:02 | #3169 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 351695019898826 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 352661003632133 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
07-05-2010, 07:45 | #3170 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM12 [VCP6] selected module v3.15 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2203:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: E808_PR1_V5.0_PAKISTAN Version: TINNO25_08B_GEMINI_HW detecting structure #2... 1 2 5 6 7 8 9 11 13 17 18 21 22 23 24 25 27 29error: detection failed (18 tries), read flash and send to support connection Ok building list... done items to clear: 165 warning: wrong packet cs warning: wrong packet cs items cleared: 122 of 165 items remains: 0 Finished, time used: 3 min 43 sec Remove/Install battery now ! |
07-05-2010, 08:59 | #3171 (permalink) |
No Life Poster Join Date: Nov 2009 Location: INDIA
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | COM3 [VCP0] selected module v1.06 Device: Samsung-SCH-B239, B259, B279 Action: "sp-unlock" Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 21 sec |
The Following 3 Users Say Thank You to javeed_mp For This Useful Post: |
07-05-2010, 09:40 | #3172 (permalink) |
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | b259 unlock COM3 [VCP0] selected module v1.06 Device: Samsung-SCH-B239, B259, B279 Action: "sp-unlock" Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 19 sec |
07-05-2010, 10:24 | #3173 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Nice Haier 2076- Varison-D Unlock Done Code: COM6 [QCUSB_COM6_22] selected module v1.06 Device: Haier-C2076-Version-D Action: "sp-unlock" Phone should be Switched ON ! connecting... HAIER C2076 ver D... downloading mode... sending command... patching in progress 30%... patching in progress 60%... patching in progress 90%... patching in progress 100%... Done... Finished, time used: 16 sec |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
07-05-2010, 11:57 | #3174 (permalink) |
No Life Poster Join Date: Feb 2005
Member: 113097 Status: Offline Thanks Meter: 365 | samsung S399 done sel: Samsung-SCH-S259, S269, S299COM7 [VCP0] selected module v1.05 Device: Samsung-SCH-S259, S269, S299 Action: "sp-unlock" Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec Last edited by kapilkapoor; 07-05-2010 at 11:59. Reason: device change |
The Following 2 Users Say Thank You to kapilkapoor For This Useful Post: |
07-05-2010, 14:37 | #3175 (permalink) |
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | c5330 unlock COM3 [VCP0] selected module v1.06 Device: Huawei-C5330-Version-108 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 6 sec |
The Following 2 Users Say Thank You to javeed_mp For This Useful Post: |
07-05-2010, 15:03 | #3176 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ot-203 unlocked module v3.48 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5892:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37M provider: 203X-2BRGTE5 customization: CM37CC31 customization: XM37CC31 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM37CC31 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908003200710 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100705-064647.B0X.bin Finished, time used: 2 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
07-06-2010, 05:19 | #3177 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP0] selected module v1.06 Device: Huawei-C5330-Version-108 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 8 sec |
The Following 3 Users Say Thank You to joni_rajpura For This Useful Post: |
07-06-2010, 06:30 | #3178 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Vodafone 225 unlock ok ! COM4 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -SA-P108A2V1.0.0B08 VDF-P108A2B07-RoFr-SA03 g3dBV2.0 Aug 10 2007 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20100706-105627.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20100706-105628.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20100706-105634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20100706-105646.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 50 sec Remove/Install battery now ! Thanks teem ! |
The Following User Says Thank You to nishue For This Useful Post: |
07-06-2010, 07:42 | #3179 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | vodafhone 541..........unlock done... COM5 [VCP1] selected module v3.41 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4C03:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\InfinityBox\MModule\backup_security\id.E22CD9F6 .[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E22CD9F6 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDDE1 customization: CN17FB75 customization: XN17FB75 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703950535 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: E:\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_E22CD9F6_E8F450A0_20100705-231358.B0X.bin Finished, time used: 4 min 23 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to zeerik For This Useful Post: |
07-06-2010, 08:14 | #3180 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | haier m151 unlockedcted module v1.78 Device: Haier-HG-M151 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:235D Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Haier-HG-M151_eeprom-static_20100706-000833.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Haier-HG-M151_eeprom-security_20100706-000834.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Haier-HG-M151_eeprom-complete_20100706-000841.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Haier-HG-M151_lock-area_20100706-000854.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 59 sec Remove/Install battery now ! |
