07-07-2010, 08:41 | #3196 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Haier Unlock Done Code: COM104 [QCUSB_COM104_1] selected module v1.06 Device: Haier-C2000, C2010, C3000, C3010 old Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... disabling minlock... Done... Phones should be restarting now... Finished, time used: 4 sec |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
07-07-2010, 08:43 | #3197 (permalink) |
No Life Poster Join Date: Feb 2005
Member: 113097 Status: Offline Thanks Meter: 365 | LG-3540 unlock done COM22 [LGSIDIAG0] selected module v1.05 Device: LG-3540 Action: "sp-unlock" Phone should be Switched ON ! connecting... RD354F04 LG RD-3540 version 4 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 26 sec |
The Following 3 Users Say Thank You to kapilkapoor For This Useful Post: |
07-07-2010, 08:45 | #3198 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Zte 335 Unlock Done Selact With ZTE-C3xx-TATA Code: COM256 [VCP0] selected module v1.06 Device: ZTE-C3xx-TATA Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec |
07-07-2010, 08:55 | #3200 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP2] selected Device: BenQ EF61 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:881500010001 file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20100707-125243.91F.bin Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:881500010001 Writing Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
07-07-2010, 10:19 | #3201 (permalink) |
Member: 113097 Status: Offline Thanks Meter: 365 | ZTE-F280 unlock done Code: COM24 [QCUSB_COM24_1] selected module v1.05 Device: ZTE-F280 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 19 sec |
07-07-2010, 10:37 | #3202 (permalink) |
Member: 113097 Status: Offline Thanks Meter: 365 | ZTE-S100 unlock Done Code: COM26 [QCUSB_COM26_1] selected module v1.05 Device: ZTE-S100 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec |
07-07-2010, 11:06 | #3203 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM8 [VCP0] selected module v3.15 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FA03:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: LBBMM01.8.32.1.3T04M0724_M513 Version: LCSH25_08A_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35403203258640 connection Ok building list... done items to clear: 168 warning: wrong packet cs warning: wrong packet cs items cleared: 168 of 168 building list... done items remains: 0 Finished, time used: 26 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
07-07-2010, 11:46 | #3204 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Haier C5000 06 Done Code: HA5000MT06 Haier C5000 version 06 selected.. Sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 13 sec |
07-07-2010, 11:50 | #3205 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM24 [VCP0] selected module v3.15 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9B03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: N82_OV_6205_SP_0522_V1.2_19 Version: GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 144 warning: wrong packet cs warning: wrong packet cs items cleared: 144 of 144 building list... done items remains: 0 Finished, time used: 48 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
07-07-2010, 11:52 | #3206 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Again Or Again Unlock Done Huwaei 2206 Code: COM2 [VCP10] selected module v1.06 Device: Huawei-C2206 Action: "sp-unlock" Phone should be Switched ON ! connecting... checking version... C2206C02B102 C2206C02B102 Huawei C2206 version B102 selected.. OFFLINE... downloading mode... erasing... pacthing in progress... pls wait... patching in progress 10%.. patching in progress 15%.. patching in progress 20%.. patching in progress 25%.. patching in progress 30%.. patching in progress 35%.. patching in progress 40%.. patching in progress 45%.. patching in progress 50%.. patching in progress 55%.. patching in progress 60%.. patching in progress 65%.. patching in progress 70%.. patching in progress 75%.. patching in progress 77%.. patching in progress 80%.. patching in progress 85%.. patching in progress 90%.. patching in progress 95%.. DONE... Phones should be restarting now... Finished, time used: 35 sec |
The Following 4 Users Say Thank You to pradeep_kus For This Useful Post: |
07-07-2010, 12:22 | #3207 (permalink) |
No Life Poster Join Date: Dec 2009 Location: westbengal(katwa)
Member: 1175892 Status: Offline Thanks Meter: 61 | samsung B119 unlock done.!!!!!! COM13 [sacumdm0] selected module v1.06 Device: Samsung-SCH-B119 Action: "sp-unlock" Phone should be Switched ON ! connecting... samsung b119... downloading mode... Wait reconnecting port... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now... Finished, time used: 29 sec |
The Following 2 Users Say Thank You to RABIULSK For This Useful Post: |
07-07-2010, 12:32 | #3208 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | C335 ZTE phone blocked contact service centre solved & unlock as well! COM3 [VCP0] selected module v1.06 Device: ZTE-C3xx-TATA Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec Br Kmax |
The Following 6 Users Say Thank You to kmaxmax For This Useful Post: |
07-07-2010, 13:13 | #3209 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Huwaei 2605 Unlock Done Code: COM256 [VCP12] selected module v1.06 Device: Huawei-C2605 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
07-07-2010, 13:22 | #3210 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Lg Rd 3100 Done Code: COM2 [VCP15] selected module v1.06 Device: LG-3100 Action: "sp-unlock" Phone should be Switched ON ! connecting... change baudrate... RD310F05 LG RD-3100 version 5 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 43 sec |
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
