07-17-2010, 13:32 | #3331 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | module v1.10 Device: Samsung-SCH-B239, B259, B279 Action: "sp-unlock" Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 18 sec |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
07-17-2010, 15:05 | #3332 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | COM1 [Serial0] selected module v3.49 Device: Verykool-i300 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A9F2:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: I305FM_SAD_PCB01_GPRS_MT6223P_S00.KAAI305FM_SAD_SP _EN_FR_1_04_C01.BIN project-id: KAAI305FM_SAD_Sp_En_Fr_1.04.C01, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... .................................. lock area found .................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 28 sec Remove/Install battery now ! |
The Following User Says Thank You to thewolverine For This Useful Post: |
07-17-2010, 15:45 | #3333 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | COM12 [LGSIDIAG1] selected module v1.10 Device: LG-3530 Action: "sp-unlock" Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
07-17-2010, 15:47 | #3334 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | SONY ERICSSON K200i user code module v1.38 Device: Sony-Ericsson-K200i "advanced chip detection" active Action: user code Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AB003 software version: CXC1250832 version flex: CDA102773/44 imei: 35617701466104 Check hardware done Read data ... reading Sony-Ericsson-K200i_35617701466104_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701466104_eeprom_calibration-1_20100717-065230.80E.bin reading Sony-Ericsson-K200i_35617701466104_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701466104_eeprom_calibration-2_20100717-065239.80E.bin reading Sony-Ericsson-K200i_35617701466104_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701466104_ffs_20100717-065847.80E.bin Read data done Check data ... Check data done Write ... .................................................. .................................................. ..............................user code set to: 0000 flash: 01227E22212200:46237300000000 Write: eeprom Write done Finished, time used: 9 min 40 sec Remove/Install battery now ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
07-17-2010, 16:35 | #3335 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | SMADL D31 FLIGHT MODE,DONE module v3.16 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:68CC:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 flash: SST SST34HF3244/3284 U 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.16, database date: 16.07.2010): MT500P_V3_03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: MT500P_V3_03.BIN project-id: MT500P_V3.03, 00000000 code offset: 00000000 ffs offset/size [01]: 003D0000/00030000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 003D0000 standard ffs/eeprom offset confirmed: 003D0000 detecting ffs/eeprom size... ffs/eeprom size: 00030000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:003D0000-003FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT500P_V3_03__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT500P_V3_03__ffs _20100717-081842.B0E.bin flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: BF7353FFFFFFFF:2BEA0000000000 flash: BF7353FFFFFFFF:2BEA0000000000 Finalization Done Finished, time used: 2 min 0 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
07-17-2010, 17:17 | #3336 (permalink) |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Lg 3600 blinking repair with select model 3500 and reapir done!!!!! LG 3600 BLINKING REAPIR DONE WITH USNING LG3500 MODEL.. HERE R LOG..[CODE][COM2 [VCP0] selected module v1.10 Device: LG-3500 operation: Repair "Blink" Phone should be Switched ON ! connecting... Repair blink lg-3500 version 08... sending command.... fixing 1.... fixing 2.... fixing 3.... fixing 4.... fixing 5.... fixing 6.... fixing 7.... fixing 8.... fixing 9.... fixing 10.... fixing 11.... fixing 12.... fixing 13.... fixing 14.... fixing 15.... fixing 16.... fixing 17.... fixing 18.... fixing 19.... fixing 20.... done.... Finished, time used: 24 sec [CODE] AND ANOTHER DONE.. LG 3530 WITH 3530... HERE R LOG... Code: COM2 [VCP0] selected module v1.10 Device: LG-3530 operation: Repair "Blink" Phone should be Switched ON ! connecting... Repair blink lg-3530 version 02... sending command.... fixing 1.... fixing 2.... fixing 3.... fixing 4.... fixing 5.... fixing 6.... fixing 7.... fixing 8.... fixing 9.... fixing 10.... fixing 11.... fixing 12.... fixing 13.... fixing 14.... fixing 15.... fixing 16.... fixing 17.... fixing 18.... fixing 19.... fixing 20.... done.... Finished, time used: 24 sec |
The Following 3 Users Say Thank You to PUNEET5154 For This Useful Post: |
07-17-2010, 18:07 | #3337 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | COM1 [Serial0] selected module v3.49 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F703:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 1E3CF2.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8DF3C2F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 901E3CF2 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 2F3CDFE8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 16W provider: 708A-2CRGDO3 customization: CN16NQ30 customization: XN16NQ30 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... max address is too big, should be recalculated: 00006F50->00006C54 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16NQ30 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16NQ30 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01194600887924 flash: 01227E22302200:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_901E3CF2_E8DF3C2F_20 100717-010404.B0X.bin Finished, time used: 4 min 34 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
07-17-2010, 19:16 | #3338 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 47
Member: 196194 Status: Offline Thanks Meter: 47 | samsung cdma B519 RESET CODE SUCCESSFULLY! samsung cdma B519 RESET CODE SUCCESSFULLY! COM3 [VCP0] selected module v1.14 Device: Samsung-SCH-B619 Checking data, wait... Action: rebuild Phone should be Switched ON ! Connecting, wait... Phone detected, wait... error: can not get correct rebuild answer, test phone after operation error: operation failed Finished, time used: 9 sec Remove/Install battery now ! REGARDS! |
The Following 3 Users Say Thank You to shoeb7 For This Useful Post: |
07-18-2010, 06:42 | #3339 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DELHI,INDIA
Member: 427627 Status: Offline Thanks Meter: 160 | lg rd3100 v4 unlocked by infinity COM1 [Serial0] selected module v1.10 Device: LG-3100 Action: "sp-unlock" Phone should be Switched ON ! connecting... change baudrate... RD310F04 LG RD-3100 version 4 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 40 se thanks lalitg |
The Following 2 Users Say Thank You to lalitgvarshney For This Useful Post: |
07-18-2010, 09:43 | #3340 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM10 [Serial2] selected module v3.15 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7603:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N81_ABROAD_2CDGB_S5LCD_V1.2.2 Version: M500_P3 detecting structure #2... 4 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 1 4 5 6 8 11 14 15 16 done 211 byte(s) read 512 byte(s) read calibration value: 0 writing data... warning: wrong packet cs verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
07-18-2010, 13:32 | #3341 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Another Moto C130 suecssfully unlocked COM4 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.3.29 HW version: _E88 LP ver: LPH_C139_ASIA2_Z1C Flex ver: FFH_C139_67_Z1C imei otp: 357251003660642 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _357251003660642_20100718-180111.31E.bin imei eeprom: 357251003660642 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 69 sec Remove/Install battery now ! |
The Following User Says Thank You to akashub For This Useful Post: |
07-18-2010, 14:32 | #3342 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Samsung S259 UNLOCKED SUCESSSFULLY BY INFINITY-CDMA TOOL Samsung S259 UNLOCKED SUCESSSFULLY BY INFINITY-CDMA TOOL COM22 [VCP0] selected module v1.10 Device: Samsung-SCH-S259, S269, S299 Action: "sp-unlock" Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
The Following 2 Users Say Thank You to akashub For This Useful Post: |
07-18-2010, 14:44 | #3343 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM24 [VCP0] selected module v3.03 Action: reset settings ("format ffs") Model: LG-KP220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 00316C1:03B2 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7338SA00-002-R1B Version: EP_0920 60 byte(s) read imei: 35167202217713 connection Ok building list... done items to clear: 225 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 225 of 225 items remains: 0 Finished, time used: 47 sec Remove/Install battery now ! |
07-18-2010, 17:12 | #3344 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | HAIER C5000 VER06 UNLOCK DONE... Code: HA5000MV06 Haier C5000 version 06 selected.. Sending command... patching in progress... Done... Phones should be restarting now... Finished, time used: 13 sec |
The Following 2 Users Say Thank You to PUNEET5154 For This Useful Post: |
07-19-2010, 07:14 | #3345 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v3.49 Action: reset settings ("format ffs") Model: LG-KG200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:3441:9850 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7330SA00-001-R1D Version: EP1 60 byte(s) read imei: 35282701536314 connection Ok building list... done items to clear: 213 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 213 of 213 building list... done items remains: 0 Finished, time used: 40 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
